Question about ViewSonic NextVision N3260W 32 in. HD-Ready LCD Television
Will not turn on and is not fuse
Please help ive checked every board, but im overlooking something with multi meter and visual am i missing somethingh
  • Anonymous Apr 07, 2008
    There is two 1000 uF 35V elconds in the power supply. In my case they must be replaced because they have overheated and blown out. Something else could also be destroyed at the same time. I will see if changing elcods will solve the lack of power, not totally without picture, just flickering 25 Hz or something like that.
  • Ted Roebuck Apr 18, 2008
    im going to try these suggestions and i want to THANK YOU ALL for answering so quickley
    sincerlly
    robuk1963
Replaced the two electrolyte capacitors one week ago. Everything seems to work normally again. No more actions required.
Posted on Apr 17, 2008
Cap blew on power supply these tv's have the same problem.
SOURCE:
I have a Sanyo DP50747. The screen just went black. I think it should be something fairly simple I just need to figure out what parts i need. Any help would be great
Could be the main board, power board or Tcon board, take your pick...only way to isolate what one is bad is use a multi meter and test the various power supply voltages and see what is missing or out of tolerance.
Jan 31, 2018 | Sanyo Televison & Video
My KVH 6hp keeps blowing fuses on the circuit board and won't search, voltage good, no blockage, it used to vibrate excessively. Now won't move at all just blows fuses.
You have a short somewhere on the board. Try isolating parts of the board by unplugging harnesses one at a time until the fuses stop blowing. Eventually you may pinpoint the location of the short. Visually inspect the board with a magnifying glass to see if any components are touching or are broken. You may need to use a multi meter to test some components that are not visual shorts. Good luck!
Feb 29, 2016 | Cars & Trucks
My oven will not get hot
1.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Jun 18, 2014 | Frigidaire Ovens
Electric oven not heating
THINGS TO CHECK:
the broil element
The bake element
Jun 15, 2014 | Frigidaire FFEW2725LB Oven
Oven no heat
THINGS TO CHECK:
the broil element
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
May 13, 2014 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire oven
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
THINGS TO CHECK:
the broil element
The bake element
Apr 07, 2014 | Frigidaire Ovens
My frigidaire electric range model ES100 oven wont heat. everything else works and lights up but no heat in oven
THINGS TO CHECK:
the broil element
The bake element
Apr 06, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Top oven/grill not working
2.
THINGS TO CHECK:
the broil element
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Dec 12, 2013 | Belling XOU482 Electric Double Oven
1988 Dodge Omni no dash board lights
Hi Beverly,looked everywhere for a diagram to your fuse box with no luck,if your able to afford a repair manual here is a link,I have one to each of my trucks.
Dec 07, 2013 | Jeep Cars & Trucks
I have a new '65 Deluxe reverb Reissue Fender Tube Amp and I'm not getting power to the amp after I plug it in and turn it on. Ive checked other things in the outlet and they work, so it is not the outlet....
If you have power and a good connection to the guitar, don't take it apart - take it back. It has a warranty and any reputable dealer will give you another one - just ask for a test before leaving the store/shop.
Sep 11, 2009 | Fender Audio Players & Recorders
ViewSonic NextVision N3260W 32 in. HD-Ready LCD Television Logo
336 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
