Question about Microwave Ovens
I have a downdraft ventilation system Best by Broan that does not raise when switched I believe it got stuck and the gears may have been stripped. Would like to know my options or at least see some schematics to effect a repair. The Model #DD61 that is about 9 years old. Can you help? Bill
  • 552 Answers
The Broan Best unit is older but if you call this number you will get the technicians there who can tell you what parts are available.
1-800-637-1453
Posted on Apr 03, 2008
SOURCE:
Aeg micromat 153e
You rather have a bad turntable motor or a stripped turntable coupling.
Jun 22, 2014 | AEG Microwave Ovens
I bought a KitchenAid 24" microwave oven and trim kit.to replace an old KitchenAid 24" oven. The old oven set on the built-in shelf with a stainless steel trim panel around the oven to trim the cut-out. ...
As long as there is ventilation at the back and somewhere for the air to come out go ahead and use you imagination to make the trim kit look good to the eye. Making those tough decisions is what installers do.
Oct 17, 2013 | KitchenAid Microwave Ovens
My microwave is rotating clockwise and is making a loud clicking sound. It was working ok until last week.
most modern units the table is driven by a gear unit with a motor, likely you have some problem with the gear drive---stripped gears etc.
Not in many models easy to get at or even get the parts.
Dec 20, 2012 | Microwave Ovens
Need a wiring diagram for the kitchenaid downdraft-/motor control switches
We have many of these schematics, but we would need the full model number with any suffix in order to provide you with free assistance.
It is usually found on a tag located inside the cooking cavity or around the door frame or controller frame.
Since FixYa is still not notifying us when you respond to clarification requests, you will have to post a new help request with your model number and symptoms / questions.
Or feel free to contact us directly here for free help.
Sep 16, 2011 | KitchenAid Microwave Ovens
Kitchen aid model 45sm50pwh stopped working - sound like a drive belt off or gear stripped or ?? In order to dismantle, I believe I need to drive the pin holding the mixer part (?) under which there are a...
Hi and welcome to FixYa, I am Kelly.
You need to download and peruse this manual:
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
See page 6 about removing the pin (figure 4) and planetary access bottom of the page and page 7.
There is yet another pin that must be removed on page 7, figure 6 to get the gear case cover off.
The manual is loaded with all the information you should need to inspect and repair your mixer.
Thanks for choosing FixYa,
Kelly
Apr 24, 2011 | Microwave Ovens
Plastic drive from the worm gear are stripped. I need to order new drive gears.
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Dec 24, 2010 | Microwave Ovens
I have come down to find my aga cooker out the fire has gone out. There is oil around the burner but I can see no reason why it has gone out. Any suggestsions?
Much better than a microwave, any day!
It is quite common, if the fuel tank is not checked yearly, that condensation may build up in the fuel line and finish up with water in the fuel, causing the problem you describe. Also a sharp downdraft from the chimney can blow the pilot flame out.
Make sure it is cleaned before you re-light it. Preferably get the system serviced.
Hope this helps.
Oct 29, 2010 | Microwave Ovens
Does stove-top need downdraft if microwave has oven-hood combo?
We have a stove with no downdraft, and a microwave with a hood above it. It works just fine. I expect you could keep your downdraft and put a microwave without a hood above it, and that would also work. I don't think, however, you can buy an above the range mocrowave oven, that slides in on brackets, which will not have a hood.
Jan 08, 2009 | Microwave Ovens
GE Spacemaker microwave. Turntable does not turn.
First you need to see if it is the motor that is bad. Usually you find the relay or switch that powers the motor and see if you have voltage.
The motor just slides up into the bottom of the brown plastic star thing (gear) that you see from inside your oven cavity (on which you put the turntable plate). It could be melted together or just stuck with whatever fluid that may have spilled over .
It's good you want to fix it, but microwaves are better left to professionals. A novice could hurt themselves working on a microwave.
Best get a qualified professional to take a look, or get a new oven (whichever works out cheaper for you).
May 22, 2008 | GE Microwave Ovens
Microwave Ovens Logo
219 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
