Question about Refrigerators
CAN I UNPLUG MY FRIG WHILE IM OUT OF TOWN FOR 6MO.
  • 552 Answers
Yes, if nothing is in it, but let me caution you about leaving the door closed when your are gone. If you do, then you may have mold and mildew when you get back.
It is best to leave the door open.
Posted on Apr 03, 2008
SOURCE:
APS 912 worked for about 6mo - 1yr. Used with a
Sorry this is what the industry refers to as a throw away.
Sep 12, 2011 | Tripp Lite Lite APS INT 912 UPS System
Want to attach a water filter. no filter came with the frig/freezer
G E does have a add on filter . ( its in line and works with a 1/4 palstic or copper ) very easy to install just cut the line ( make it a true 90 deg and just plug it in / good for 6mo or about 2000 gal . takes care of taste and other minerials . hope this helped mm ..
Oct 16, 2010 | GE Profile 25.5 Cu. Ft. Side-by-Side...
Unit stopped running. T-stat just makes a clicking sound
Are you sure its the thermostat that is clicking and not the compressor. IF the click is comming from inside the frig it is the thermostat, but if its comming from the rear of the frig its the compressor.
If its the thermostat thats clicking you can unplug the frig and remove the thermostat and jump the two wires together and plug the frig back in to see of the compressor comes on. If it comes on, replace the thermostat.
If it doesn't come on check to see if you have current to the compressor. If no power to the compressor check to see of the frig is stuck in defrost. Locate the defrost timer and advance one click and observe if the frig comes on. If the frig comes on at this point replace the defrost timer.
Dec 29, 2009 | Refrigerators
Same as the rest. Handle broke off after 6mo of use!! POS!!
Call and get it fixed under warranty, and don't get no for an answer (worked for me).
Aug 30, 2009 | Samsung 1.8 Cu. Ft. Over-the-Range...
GE Profile side by side freezing everything
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=219577
thats what you need its not that hard to put together
thats the kit that allows air into the fridge and its allowing too much, before you order this  go to the back of the fridge and take off the silver panel  with about 10 screws take off the control board take off the wires and it has clips on each corner of the board get needle nose pliers and squeeze the white plastic that extends out of the clips and pull the board towards you got to do that for all 4 corners once you do that check on the back of the board for black smudges and burning smell if there is significant black smudge or burning smell you need to oder that but im 97% sure you need the inlet assembly
its located in the middle upper part of your fridge
Jun 08, 2009 | GE Profile PSS26NGS Side by Side...
Run frige when not in FL or turn off?
Empty it out totally and unplug it. Prop the doors open to allow air flow. Leave town happily.
May 06, 2009 | Refrigerators
IF I UNPLUG MY FRIG FOR 6MO.WIIL IT CAUSE PROBLEMS
hi
i personally think that it would be a problem all you have to do is clean it thoroughly
Apr 03, 2008 | Refrigerators
Freezer works like frig-freezer lite only one working
ch the fan in the frige feel it if is blowing air .or is slow. you need to replace the fan moter.
Feb 06, 2008 | LG LSC26905TT Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
