Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Buttons Can anyone tell me the part number for or how to get the button cover for the keyboard assay for this tv. The buttons on the tv have been ripped out. it would be awesome if you could help me... Thank you.
  • Kaiden54 Apr 04, 2008
    Thank you but what is the part specifically called cuz i can't find the part number and i don't know the real name for the part
    Genius:
  • 1,153 Answers
Vancebaldwin.com
Posted on Apr 03, 2008
My lenovo g530 laptop keyboard u,i,o,j,k,l buttons is not working properly if i am pressing those buttons 1,2,3,4,5,6 numbers is coming how to solve
you have numlock enabled which makes those numbers come instead, turn off numlock on your keyboard. please read your usermanual on how to use the keyboard to turn off numlock. it is a numlock button or a combination of buttons that needs to be pressed.
Jun 30, 2012 | Lenovo Computers & Internet
Samsung lcd tv can't find a source, buttons on remote control don't respond, nor buttons on the control panel on the right side of the TV device
consult the owner manual or call Samsung---this set likely has a lockout feature that locks both the remote and the keyboard out.
You might also want to research this by taking the model number and Google key words "remote lockout" etc.
Jun 01, 2012 | Samsung Televison & Video
Prgram old RCA removte
I also have an early RCA universal remote with the number 97P04730 stamped on the battery cover. I do know if that is the part number for the remote. There are buttons labelled TV and VCR, presumably to select which device the buttons will work for. This remote has a "search" button, but no "code search" button that is found on later RCA remotes. I have spend several hours searching the net for any information on this device. The only thing I found was a post that claimed this early remote is programmed by pressing and holding the device button (TV or VCR) and simultaneously entering the device code. Because this is a very old remote, it probably uses 3 digit codes. There are several places that list RCA 3 digit remote codes. I have tried to program mine this way, but I have not been successful. Possibly my remote is not working correctly, but it is putting out IR.
Jan 29, 2012 | RCA Universal Remote Control
Advent t9307 power switch not working
Your laptop's power button sits directly on top of a device called a power button board. This is a small circuit board where all power and control buttons interface with your laptop's motherboard. The repetitive use of the power and control buttons can damage the power button board. Repairing your power button means removing and replacing the power button board, which requires partial disassembly of your laptop.
1.Power down your laptop. Unplug the AC power adapter and all external devices from the computer. Close the laptop's LCD panel and place the laptop face down. Rotate the laptop so the front opening edge is facing you. Remove the battery pack from its compartment on the laptop's bottom side.
2.Flip the laptop over, and pull open the display panel as far as possible. Use a thin, flat-head screwdriver to pry the keyboard cover from the laptop. The keyboard cover is the plastic piece situated above the keyboard assembly that houses the power button board.
3.Lift the keyboard cover out of the laptop slightly, and disconnect the cables extending from the power button board to the motherboard. Remove the keyboard cover from the laptop.
4.Place the keyboard cover face down on a flat surface. Remove the Phillips-head screws fastening the power button board to the cover, and remove it. If your speakers are situated inside the keyboard cover, disconnect the speaker cables from the power button board before removing it.
5.Place the new power button board inside the keyboard cover. Align the screw holes on the button board with the holes on the keyboard cover. Replace the Phillips-head screws fastening the button board to the keyboard cover. Reconnect the speaker cables to the button board, if necessary.
6.Reconnect the power button board's main cable to the motherboard. Place the keyboard cover back inside the slot above the keyboard assembly. Press down on the cover until it snaps into place. Replace the battery pack and reconnect all cables.
Sep 06, 2011 | Computers & Internet
Have lost manual for aToshiba 2173DB can anyone help,need 2 search for channels but have lost remote,can anyone tell me if they can sort it by just using the tv buttons thank u
usually you can hit menu button. The channel buttons will move highlighted part up and down, and volume up is the select. Hopefully that helps you out.
Mar 11, 2010 | Toshiba Televison & Video
How do i turn it on?
  • If you have the TV Code listing, first set up:
  • Slide the TV/WebTV switch to TV.
  • Find the brand of your TV
  • Press the Code Set button.
  • Use the Number buttons to enter the three-digit code for your brand of TV.
  • Press the return button.
  • Slide the TV/WebTV switch back to WebTV.
To see if the keyboard operates your TV, press the Power (TV) button. If the TV turns on or off, the Keyboard successfully operates the TV. Hope this helps.
Jul 16, 2009 | Philips MWK122BK Wireless WebTV Keyboard
Black buttons under plastic shielf at top of keyboard. ? r they?
i would guess those to be a media player control set of buttons.without you supplying important info as to the model number im not cetain., as i say its only a guess
Jul 09, 2009 | Compaq Keyboard
32" Samsung LCD HD ready TV buttons & remote malfunction
seems like your remote is getting bad and also a keyboard control board from the TV,
whats the model number?? maybe I can give you the part numbers for it
Apr 21, 2009 | Samsung 32 in. LCD Monitor TV
I need to install a keyboard for a Dell Inspiron 1525. I need step by step directions
Before you begin, Follow these steps carefully;
  1. Shut Down to turn off your computer. Ensure that the computer is off and not in a power management mode. If you cannot shut down the computer using the operating system, press and hold the power button for 4 seconds.
  2. Disconnect your computer and all attached devices from their electrical outlets. Disconnect any telephone or network cables from the computer
  3. Remove any installed cards from the ExpressCard slot.
  4. To help prevent damage to the system board, you must remove the battery from the battery bay before you service the computer. to do this, Turn the computer over, Slide the battery release latch until they click into place. Slide the battery out of the battery bay.
  5. Turn the computer top-side up, open the display, and press the power button to ground the system board. Now you are ready to remove your Keyboard;
  6. Removing the Center Control Cover, Remove the two screws securing the center control cover from the battery bay,
  7. Turn the computer top side up, and open the display as far as it will open.
  8. Insert a plastic scribe into the indent to lift the center control cover on the right side and ease the center control cover up.
  9. Disconnect the cable from the media control buttons connector located underneath the center control cover. NOTICE: To avoid damage to the data cable connected to the system board, ensure that you do not pull hard when you are raising the center control cover. NOTICE: To avoid damage to the center control cover, do not lift the cover on both sides simultaneously.
  10. Remove the center control cover.
  11. Remove the two screws at the top of the keyboard. NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard.
  12. Lift the keyboard and hold it up and slightly forward to access to the media control buttons connector.
  13. Disconnect the media control buttons connector and remove the media control buttons cable.
  14. Lift the keyboard and hold it up and slightly forward to access to the keyboard connector.
  15. To disconnect the keyboard cable from the keyboard connector on the system board, rotate the keyboard connector latch toward the front of the computer.
  16. Slide the keyboard cable out of the keyboard connector.
  17. Replacing the Keyboard
    1. Slide the keyboard cable into the keyboard connector.
    2. Rotate the keyboard connector latch to secure the cable.
    3. Align the tabs along the bottom of the keyboard and slide them under the palm rest.
    4. Press on the right edge near the top to snap the keyboard into place.
    5. Replace the two screws on the top of the keyboard.
  18. Replacing the Center Control Cover
    1. Reconnect the media control buttons cable to the connector below the keyboard.
    2. Align the tabs along the bottom of the keyboard and slide them under the palm rest.
    3. Press on the right edge near the top to snap the keyboard into place.
    4. Replace the two screws on the top of the keyboard.
    5. Reconnect the media control buttons connector to the center control cover.
    6. Insert the left edge of the center control cover.
    7. Press from left to right until the cover snaps into place.
    8. In the battery bay, replace the two screws that secure the center control cover.
Apr 17, 2009 | Dell Inspiron 1525 Laptop Jet Black
S-video for the Acer Aspire 5520-- model# ICW50
you should have a button on your keyboard probably in blue called Fn. once you press this you need to press the screen tab button on the keyboard that corresponds to the screen. This is usually present on one of the function buttons from F1 to F9.
Sep 30, 2008 | Acer TravelMate 2300 Notebook
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
41 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
