Question about Brother GX-6750 Typewriter
Replacement ribbon Can you tell me if the replacement ribbon needed for the GX 6750 is the BRT 1032 - the black nylon one??
    Scholar:
  • 132 Answers
This should confirm your question
Regards TC
Posted on Aug 19, 2008
SOURCE:
I replace new Ribbon but when i start typing theres now text appearing on the paper. That happens after i replace new one.
sounds like the printhammer isn't latched into place push forward on black lever in front of printwheel.
Feb 17, 2011 | Brother GX-6750 Typewriter
Installing new correction ribbon
Go to brother.com click on support a users manual is available there.
DickyO
Jan 18, 2010 | Brother GX-6750 Typewriter
MY BROTHER GX-6750 WILL NOT TYPE. YOU PRESS THE KEYS AND THE LITTLE "HAMMER" THAT HIT THE DAISY WHEEL WILL NOT MOVE. THE TAPE AND CORRECTION RIBBON ARE FINE. CAN THIS BE FIXED?
make sure the black lever on the right of the printhammer is all the way forward.
if it still doesn't work, it will need a trip to the repair shop, or just look for a cheap replacement at a thrift shop.
Nov 13, 2008 | Brother GX-6750 Typewriter
GX-6750
The ribbon doesn't advance at all? Try turning the ribbon by hand. If it is really hard to turn, or doesn't advance when you turn the knob (make sure you turn it in the direction of the arrow), then the ribbon is defective and you just need to get a good one.
If the ribbon turns easily, the leave the ribbon off, type and watch to see if the black knob on the left of the ribbon plate (the place where you put the ribbon), that turns the ribbon, is moving.
Also I have found that some brands of ribbons simply do not work on this machine. If the ribbon and the ribbon drive is working, try a different brand of ribbon.
Oct 22, 2008 | Brother GX-6750 Typewriter
Replaced ribbon and it wont print anything
Check to make sure the ribbon is between the two metal "fingers" and the metal cardholder. Also make sure the printwheel is latched forward by pushing forward on the black lever to the right of the printhammer. Turn the knob on the left side of the ribbon, in the direction of the arrow. It should turn fairly easy, if not, or turning it doesn't advance the ribbon, you may have a defective ribbon. If this doesn't cure the problem, you will need professional repair.
Sep 12, 2008 | Brother GX-6750 Typewriter
Ribbon/correction tape
Ribbons:
Correctable film - MODEL 1230 or 1030
Nylon - MODEL 1032
Multi Strike - MODEL 1031
Correction tape:
Lift-off - MODEL 3010 for use with correctable film ribbon & cover-up - MODEL 4010 for use with nylon ribbon and multi strike ribbon.
Aug 22, 2008 | Brother SX-4000 Typewriter
Correction ribbon
make it sure that the correcting ribbon correct insert to the guide of the ribbon push it then you feel lock , test correcting not jumping ribbon case , then ok.
Dec 11, 2007 | Brother GX-6750 Typewriter
Brother GX-6750 Typewriter Logo
130 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
