Question about Mitsubishi VS-50605 50" Rear Projection Television
Red tinted picture
When the tv first comes on it has alot of static in picture, it clears up after a few minutes. The picture was red tinted and had a wave through the bottom of the screen. I replaced the convergence chips, the wave is gone. The picture is still red tinted and kinda dull, will not adjust. When I turn up the contrast or color tint it shows a green spot on the bottom right side of the screen like the green lamp is only projecting in that spot. Thanks in advance
  • 3 more comments
  • Perkspc Apr 03, 2008
    Model is a Mitsubushi VS-50VA1
    It seems to be some kind of color balance issue maybe.
    I do computer and appliance repair. I have electronic component repair schooling. AC/DC Classes. My problem is I am not very familiar with tv repair and if this is the symptom then I don't know to look in which area of the tv for the problem area. I know just enough about it to get me in this bind of having this tv apart and not knowing where to look next. I have repaired many tv's as far as bad caps, flybacks focus blocks, and convergence chips. Point me in the right direction for these symptoms. Thanks
  • Perkspc Apr 04, 2008
    Anyone
    I have noticed that on the convergence screen where it says "red", you can read the red text fine. When where it is supposed to say "blue", you can barely see the text word blue at all and what you do see of the word is blurred out. Thanks
  • 2,334 Answers
How old is your TV?
It looks like it could be CRT coolant is not clean, after a period of time this coolant inside the CRT creates fungus inside affecting the quality of the picture and colors as well.
Check this site to have a better idea on what to do.
Posted on Apr 04, 2008
  • Jaime Hernandez Apr 04, 2008
    I would suggest to do some reading from the link I sent you.
    I have fixed a good number of CRT with the same problems. The only problem is time consuming and not many techs like to do it, instead they change the whole CRT.
    The coolant inside become like dull and that affect the color focusing.
    Genius:
  • 1,665 Answers
You can download your service manual at link below
http://www.eserviceinfo.com/downloadsm/19913/mitsubishi_vs-50605.html
  • 563 Answers
Check if the LCD's are all in working order
    Genius:
  • 3,587 Answers
How techically inclined are you to do this level of troubleshooting?
Posted on Apr 03, 2008
    Genius:
  • 3,422 Answers
HI,
Try reseting the TV first by unpluging all the cords for 4hrs and then plug it back.
I will be posting more troubleshooting steps..
  • 2 more comments
  • Priya darshan Apr 03, 2008
    ONE: Check the line cord. Wiggle both ends near the molded part.
    TWO: Make sure you have power in the outlet by plugging a lamp into the same exact outlet.
    THREE:The whacking test is to just bang or smack the set with your hand
    on the back, side, top, etc., to see if there are loose connections or
    cold solder joints inside that are acting up. If so, the banging should
    knock them back to normal and the set should restore. You might have
    to use some creative banging and some have had to put a book or
    magazine under one corner to torque the chassis enough to get it to
    work reliably.
    Check the video input to the CRT video driver board and signals on that board.
    If B/W picture is also bad, then you can compare red and green signals
    to determine where they are becoming different. The red lines in your
    description sounds like the red video output circuit is drifting and messing
    up the background level, blanking, screen, or other setting. Could be a
    capacitor or other component.
    Where only one color is showing, suspect an incorrectly adjusted individual
    background/bias control or bad part on the CRT neck board for that color.
    • Individual brightness/background/bias control(s) - mark setting of pot for
      the problem color and then see if a slight adjustment removes the retrace
      lines. See the chapter: "TV Adjustments". Of course, if this happened
      suddenly, the problem is not due to a misadjusted control though a dirty
      pot is possible - turn it back and forth - this might clean it and restore
      normal operation.
    • Component or connection on CRT neck board - insufficient voltage to or
      incorrect biasing of the video driver for this color can result in the
      CRT never totally blanking. Compare voltages and signals, and swap
      components between good and bad channels to confirm.
    • Blanking circuit - this may be a part of the video/chroma chip or separate.
      Check and compare waveforms of good and bad colors to determine if the
      blanking pulses are making it to the video output.
    There is a slight possibility that a bad CRT may result in visible retrace
    lines. To eliminate this possibility:
    • Disconnect the filament - all evidence of a picture, raster, and retrace
      lines should disappear once the filaments/cathodes have cooled (15 seconds
      or so. If there are still visible retrace lines, the CRT is suffering
      from cold or field emission from someplace (may not even be the cathode).
    • Turn down the screen control on the flyback (usually). If one color
      remains no matter how you set the control, again there is some kind of
      weird emission from the CRT. However, if white/gray retrace lines remain,
      the problem may be in the screen supply.
    I hope all this info. is sufficient for you.
    Goodluck,
    Please don't forget to rate the solution.
Samsung Ln52a650A1fxza lcd has a red tint when I turn it on. This red tint disappears usually disappears after about 10-30 minutes, then the T.V displays a normal picture. There are times when I turn the...
Check the LVDS cable !!! It is the cable that supplies the video signal from the main board to the LCD controller. If wiggling the cable clears up the problem or invokes the problem, you need a new LVDS cable!
Oct 18, 2013 | Samsung LN46A650 46 in. LCD HDTV
Red tint on PROTON TV picture
did u go through the menu and check for the contrast and tints?
Mar 03, 2012 | Proton NT-333 31" TV
Video is taking on a red tint which is getting worse over time
check the cable connections. look at different inputs. VGA and Component cables have the colors split, so if it's turning red, green, or blue; it's likely a cable or connector.
Dec 29, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Mitsubishi tv model wd 73727 and how to take tv apart to clean marrow
my mitsubishi 73" set is 4+ years old. all of a sudden the color is all wrong. after a couple of minutes of clear picture the colors change--blue is green and red is yellow. a little while later everything has a red tint to it and there is a line going down the center of the screen. to the left the picture is still relatively sharp, but the right hand side is terrible. I'm hoping this is just the lamp.
Rick
Woodland Hills, Cal.
Apr 12, 2009 | Televison & Video
RED TINT
yOUR CRTS ARE SHOWING THE SIGHNS OF WEAR. ON THE FRONT OF THE SET BEHIND THE SPEAKER GRILL OR FRONT FACIAL. THERE ARE 6 CONTROLS 3 FOR SCREEN RED GREEN AND BLUE AND 3 FOR FOCUS RED GREEN AND BLUE. YOU CAN TRY TURNING THE RED SCREEN DRIVE CONTRIL COUNTER CLOCK WISE. JUST A VERY LITTLE BIT.
Jan 22, 2009 | Televison & Video
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Red tint on screen
Good Day,
Try resetting the TV by unplugging from wall outlet for 3 to5 minutes then plug back in. If no fixya take front grill off and panel and adjust the screen controls, turn color off adjust for Black & White Picture. Good Luck, big IRISH.
Sep 13, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Connect desktop PC w/ DVI and get a red screen
Fixed my own problem lol. Video card needs to be replaced.
Apr 25, 2008 | Protron PLTV-32 Television
Sylvania 27 inch stereo flat screen tv
This problem sounds like a short inside the picture tube itself unless a driver transistor failed that drives the red gun in the CRT. You may have to take it to an authorized repair facility if the picture tube is still in warranty.
Nov 10, 2007 | Sylvania 6427FF TV
Mitsubishi VS-50605 50" Rear Projection Television Logo
195 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
