Question about ViewSonic VX900 19" LCD Monitor
I can not see nothing from the computer
The green light is on, if the computer is on, and yellow, if the compu is off,
if i push #1 menu appear.Help to fix this.
  • Tribilin Apr 07, 2008
    Mi vga card and my pc are working perfect with my old monitor,only this happen with the vx 900 lcd monitor
    New Friend:
    Problem Solver:
  • 6 Answers
Try to check first ur pc,matbe trhe vga card oe memory
Posted on Apr 04, 2008
SOURCE:
Su pregunta: "no puedo decscargar mis fotos desde el samsung GTE2121L en el cel aparece como conectado a la compu, pero en la compu sale que no tiene el controlador o no lo reconoce,que debo hace ?,ya
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Mar 27, 2012 | Computers & Internet
Power light green, but turns on for a second says 'Resuming Windows' and then screen goes black and nothing else happens. Power light still green and another light green with a padlock and number 1 in...
It sounds like windows may be stuck. While turning you laptop on hold down the f8 key. You should get a text menu appear after a few seconds. Select start windows normally and this should fix the problem.
Incidently Asus PCs have an issue with windows hibernation. If you know ho you should disable this feature, if your not sure how to do it, leave me a comment and i'll walk you through it.
#Please take a moment to rate my solution.
Thanks.
Simon.
Rytech Computer Services Limited
Nov 23, 2009 | ASUS Computers & Internet
Canon ip1800 printer not working
when the yellow led flashes is never a good signal... you should check the manual's printer to find out the error code meaning "4 yellow flashes and 1 green)
Usally it's the waste tank that is full, in this case you need to:
  1. Push “resume” for 5 seconds for canon IPXXXX.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Jul 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
My aopen f2925 monitor has a green tint.
The solution: hidden menu within the main menu itself. Hold the Menu button down while pressing Power to power on, and release power button only when the screen comes up, still holding the menu button. The menu will appear and there will now be a hidden selection, "Auto Color", printed in a red-on-black font at the bottom of the menu. Use the +/- buttons to access it, and press Menu. My green/yellow tint went away! Now my picture works great, and the setting lasts through Auto-Adjusts and Resets!
Apr 08, 2009 | AOpen F70PS 17" Flat Panel LCD Monitor
Turn power on with a steady green light but nothing appears
Try it on another TV if nothing shows up then your PS3 or the video plug is broken.
Feb 21, 2009 | Sony Playstation 3 (PS3) Console
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Monitor w2gen mg15vt
I had a somewhat similar problem. Mine was still under warranty. bad news is that x2gens parent company just filed for chapter 11. which is why their RMA website is unresponsive. I bought mine through a 3rd party retailer who refunded the entire purchase price of the monitor. HELL YEAH! Good luck unloading all ur x2gen stuff when it craps out cuz all warranties are essentially useless now.
Dec 18, 2007 | X2Gen MG15VT 15" LCD Monitor
ACER ORBI CAM
Does the camera still work without the green light?
Nov 26, 2007 | Acer Aspire 5100 Notebook
Toshiba Satellite A15-S129 PC Notebook will not turn on
I have the same problem. What I have found with mine is that if I can get the battery to take just a little charge then I can get it up and running. Here is how I do it. Disconnect AC power leave the battery in and start the laptop. As soon as thing start to run I plug the AC back in and it works fine from there on. Now mine is flashing as well now and I have a dead battery and it will not restart. Something I have noticed thought is it appears that the yellow light is blinking a code. This is what I have come up with. I appears to be flashing 323 as the code or could be 2 shorts 1 long then 2 shorts and then 3 shorts.
Anyone know where to find info on these flashing codes.
Thanks
Oct 30, 2007 | Toshiba Satellite A15-S129 Notebook
ViewSonic VX900 19" LCD Monitor Logo
29 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
