Question about Sony Ericsson K750i Cellular Phone
Photo is not saving
Whenever i 'm taking a photo , it is not saving & just return back to main menu,I have master reseted the phone but still the problem persists.
pls help me to come out this problem.
Raj
  • Anonymous May 11, 2010
    hi ,
    first of all you cheak that in witch memory your are saving
    the photos in phone or memory stick. may be your memory card got currupt. so change the save to option first, if steel not saving then relode the softwere. your phone will ok 100%.
    thanks
    vyas
I have also got the same problem... desperately in search of solution, I just format my phone memory and memory card through my pc.
this is the solution ... How to do!!
Copy your all files from memory card and phone memory to your hard disc and format both of them.........
Now start your camera, select destination - first the phone memory, click one photo. Then your memory card, and click. This is just to create folder through mobile. Now try to play song to create folder.
Now!! paste your files to the folder created on your phone and Mem card, and don't past the folder. If you need folder then create new one.
Your Phone will be OK now !!!!!!!!!!!
Posted on Apr 20, 2008
    Brigadier General:
  • 7,752 Answers
Cool
Posted on Apr 10, 2008
SOURCE:
MY PHONE IS LOCK AND I CANNOT UNLOCK IT. WHAT CAN I DO?
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.samsung.com/us/consumer/mobile/mobile-phones/t-mobile-phones/SGH-T929ZKATMB/index.idx?pagetype=prd_detail&tab=support
Page 165 from your manual:
Reset Settings
From this menu you can reset your phone and sound settings to the default settings or perform a Master reset.
Reset settings
1. From Idle mode, touch Menu ➔ Settings ➔Reset settings ➔Reset settings.
2. Touch the check box next to each of the following that you want to reset
• All: Phone, Display, and Sound settings are returned to default values.
• Sound profiles: only sound settings are returned to default values.
• Display settings: only display settings are returned to default values.
• Phone settings: only phone settings are returned to default values.
3. Touch Reset.
Master reset
From this menu you can reset your phone and sound settings to the factory default settings.
1. From Idle mode, touch Menu ➔ Settings ➔ Reset settings.
2. Touch Master reset, enter your password, then select Yes to confirm.
The phone resets to the factory default settings automatically and when finished displays the Main menu.
Hope this helps, let me know if I can do anything else for you.
JimmyC
Oct 13, 2009 | Samsung Memoir SGH-T929 Cell Phone
K618i Camera fail to capture photo
if your flash is on turn it (off)
if your flash is off turn it (on)
Oct 07, 2009 | Sony Ericsson K750i Cellular Phone
When i take a photo it comes up some times "unable to save file" and then i lose the photo??help.i have memory card and only a couple of photos so memory not full up i think??
Usually the camera saves the file in Phone memory rather than Memory Card.
So change the default storage to memory card.
It will be under the main settings menu.
Or the camera settings.
You can also make enough space in Phone Memory, so that a picture can accommodate itself, but its not a permanent solution.
If Helpful, kindly Rate.
Jul 17, 2009 | Nokia 5200 Cellular Phone
Whenever i try to take photo the camera turns to
probably ther isn't enough space left in ur phone memory try deleting to clear up unwanted stuff.
If there is space both in ur phone as well as memory card then rearrange all items in the memory card to specified folders. like if there are items that show outside the folders then dump them into the folders and this will solve ur problem.
This is strange but try it all will be ok. Next time when u want to format ur memory card see that u do it with the phone itself and not through a PC
Jul 01, 2009 | Nokia 6300 Cellular Phone
My krzr screen shows everything backwards!
Try a master Reset.
To perform a master reset on the handset, follow these steps:
NOTE: A master reset restores the original factory settings and can erase all downloaded content, including ringtones, camera images, contacts stored in the handset memory, and Java™ applications. It does not erase data stored on the SIM card or memory card. Back up all necessary data on the handset memory before proceeding.
  1. From the main screen, select Main Menu.
  2. Scroll to and select Settings.
  3. Scroll to and select Initial Setup.
  4. Scroll to and select Master Reset.
  5. Enter the security code.
    • NOTE: The default security code is 000000 (six zeros).
  6. Select OK.
  7. Select Yes.
  8. Press the red End pattlnk_5142007_1444-redend.gif key to exit and return to the main screen.
Dec 09, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Tone setting problem
you could try a master reset but i am not to sure why it goes back to the main menu
Sep 13, 2008 | Nokia 1100
Cant get my cell to go back to its factory settings
To do a reset, go to your main menu and select 'Settings'. Select 'General' from the list and scroll to 'Master Reset' and select. Select 'Reset Settings'. If the phone prompts for a password, enter the default 0000, unless you've changed the phone's password.
To do a master reset, go to your Menu, then select Settings. Under the General tab, scroll down to Master reset and press select. Select Reset All and press yes.
If prompted, the default passcode is 0000.
Please note that a Master Reset will return the phone to its factory default settings. All user data and settings will be deleted. If you have any files or information you would like to save, you should either back it up to a memory stick or your computer. Your contacts can be backed up to the memory stick or your SIM card.
Apr 30, 2008 | Sony Ericsson W200i Cellular Phone
Camera
try deleting the cache file from your internet. If you have a computer with bluetooth, try transferring all you photos off of it, then emptying your photo file and trying again. make sure youre attempting to save to your phone, not the sim or SD slot if its empty.
Oct 16, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Sony Ericsson K750i Cellular Phone Logo
65 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
