Cann't copy on two sides of the paper - Computers & Internet
  • 55 Answers
Your printer should have property to print both side..
its called duplex printing..
check this property into the printer.. if its there enable this option so you can print both side of printer.
chirag
Posted on Apr 03, 2008
How do I copy 2 sided copy from 2 sided original on hp Officejet 4630 e- All-in-One Series
copy one side, then take copy and put back into blank paper try and then copy other side. trial and error will tell you how to put paper in paper tray but usually printed side up, top in
Sep 18, 2015 | HP Office Equipment & Supplies
I have an imagerunner 2800 and it only seems to jam in the tray loading area, just bends the long side of the paper randomly. It changes it's performance just like the weather, sometimes I can get multiple...
A couple of things to consider:
Do not load the following types of paper in the paper drawer. Doing so may cause a paper jam.
- Severely curled or wrinkled paper
- Heavyweight paper
- Transparencies
- Paper on which color images have been copied.
- Paper which has been copied on using a digital full color copier (do not copy on the reverse side
either).
- Paper which has been printed on using a thermal transfer printer (do not copy on the reverse side
either).
Also, what # paper are you using?
Oct 12, 2013 | Canon (6981A002AA) for imagerunner 2200,...
I CANN'T ERASE WITH A KXE-7000 PANOSONIC TYPEWRITER
This T/W should correct automatically when the correction key is pressed, if it goes thru the motions but dosen't correct be sure the dull side of the correction tape is facing the paper.
DickyO
Jan 10, 2013 | Office Equipment & Supplies
I was wondering if there is anyway that you can make double sided copies and if so how??
Only copiers fitted with a duplexing unit will automatically make a double sided copy. I assume yours does not have this accessory.
You can always make two sided copies manually. You need to first work out the paper path, so mark one piece of paper with an arrow showing the top and the direction the sheet was placed on top of the paper feed tray. Make a copy and you will now know whether the top or bottom of the paper as loaded gets printed on. Now place that sheet back in the paper feed tray again with the arrow face down in the paper tray, but still pointing in the same direction as before. Print side two and you will now have a double sided copy. If the reverse of the copy is facing the wrong way then you know that the paper needs to go into teh paper tray with the arrow facing you. Hope this makes sense, but it just needs a couple of trial runs to get to understand which was round to put the paper back in for the revers side to be printed. Always keep the final successful double sided copy, marked up for future reference, as it is so easy to forget which way to put the paper back in several weeks later.
Oct 01, 2010 | Copystar CS-2030 Copier
DOUBLE SIDED COPYING
First normaly copy first side, then take copied paper and set it in bypass tray, when you do thath, the copier ask you for paper size and type, choose correct sett. and confirm with OK.The side on wich you want to print must be face down in bypass tray.
May 11, 2010 | Canon iR 1600 Laser Photo Printer
Paper Jammed in printer
once a time u should open cover of printer. and drum .then clean and blow air by air blower . it help u to clean dust and fixed parts which is connected to the sencer , i hope your printer can work . we also do for this --thanks
Jun 28, 2009 | Dell 1110 Laser Printer
Xerox Regal 5790 Paper Jam
Wat is the code about this problem 08-300 its maine the Füser is not start on the same time when the cluts is not werking oder the pall is not gooing to this point open the front dore an you cann sche small cluts this is no good contact of its not working then you can puss the small wiel to the bik rol en the paper wil to the füser turn the green wiel and the paper go to füser out. I had this problem also with Xerox 5760 the same .
Apr 10, 2009 | Xerox Office Equipment & Supplies
I cann;t Copy or print in paper 81/2 x 14 in the IR 3100 canon
Just guessing.... Not knowing the model or Make of the copier. You Probably have to change the papersize on the drawer that you are putting the larger paper into to equal 8.5x14: usually by a dial or the position of the fences (side and rear paper guides inside of the tray)....
Mar 29, 2009 | Office Equipment & Supplies
I do not know to copy on both sides of the paper, can you help?
I don't think the HP Officejet 5780 have the capacity automatic for double side copy.
nothing in the printer specification have the double side copy listed.
what you can do is copy one side and trun the paper over and copy the other side.
Dec 09, 2008 | HP Officejet J5780 All-In-One InkJet...
How to use
Does the copier have a duplexer? Automatic 2-sided copying (duplexing) was an optional feature for the EP2030. If there is a drawer in the lower section of the copier labeled "duplex" then your unit has this feature.
To use it, simply select 1>2 (for single-sided originals) or 2>2 (for 2-sided originals) on the "Orig>Copy" section of the control panel (toward the left side).
If your copier is not equipped with a duplexer, the only way you can make 2-sided copies is to copy the first side and then load the copies back into the paper tray or the manual bypass on the right side of the unit.
Note the the copier copies on the bottom side of paper fed from the paper trays, and the top side of paper fed from the manual bypass.
You can download a .pdf file of an operator's manual for this copier from the Konica Minolta website.
Oct 22, 2008 | Minolta EP1030/1030F CS/PRO Copier
Computers & Internet Logo
David Payne
David Payne
