Question about Jeep 10 x 20
1994 Jeep Cherokee
I have a 1994 Jeep Cherokee with low mileage (115K). Recently when I was driving it it stalled out and then would not start. After about 20 minutes it will start. AAA thought the problem was the burgular alarm was activating the shut down engine sequence so I had the burgular alarm system removed. This did not solve the problem. Do you have any suggestions?
  • Anonymous Jun 18, 2008
    same thing happened to my jeep. cleaned the injectors and still won't start. don't know what to do with my jeep. need help!
  • Anonymous Dec 17, 2008
    I have a 1994 jeep cherokee 50,000 miles. It stalls out while driving, as if it ran out of gas.Sometimes it will start, last time it had too be towed. When it cools it starts back up.Can anyone answer or give me HELP. THANKS
Check your alternator
Posted on Apr 18, 2008
SOURCE:
Frequent stalling
Could be the ASD relay among other things.
Can you check to see if the coil and injectors have power the next time it fails to start ?
Feb 04, 2014 | 1994 Jeep Grand Cherokee
We have a 1994 grand Cherokee Jeep and it will shut off when you are driving. If we wait 15 or 20 min then start it again it will crank, What could be the problem.
Without the benefit of testing, the two most common causes are either the crank position sensor has failed or the fuel pump is failing. If you can't hear the pump humming in the tank when you first turn the key to run after the engine has stalled, good bet is the pump is bad.
Apr 21, 2011 | 1994 Jeep Grand Cherokee
After driving the jeep for 20-30 min the front
it sounds to me like you need tie rods and hub assembly's and bushings
Mar 14, 2010 | 1994 Jeep Grand Cherokee
1994 jeep grand cherokee laredo starting problems
Check to see if the fuel pump is running after it shuts down...could be a relay or the pump itself (overheating internally) Checked the fuel filter yet? Some crank sensors need to be shimmed. If it's too close to the flywheel even though you recently changed it, if it's too close to the wheel it can fail again. May not be the case but worth checking over. Also check the ceramic resistor on the left fender near the master cylinder if you have one. That too can cause problems.
Dec 27, 2009 | 1994 Jeep Grand Cherokee
1994 jeep grand cheeroke limited stalling
There is no such thing as a small fuel leak. Even if the car was running great, it is extremely dangerous. You can "section" the line using a small pipe cutter and brass compression fittings if you don't want to change the entire length (providing it's not really rusted. Most of, if not all your problems can definitely attributed to that leak.
Jun 03, 2009 | 1994 Jeep Grand Cherokee
Once I start my 1994 Jeep Grand Cherokee it starts hestating.
check idle control valve mounting hardware & electrical connection on tbi. do not over torque bolts.
Mar 25, 2009 | 1994 Jeep Grand Cherokee
96 JEEP Gr Cherokee hesitates, surges, later stalls
You might want to start by replacing the crank sensor first.
Nov 24, 2008 | 1993 Jeep Grand Cherokee
Jeep 10 x 20 Logo
69 people viewed this question
Top Jeep Optics Experts
Marvin
Marvin
james laughton
james laughton
ray gallant
ray gallant
Are you a Jeep Optic Expert? Answer questions, earn points and help others
