Question about Canon imageRUNNER 210S Copier
E051 sensor location
I also keep getting error code 051 on my Cannon image Runner 400/330 series
Can you tell me where the The horizontal registration sensor
(PS10) and the horizontal registration motor (M9) are located at?
I moved the copier fromo ne side of the floor to the other and not I get that same error E051
Thanks
E051
The horizontal registration home position
detection mechanism has a fault.
• The horizontal registration sensor
(PS10) has a fault.
• The horizontal registration motor (M9)
has a fault.
• The DC controller PCB has a fault.
Any problems please get back to me
Thank You
  • Anonymous Jun 20, 2008
    please show through diagram
  • 47 Answers
It is located behind the paper pickup unit on the pre-registration guide. There is a teeny tiny motor with a tiny plastic gear and the gear cracks which stalls the motor. The purpose of the sensor and motor are to find the front (or is it rear?) edge of the paper coming out of the duplex unit so it can accuratly line up the images on the paper.
Posted on May 07, 2008
E001 e014 e051
E-001.check the thmistor.if it is o.k.DC controler or IP board has a fault.
E 014 faulty rotation of heater unit .correct it.else dc board has a fault.
E 051 horizontal registration sensor not sensing home position.might be mechanical problem or motor might be faulty.
Aug 07, 2011 | Canon imageRUNNER 400S Copier
Can the E051 error message be fixed by someone other than a technician. On a Cannon Image Runner 400/330 series. I tried finding the upper right side sensor that should have long white plastic teeth
Someone who is not a technician can only do the following:
1. disconnect the souter and detarche it from the machine.
2. E051 means the souter ias not functioning properly discopnnect and the problem is gone while you look for the technician to repair your souter.
Jul 12, 2011 | Canon imageRUNNER 400S Copier
My machine shows E051 error how to solve this problem.. Switchmain power off & on E051 is the total display of my machine can u please give me a solution for this
E 051 IS PROBLEME OF REGISTRATION MOTOR SENSOR NOT OPERATING.THIS MAY BE DUE TO NON MOVEMENT OF SLIDER FOR FAILURE OF GEAR BREAKAGE OR OBSTRUCTION FOR ITS MOVEMENT.LOCATION AFTER OPENING RIGHT DOOR JUST BELOW FEEDER METAL PLATE.
Jun 27, 2011 | Canon imageRUNNER 400S Copier
Error code 000051
From service manual E051-0000 At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
Main cause The horizontal home position sensor is faulty. The horizontal registration motor is faulty. The DC controller PCB is faulty.
Action
1. Connector
Are the connectors of the horizontal registration home position sensor and the horizontal registration motor connected?
a. DC controller PCB (J304) <-> relay connector <-> horizontal registration home position sensor
b. DC controller PCB (J304) <-> relay connector <-> horizontal registration motor
NO: Connect the connectors.
2. Sensor lever (damage and interference), Sensor
Is abnormal noise heard from the horizontal registration assembly in keeping with the motor rotation?
YES: a. The horizontal registration assembly is out of place because of
damage to the sensor lever. Replace the sensor lever.
b. The horizontal registration assembly malfunctions because of the
presence of foreign matter. Remove the foreign matter.
c. The sensor is faulty and cannot detect home position. Replace the
sensor.
3. Horizontal registration motor, DC controller PCB
Is the horizontal registration motor control signal generated by the DC controller PCB?
J304-1/2: 24 V, J304-3/4/5/6: motor excitation signal
YES: The horizontal registration motor is faulty. Replace the motor.
NO: Replace the DC controller PCB. Usually E 051 is the horizonal motor problem, you can take out the pick up ***'y. On the motor have a small gear, sometime this gear broken.
Or the horizontal reg motor became stuck in the wrong position. I was able to manually move it back and rebooted copier. Not sure why the motor was in the wrong position-cust related?
Oct 10, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon Gp 335 E051
E051 indicates that the side or horizontal registration sensor is not detected try to switch off/on the machine but if the same error code display again thereis a small motor that drive the sensor assy should be change.try to move the sensor manualy by opening the upper right side peep inside you will see a long white plastic wth teeth push to this to right side hope this will help
Jul 17, 2009 | Canon imageRUNNER 400S Copier
051 code showing in gp 405
E051 indicates that the side registration sensor is not detected try to switch off/on the machine but if the same error code display again thre is a small motor that drive the sensor assy should be change.try to move the sensor manualy by opening the upper right side peep inside you will see a long white plastic wth teeth push to this to right side hope this will help
Jul 09, 2009 | Canon imageRUNNER 400S Copier
Cannon Imagerunner 2200 Error COde: E000051-0000
There is information in the Service Manual to fix this problem. Make a service call and get a technician to fix this problem.
E051 is Horizontal registration HP detection error
Main cause: The horizontal home position sensor is faulty. The horizontal registration
This problem should be handled by a technician.
Jul 03, 2009 | Canon (6981A002AA) for imagerunner 2200,...
CANON GP 405 ERROR E 051
My machine gave me an error E051 and it could not start. when i restarted, it still ended at that.
i decided to switch it off and wait for the technician to come and fix it.
the next morning i arrived before the technician came and when i switched on, it was very fine.
what could have happened.
Tonny Obwin Telecommunications engineer.
May 02, 2009 | Canon imageRUNNER 400S Copier
What is that eror code E000051-0000
E051-0000
because The horizontal home position sensor is faulty or the horizontal registration motor is faulty.
Dec 16, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Cannon Copier image Runner 400/330 series error 051
E 051 problem is registration horizontal position gear is broken. this gear seem to paper pick up deck back side. remove paper pick up deck and see one small moter and see small gear is there u change it u r problem is solved
Mar 21, 2008 | Canon imageRUNNER 210S Copier
Canon imageRUNNER 210S Copier Logo
1,224 people viewed this question
old marine
old marine
