Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Stk's Where can you get the STK392-150. I had two replaced a year ago and the tv is doing the same thing again, I had the 180's put in though.. Are they easy to replace?
  • 58 Answers
If you are good at soldering and desoldering then you can do it. I get the 150's from vance baldwin. Good luck
Posted on Apr 03, 2008
Hi. On my sony 57in. tv i am getting red arched lines over the entire screen, and double images. 5 years ago i had a similar ocurrence and the tech changed a module. What is the cause ? and why again so...
2 Things can cause this Red Tube needs to be adjust down on screen drive control or you need to replace Both of your STK ICS. Sony has alot of problems with Defective Tubes.Red and Blue Shorted out the most.
Mar 24, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
The convergence going bad again on my Hitachi 51swx20b
Sounds like loose solder on the chips. Either that or they are failing. You can save money next time by doing it yourself with a kit from www.TvRepairKits.com
Jan 10, 2010 | Hitachi 51SWX20B 51" Rear Projection...
Proscan 61700 chassis ptk195 ft
There are two STK on conv. board, even if they are not 392-180.
To know if the STK are the problem, test the pico fuses at base for continuity.
Replacing STKs require a precision soldering job, using thermal compound and taking care not to damage C board. This is not a job for beginners, and should be done by an experienced technician.
Here is how an stk looks like:
Mounted:
Dec 28, 2008 | Proscan PS61700 60 in. Rear Projection...
Stk divergent chips
That series usually used the STK 392-110.
It has been upgraded to the STK 392-180. 2 of them.
Mr Bob
www.imageperfection.com
May 11, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Panasonic pt-53tw53 convergence
It looks more like an open solder because you were able to align it properly after replacing the STK ICs, if there was an open resistor(s) you would not be able to get it align.
I would suggest to go back and double check the solder joints on the STK ICs as well add some fresh solder to the resistors nearby the stk392-180.
Good Luck.
Apr 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Red shadow line
you need 2 convergence IC's this is an easy repair take the back off your tv and they are on the right hand side of the board mounted to the heat sinks check your ic's for the stk numbers it will either be STK392-010 OR STK392-040 you will need 2 of them I will post you a link where you can get replacement ic's as well as free online tech support and installation instructions with pictures for reasonable price
http://servicemanuals.vstore.ca/
Apr 22, 2008 | Samsung HCM5525W 55" Rear Projection...
Pioneer 610HD Rear Projection
Check all solder joints on the deflection board.
Dec 10, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Convergence problem
That unit has a convergence repair kit that should fix most problems. Order it directly from Hitachi p/n# X480295. It contains: Rk42 3.3 Ohm 1w Rk46 1.8 Ohm 1w Rk50 3.3 Ohm 1w Rk54 1.8 Ohm 1w Rk58 3.9 Ohm 1w Rk62 2.2 Ohm 1w Ik04 Stk392-150 Ik05 Stk392-150 And I would strongly recommend testing all the resistors in that circuit for change in value. Are you using a good heat sink compound on the STK's when you installed them? That and ordering the japanese knock-offs for STK's are the two most common critical mistakes made. Originally that unit had two STK392-110's for conv. amps. Even Hitachi recommends subbing to a STK392-150 or 180 for greater reliability. You do realize that for the cost you have after two failed attempts you probably could have taken this to a reputable shop and watching the ball games now. :) (no disrespect intended) Good Luck! Bill
Jun 01, 2007 | Hitachi 53UDX10B 53" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
35 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
