Question about Refrigerators
IF I UNPLUG MY FRIG FOR 6MO.WIIL IT CAUSE PROBLEMS
  • 25 Answers
Hi
i personally think that it would be a problem all you have to do is clean it thoroughly
Posted on Apr 03, 2008
SOURCE:
ALARM WONT STOP BEEPING
unplug it let it set for 5 mins then plug it back up hope this helps. if it continues then there is a problem with the frig that needs to be repaired. find out what's happening to cause the alarm. is it cooling? is it defrosting? what's up with the frig?
Aug 24, 2014 | Hotpoint Refrigerators
Wiil the engine light come on if i'm low on oil?
Somehow, I get the feeling that you might have some severe problems with your vehicle. The check engine light can come on for all kinds of engine problems and engine control system failures. Why do you ask?
Apr 27, 2012 | 1998 Toyota Corolla
Turns over ok wont start.ran ok last night this morning wont start. new clutch last night and brake lines.
While doing the clutch you more than likely unplug the fuel pump wiring harness or the crankshaft sensor and this wiil cause the truck not to start. Check under the truck for a unplugged wiring harness and reconnect it and I am sure your truck will start.
Apr 20, 2011 | 2002 GMC Sierra
Want to attach a water filter. no filter came with the frig/freezer
G E does have a add on filter . ( its in line and works with a 1/4 palstic or copper ) very easy to install just cut the line ( make it a true 90 deg and just plug it in / good for 6mo or about 2000 gal . takes care of taste and other minerials . hope this helped mm ..
Oct 16, 2010 | GE Profile 25.5 Cu. Ft. Side-by-Side...
My frig is running but not cooling - frig is 50 degrees,freezer 40 degrees, cleaned the coils,etc GE side by side coils in bottom if frig side feel cool, "box" between freezer and frig side is not blowing...
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Jan 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
OK, here's the problem - Samsung model RB1955SH - plug refrig in it cools both frig and freezer to desired settings - however, once system reaches stttings and turns off compressor, will not restart system...
the temp controller is bad in the fridge once it reaches cooling temp desired it cause the temp comtroller to go into a shut off mode due to being weak on the temp sensor tube
Jan 18, 2010 | Refrigerators
Same as the rest. Handle broke off after 6mo of use!! POS!!
Call and get it fixed under warranty, and don't get no for an answer (worked for me).
Aug 30, 2009 | Samsung 1.8 Cu. Ft. Over-the-Range...
My samsung i760 wiil not sync today. i run windows xp and have microsoft active sync 4.5. the pc connects to the phone but sync wiil not proceed.
Try to unplug the usb cable or the sinc cable and wait a few seconds and then plug it back in, be patient...If that don't work reboot the computer. Good Luck and don't get too frustrated.
Feb 14, 2009 | Lands Phones
CAN I UNPLUG MY FRIG WHILE IM OUT OF TOWN FOR 6MO.
Yes, if nothing is in it, but let me caution you about leaving the door closed when your are gone. If you do, then you may have mold and mildew when you get back.
It is best to leave the door open.
Apr 03, 2008 | Refrigerators
Frig and feezer stopped working
It sounds like the overload and relay on the compressor.If the problem isn't that then you need a compressor.
Eeggman
Nov 07, 2007 | GE GDS20KBS Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
