Question about Toshiba 42H81 42" Rear Projection Television
Programming rca universal remote for my toshiba tv
My Toshiba tv remote has a button on it that says "input". This is how I can switch my tv from "tv" to dvd/vcr or aux mode. I programmed the RCA universal remote to my tv, but am unable to switch from tv to dvd/vcr or aux mode. Any similar button on the RCA remote doesn't seem to work. Any ideas?
  • Anonymous Oct 05, 2008
    none of the listed codes work.
I can't exactly help you, but can you tell me how you programmed the remote to your TV, because I cannot get mine to work...
Posted on Sep 12, 2008
I have a toshiba universal remote model ct-90121. I need the program codes and programing instructions for an rca tv
According to Toshiba, the CT-90121 isn't a universal remote control. This remote only works with TOSHIBA TVs with the following model numbers:
32AFX62, 32AFX63, 32HFX72, 34HDX82, 36AFX62, 36AFX63, 36FX72, 36HFX72, 42HDX52, 42HDX82, 50HX70, 57HDX82, 57HL83, 57HLX82, 65HDX82, 65HLX83
Unless you posted the wrong remote model number (?) your Toshiba remote isn't going to work with your RCA TV.
Please rate this solution if you find it helpful. Thanks!
Nov 02, 2010 | Toshiba Televison & Video
How to make tosiba tv show the movie that is playing on a tosiba
You may need to manually switch the input on your tv via the menu on the front panel switches if your universal remote does not have an input button or it just wont respond.
Aug 25, 2009 | Toshiba 27AF43 27" TV
Switch Toshiba projection tv to receive input from video-1?
If your DISH remote is programmed to your Toshiba TV, you can press the TV button at the top left of the remote and then release. This will put the remote in TV mode. Press and release the TV/Video button just below the clear TV button. This will cycle through the inputs on your TV. Continue to press and release until you have Video-1 displayed on your TV screen. I hope this helps.
Ray Calo
DISH Network
Jun 14, 2009 | DISH Network DVR-625 DTV Receiver /...
Need Toshiba remote access code for this product so I can use a universal remote to operate the VCR and DVD
remote codes are set by the manufacurer of the remote not the tv. if there are any others not listed in instructions for remote, the manufacturer of remote would have them. most combo unit are not able to be programmed into universal remotes due to the fact that there are alot of specialized function buttons on original remote. you can obtain a replacement remote thru toshiba
May 16, 2009 | Toshiba MW24F51 24 in. TV/VCR/DVD Combo
Universal remote works for basics but won't change input
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
Jan 31, 2009 | Toshiba 32A33 32" TV
Toshiba mo#20af44 hooking up 360 xbox
As far as I'm aware, the only way to switch inputs on the TV is by using the Toshiba remote--there aren't buttons on the TV itself to do it. Which means unfortunately, if nothing on your universal remote will do so and you don't have the Toshiba remote (either to use or to reprogram your universal remote with), you may be out of luck.
Oct 11, 2008 | Toshiba 20AF44 20" TV
Can't find code for my RCR312W to work on my Toshiba TV. I tried all different codes. Any suggestions?
Have you tried these codes?
Code 1000 for Toshiba TV Code 1048 for Toshiba TV Code 1072 for Toshiba TV Code 1105 for Toshiba TV Code 1109 for Toshiba TV Code 1118 for Toshiba TV Code 1160 for Toshiba TV Code 1190 for Toshiba TV Code 1241 for Toshiba TV
Sep 10, 2008 | RCA Universal Remote Control
rca d770 universal remote how do i program
Sep 03, 2008 | RCA Universal Remote Control
Programming remote to toshiba Tv
Depending on the universal remote you can usually program the remote without knowing the codes. One way is to turn on the television, then follow the basic programming instructions for the remote, but instead of entering a code, hit the power button over and over again until the television turns off.
I hope this helps.
May 27, 2008 | Toshiba 27A34 27" TV
Toshiba 42H81 42" Rear Projection Television Logo
386 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
