Silicone Oil refill
How do I replace the silicone oil in a gestetner dsc232? Where does it go?
  • 87 Answers
There is a door on the back cover. It is located on the lower right hand side. Take a quarter, and turn the screw until the door comes off. Inside is a tank, that you fill with the proper silicone oil.
Posted on Apr 03, 2008
Need to replace transmission pan gasket.
1) Drain the fluid.2) Remove all oil pan screws around the exterior.3) Pull down oil pan.4) Remove old gasket.5) Clean both mating surfaces.
6) Take the opportunity to replace any gearbox oil filter within.
7) Refit new gasket with silicone sealant on both sides (I prefer 'Three Bond')
8) Refit screws, tightening several times all the way around until snug.
9) Refill with fresh oil.
Nov 12, 2012 | 1996 Chevrolet Cavalier
Oil has gotten to my stater and has ran out of the stater plug, How can I fix it
If it is just leaking a little, remove the primary cover. Push the stator plug into the primary housing. Clean the plug and hole it goes into with brake cleaner. Apply black silicone to the outside of the stator plug and push back into the hole. Replace the primary cover, and after the silicone is dry, refill the primary. If oil is leaking alot, and the bike is a Twin Cam, check to make sure vent hose on the trans top cover isn't plugged. Twin Cam primaries vent through the trans and if the vent hose is plugged, oil will be under pressure in the primary and force itself out around the stator plug.
Jul 31, 2012 | Harley Davidson FLHR-FLHRI Road king...
How to replace the oil pan gasket?
Drain oil, remove oil pan bolts, drop pan, scrape remnants of old gasket off, attach new gasket to pain using silicone gasket sealer (Permatex) and reinstall & refill w/oil. Some applications require loosening motor mounts and raising engine a couple of inches to clear cross members.
Apr 04, 2011 | 2000 Ford F350 Super Duty Super Cab
The oil pan is leaking from its seal
Drain oil remove appx, 20 bolts from arround pan remove and replace gasket, Make sure you get all of the old gasket off. And use a high tempiture silicone when replacing gasket onto pan place hew gasket onto silicone let set appx 15 min Also place some of your silicone onto your engine block where the pan fit's up to. When tighting bolts do not over tight, this will damage your pans smoothness. Good luck.
Apr 01, 2011 | Chevrolet Suburban 1500 Cars & Trucks
Changing a sump on Jetta IV
You need VW silicone sealant D 176 404 A2.
  • Apply 2 to 3mm (1/8") bead of new sealant to oil pan sealing surface. Be sure to run bead on the inside of the bolt holes.
  • Immediately install oil pan to cylinder block and loosely install M7 bolts diagonally.
  • Install and lightly tighten M10 bolts securing oil pan to transmission.
  • Diagonally tighten M7 oil pan bolt further, but not final torque.
  • Diagonally torque M7 bolts securing oil pan to cylinder block.
  • Oil pan to transmission (M10)... 45 Nm(33 ft-lb)
  • Oil pan to cylinder block (M7)...15 Nm(11 ft-lb)
  • Wait 30 minutes as prescribed and refill with proper viscosity and quantity of engine oil.
Apr 20, 2010 | 2002 Volkswagen Jetta TDI
How do i fix oil pan/gasket for 1999 toyota camry solara
cool off your engine/ remove the oil pan bolts and remove old silicone or gasket/ clean the pan/ put a new gasket or silicone gasket/ refill fresh oil...
Apr 05, 2010 | 1999 Toyota Camry Solara
Dsc232 code 571 how to reset
Error code 571 is for oil overflow sensor error.If you pull out fusing unit,on the left side of it there is an oil unit attached,that has oil sensor on it.Most common problem is the sensor is getting disconnected.After you checked the sensor connection,here the procedure to reset the error code:
Turn main power switch off and back on.Then press "clear modes" key, 107 and press and hold "Stop" key for until you see screen has changed. Touch "Copy SP" tab on the screen, the press 5810 and # key. Press "Execute" tab on the screen to reset fusing error code.After that turn the main power to the machine off for a few minutes.Turn the machine back on - the error code should be gone and the machine should be working now.
Oct 05, 2009 | Gestetner DSc232 Copier
Code 571
"Fuser oil overflow" This is a color machine right? -Carl
Jul 10, 2009 | Gestetner DSc232 Copier
I HAVE PROBLEME OF GESTETNER DSC224 ERROR COPIER SC570 .
Fuser oil end On the rear of the copier is a cover that is near the lower center of rear cover you need to add silicone oil (fuser oil) to the copier and cycle power. Oil P/N A2579550
-Carl, please let me know if this helps.
Jun 18, 2009 | Gestetner Office Equipment & Supplies
jasbo
jasbo
