Question about Canon imageRUNNER C3200 Color Printer
Setting for printing evelopes on c 3200 canon
I trying to print evelopes and it will not take the size that i want to print it is one of the sizes that is in the system but it tells me the quides our set up incorrect but they are not
  • 1,219 Answers
See if there is any damadge in bypass rails or sensors
Posted on Jan 14, 2010
  • 149 Answers
You may need to calibrate the tray sensors again - you can find the tray size calibration in the service mode under 'feeder' and select 'manual tray' or 'bypass tray'. You really need a manual to configure the trays properly but you did not specify which machine you are referring to. Assuming you have a Canon search for your manual here
Posted on Jul 06, 2009
Canon IR1022if copier can't print in Legal size(8.5inx13in) using bypass or even paper cassettee
Did you trying hitting an Ok button, green button, etc to confirm legal size paper, maybe it wants you to confirm paper size. Also legal is 8.5x14, did you select legal or enter the size as a custom page?
May 22, 2014 | Canon IR1022IF 220-240 VOLT, 50/60HZ
Everytime i print something in a label sized setting it always cuts into short
Before printing try using print preview first and adjust yur settings from there. Or go into control panel select printers and reset to default settings, restart your computer and try again. Good luck.
Sep 09, 2012 | Canon IP2700 Inkjet Printer
When I print pictures on the 3210 HP all-in-one, they come out very small even though I choose the 4X6 in paper size for the photo tray. I've tried everything I can, but the pictures keep printing wallet...
First thing that comes to mind is that a 4x6" print could print four wallet sized photos; be shure your are not printing more than one copy.
If you are trying to print more than one,it will print the actual picure you have and leave space for the number of other nonexistent prints selected.
See page 75 of the Manual. for directions on how to set up photo printing.
If you have photoshop, you can resize your documents using the menu item, Image / Image size, (Alt + i then i again)
Set the resolution to 300, then the document size width to 6 or 10 inches.
This will guarantee that your document is full size, (though the printer should be able to resize it to fit on the page no matter what).
Give these a try. It's really a shot in the dark, but it's my best guess.
Cheers.
Richard.
Oct 13, 2009 | HP LaserJet 3200 All-In-One Printer
Printer printing blank evelopes ....everything else prints ok. Lexmark printer Z705
Check your setup in your envelope printing software, make sure it's set for the size envelope you're using, it might be printing in the air next to the envelope.
Sep 30, 2009 | Lexmark Z705 Inkjet Printer
My Canon imageRUNNER 2200 won't print envelopes. How can I get this function to work?
Put the evelopes in the bypass tray.As soon as you insert envelopes on the touch screen different papersize options will apear.Select the envelope size.Then you are set to copy or print on the envelope.
Sep 30, 2009 | Canon imageRUNNER 2200
HP Photosmart Premium c309a series will not print envelopes. I keep getting an error message that says paper mismatch. It doesn't matter what size envelope I put in, it always gives me an error message....
Try This :
Try printing from micrsoft word; Click on tools;
Click on Envelopes and Labels
Click on "OPTION"
Under the TAB Envelope Option you will get Evelope Size;
Scroll Down to the bottom you will get an option "Custom Size " Select it;
Set the accurate size of the envelope;
Click on Printing Options
Select the Feed method and make sure you do it the same way;
And then try to print this should resolve your Issue
otherwise let me know
Regards Soumajit
Sep 21, 2009 | HP Photosmart Premium C309A All-In-One...
Canon ir2200: data light comes on, nothing prints We have a Canon ir2200 installed as a local printer; no test page will print nor will a page sent from a program print, although the data light comes on,...
I would first try to see that your paper trays are set correctly. Meanning that the paper size are set to the same paper size in the tray. The knobs that input the paper size Magicly they move. Also, make sure that you clear out all the print jobs in the print "Q". Some body may have a odd paper size tring to print. Also, has anyone chaged anything on your network or the setting in the copier?
Mar 19, 2009 | Canon Office Equipment & Supplies
Small print size
Please try to reinstall the printer driver
And also try to use the printer properties in the printer menu and try to select the fit to page option
Jul 01, 2008 | Canon PIXMA MP470 All-in-One Printer
Printer problem
From the Printers & Faxes window, check in the i9950 Printing Preferences, Page Setup tab, for the following settings:
Page Size and Printer Paper Size are both set for the same size (both A4 or both A3).
Printing Type is set for Normal-size Printing
The graphic on the left should now show A4 (or A3) and Normal-size Printing in the legend.
Once that is set, verify from the application you're printing from that these settings are not being changed by the application (Preferences button in the print dialog box).
Jun 16, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
Canon imageRUNNER C3200 Color Printer Logo
160 people viewed this question
old marine
old marine
