Question about Royal Orca ASF5000X Shredder
Royal Orca 9512
Shredder worked. Shipped it to my new home, plugged it in and nothing happens.
Is there a reset button or ?
I had something very much like what you tell of.
Take off top with 4 hex/Allen screws, careful not to stress wires to panel rocker switch. support it somehow. Follow the line cord in and check the fuse, maybe we should have done this first, huh?
With VOM check cont of black lead thru fuse into safety switch adjacent. ON MINE IT WAS JAMMED. I could not free it, and surmising it was an interface with custom waste receiver which I did not have I bypassed it with a drop of solder. SUCCESS!!
But not quite. therre was still a pesky intermittent on/off that came and went.
Traced it all down to a cold solder, dry, joint on a red lead going to the front panel switch. Take it off, tighten tabs, solder what had been only crimped at factory and SUCCESS!!
All back together and there is a reason they call this thing ORCA:
Good luck with forensics as this thing delivers uniform quarter inch squares, confetti, no chance to decipher one damn thing.
Hope this helps, David Anshus
Posted on Jul 16, 2009
There are 2 plugs in the back. one is on a short cord, the other is the regular power cord. BOTH must be plugged in. also, the shredder must be properly situated on top of the base so that the button inside of the back right good is depressed. last, there is a safety behind the bin that must also be depressed. mine broke--i have a piece of wood jammed in there to hold the button in.
Posted on Aug 25, 2008
I have an older royal orca 9512x shredder that I purchased at staples....recently it wouldn't work...I found out that the plastic switch that triggers the shredder fell off ...a small projection of...
screw a small screw into the piece in the back right corner of the basket that the shredder fits on. This will adjust to the height needed to make the shredder run.
Jun 17, 2011 | Royal 15MX Shredder
The shredder stopped and we can't get it started again.
Assuming that its not jammed,??.... if its dead and you have no lights, no power etc etc...then you may have blown pcb inside machine...call Royal at 1-800-524-0799 for parts assistance.
Sep 22, 2010 | Royal Orca ASF5000X Shredder
Royal Orca 9512x shredder will not run. I have checked the fuse and it is good. Cleared a paper jam and still wont run forward or reverse.
If motor wont run at all then probably the pcb is blown...call Royal at 1-800-524-0799 for parts and prices.
Sep 15, 2009 | Royal 15MX Shredder
Fuse Cover for fuse
For parts give Royal a call at 1-800-524-0799.
Aug 11, 2009 | Royal Office Equipment & Supplies
Royal orca wont forward will reverse shredd.
May have paper bits jammed above fixed curved metal surface that spiral cutter slices against.  Need to spend time removing built up material with stiff wire or flat tool.
May 04, 2008 | Office Equipment & Supplies
Royal ORCA 3500 paper shredder
orca 3500: reverse works but auto run does not. Green Light is on, bin is empty but will not shred paper? Any suggestions?
Dec 24, 2007 | Office Equipment & Supplies
Royal Orca ASF5000X Shredder Logo
269 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
