Question about SanDisk Sansa e250 MP3 Player
Volume control works backward, and will only turn volume down. Also various other problems, songs that used to play but now won't, etc.
  • 790 Answers
Just reset ur player using the reset pin available on the player!!
Posted on Apr 07, 2008
Alpine 9886 with sirius interface
This problem sounds very sirius. Sorry, couldn't resist, but "siriusly", the song alert feature is supposed to be something you select yourself, so it locates a particular song whenever it is played on the service. Do you recall setting this?
Are you using the Alpine KCA-SC100 tuner or another?
I would try resetting the radio too.
Dec 13, 2013 | Alpine Car Audio & Video
Volume control
What is the model number of the TV? Does the set work normally with just cable etc?
Jun 10, 2012 | Toshiba Televison & Video
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
Sep 20, 2011 | ButtKicker BKA1000-4A Amplifier
Using oakley thump pro 512mb, once reset glasses comes on but unable to use any of the controls to change song forward or backward or even to change volume. this is after fully charging them. what could...
I'm having the same problem....also if you try and forward to the next song...it will repeat that same song 3 times. Its almost like the volume butons are stuck or something...they dont seem to depress the same 9you dont feel a click or anything)... weird.
Aug 14, 2010 | Oakley Thump MP3 Player
Dvd rom will play cd with sound it will play dvd with/out sound
Well the good news then is that its not a hardware problem, it is most likely one of the issues below:
1- Vista muted the player that you are using: Launch the player and then at the bottom right corner by the time click on the volume control and select mixer. It should list all the programs you have open. In vista you can mute a selected program, make sure all programs are not muted
2- The volume control is turned down on the Toshiba laptop: On Toshiba laptops there is a volume dial control located either on the front or around the sides, make sure that it is not turned down. play a song and try adjusting it both ways
3- Conflict with another Video/Audio Player : Un-install any newly added media software.
Apr 14, 2010 | Computers & Internet
Songs are continueously playing backwards and won't stop.
Basically, just keep plugging it into your USB port and out again. Hope that this works. It should. Turn it on after you've unpluged it and text out to see if your songs are still playing backwards.
Oct 30, 2009 | Samsung YP-U3 MP3 Player
Ipod turns on and works - cant hear song playing
Check the volume using the buttons on it and also in your settings/volume limit. If that doesn't work, resync it with iTunes and see if there is a parental control in place preventing music to be played.
Oct 13, 2009 | Apple iPod MA446LL/A MP3 Player
My jbl radial, when using a 120 gig ipod, will skip songs.
Not a solution but mine sometimes causes my ipod to skip mid-song to the next song or podcast as well. JBL customer service is usually good and I've been meaning to check with them since I finally figured out it's the radial and not my ipod.
Jun 21, 2009 | JBL Radial Speaker Dock Docking Station...
Recordings problem
The database is corrupt - run the Sansa Recovery Tool and start over - back up your recordings first, b/c the recovery tool will delete everything:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 02, 2008 | SanDisk Sansa Clip MP3 Player
Volume control problem
bring good contact luricat cleaner from near radio shack and apply it over volume and move it forward and backward many times.
Jun 21, 2008 | Marantz SR-5200 Receiver
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
