Question about Neff U1721 Double circotherm Electric Oven
Oven electrics keep tripping when oven turned on
  • porsche177 Apr 03, 2008
  • 23 Answers
If it trips out after a few seconds then then you need to rewire it
if it trips out as soon as you turn it on then a cable has come loose and is touching either another cable or the metal casing in which case if you cant find it you may need another oven
it should be on a 32amp breaker with 6mm cable if its a long distance from mains to oven it should be 10mm cable covered by a either a 32 amp or 45 amp
Posted on Mar 14, 2009
  • 549 Answers
You either have a bad element, loose wire or a short.
Start by checking the connection at the back of the stove.
Then look inside the oven to see if there is any visible evidence of damage to one of the oven elements.
I would suspect it is the bottom element that is giving you trouble.
Otherwise, if you have bad wiring to the range outlet, this could be difficult to track down.
If this is a new installation, your fuse/circuit breaker may not be high enough amps.
You may need to increase the size by installing new fuses or breaker depending on which you have.
I think a 50amp breaker would be standard, but you may need to use a 45 amp or greater. Just be sure your wire to it is heavy enough.
#6 wire would be better for a double oven situation.
Posted on Apr 03, 2008
3 Suggested Answers
SOURCE: fan Oven keeps tripping the electric box
keeps triping main fuse box off
Posted on Mar 20, 2010
  • 414 Answers
SOURCE: my oven keeps tripping the electric
It will be the ring element, short circuit. This is the element that runs around the fan behind the backplate in the oven. It can be replaced by isolating from the mains, remove the 4-6 screws hold the backplate on. remove the two screws on the element brabket and one screw holding the element in position at approx 4 o' clock. Be very careful removing the element at the bracket, ease it out very slolwly so as not to detach the spade connector and wiring. A replacement can be obtained from ebay, espares etc or neff direct via there website (link to spares shop). Make sure the wiring goes back on the new element as it came off the old one. Replace screws and backplate and it should be sorted.
Hope this helps
Posted on Apr 07, 2013
My Creda Reflection double oven keeps tripping the oven fuse when I turn it on? It doesn't trip straight away, it works for a minute or so and then trips the fuse. Any ideas?
call an electrician to check the circuit insulation for shorts
could be vermin cooked across electrical terminals , failing insulation, grease /fat across terminals
dead shorts trip the breaker immediately, ground leakage problems take a little longer
May 07, 2017 | Creda Ovens
Why does the cooker keep tripping the electric power?
loose wire,shorted switch?(You will receive an answer like this if,you did not include the make or model or serial number or
date of manufacture or complete problem and what needs to be done.)
Jun 08, 2015 | Ovens
My hotpiont cooker c358ewh keeps tripping the electric every time I turn cooker on. Everything else works. It started when I self cleaned my oven. Can you help please
It's tripping because to much amperage is going to it, this tripping is a safety to let you know you have a problem.
Feb 10, 2015 | Ovens
Oven keeps tripping mains
If it is a electric oven, then the chances are it is the oven element that is causing the problem.
What is probably happening is that as the element gets hotter, the insulation resistance is breaking down, and causing the trip to operate
Hope this helps.
Feb 02, 2010 | Whirlpool Ovens
Zanussi zbf260x built-in oven keeps tripping out
Probably due to a fault on the oven heating element. Check continuity and earth with a multimeter if you can but it's odds on you will need a new heating element.
Dec 26, 2009 | Zanussi ZBF260 Electric Single Oven
Oven keeps turning off . HELP it is Thanksgving. Just shuts off.
Hello there
you may want to consider unplugging other heavily used items in the home so the electricity will not keep overloading the oven and making it trip off ok
best regards michael
Nov 25, 2009 | Bosch HBL3420UC Electric Single Oven
Zanussi 360 just tripped and now keeps tripping
You will probably find that it is the oven element that needs replacing, located at rear of oven compartment behind rear panel.
Please rate my solution.
Thanks.
Nov 11, 2009 | Zanussi ZBF360 Electric Single Oven
Double oven keeps tripping circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Oct 24, 2009 | Jenn-Air JJW9830D Electric Double Oven
Neff U1721 Double circotherm Electric Oven Logo
301 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
