Question about Canon PowerShot A530 Digital Camera
Lense error restart camera
My camera was dropped and now each time I turn the camera on it says lense error restart camera and thats what I do. I have restarted the camera in playback and each other setting and this still comes up. I am unsure of what I need to do.
  • wajidd3 Dec 16, 2008
    when im zooming the lense of the camera .. my lense got stucked and i got a messege on the screen that "lense error, Restart the camera". when im restarting im getting the same message .. give me the solution wat to do..
  • 477 Answers
A digital camera's lens is a very easy thing to have damaged. If the lens is bent some time you can force it in to the other direction and it will pop back into place. some times the gears get stripped and the lens then has to be replaced. I replace lenses all the time because of this issue. Hope this helps.
Posted on Apr 03, 2008
I drop my camera ixus 9515 canon
Before taking your camera to an authorized Canon repair shop try these procedures. If you need to contact Canon, start here.
Mar 26, 2013 | Canon Cameras
"lense error, restart camera"
on the camera bottom by the battery theres is a little niddle size reset button press it wit niddle when camera is on then it will restart to factory setting you can try more then ones pushing it.please leave comment,vote,note.thankyou
Sep 13, 2009 | Canon PowerShot A470 Digital Camera
Lens error, restart camera.How can I restart the camera IXUS 60?
Since the camera is locked after lens error, you will restart camera removing batteries.
If this does not help, then you are in one of the following conditions:
Lens error and lens does not retract.
Try helping lens gently back in while you turn off the camera holding the button at same time.
Lens error and lens do not extend.
Restart the camera , and try gently tapping the camera back with the palm of your hand whilst restarting camera at same time.
If that does not help, then one part on the camera lens assembly is broken or out of place, or dirt inside lens mechanism caused the fault.
The lens must be disassembled by a technician to fix the problem.
If the problem is not fixed swapping batteries and resetting, then the camera must be taken apart and tested by a technician.
Here you can get a quote on repair: Repair
Aug 22, 2009 | Canon Cameras
I dropped my camera in the sand and the lense won't close. When I turn it on it makes a buzzing sound and states ''Lense error, restart camera'' and then turns off.
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Aug 18, 2009 | Canon PowerShot SD1000 Digital Camera
Camera was dropped now it is saying that there is a lense error HELP!
My camera was dropped and now the lens will only detract half way. It says lens error and restart camera. It is a Cannon Power Shot SD1100 IS. Thanks.
Jul 13, 2009 | HP Photosmart M425 Digital Camera
How do you fix 'lens error restart camera' I put it in my bookbag. I guess i threw my bookbag around and now i have this "lens error, restart camera." The lens froze halfway and it's staying that way....
It sounds like. You really need to have some one take it apart and clean the sand out of it. The camera will make those noises when the sand gets between the gears of the lens assembly and they cant connect correctly.
ou could try helping the lens go back in GENTLY. But thats risky and you could ruin a lens that would work just fine if it where cleaned out.
let me know which model and brand you have and I could tell you better whether or not you should try anything your self.
goodluck,
Caleb
Jun 30, 2008 | Cameras
Lens Error, Restart
Hi
What you are seeing is a generic stuck lens error message, turning off the camera and turning it on again will not fix the lens unfortunately.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from....
Darntoothysam com
May 01, 2008 | Canon PowerShot SD1000 Digital Camera
Cannon Power shot SD630 Lens Problem
I had the same problem, tried different things but this is what worked.
I put the camera flat on its "back" (screen down, lens up). Looking down at the lens I could see that it was slightly off center. I pushed the lens towards the center and down, forcing it to close. Once it was centered I was able to turn it on and off no problem.
Sep 30, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot A530 Digital Camera Logo
169 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
