HP Deskjet D1400 series PROBLEM - ON/OFF BUTTON FLASHES CONTINUALLY. APPEARS TO HAVE STARTED FOLLOWING CHANGE OF CARTRIDGES
  • 14792 May 07, 2008
    the light flashes continously n when we select print button on the screen n then we press the button again the paper sets n goes inside for printing the paper cums plain without printing anything.the status of the document is blank n the documents remain in queue without printing
    Genius:
  • 3,587 Answers
That's not unusual...check the seating of them..
Posted on Apr 03, 2008
Continous pop up on low ink, how to stop?
Posted on Jun 21, 2008
HOW DO i SOLVE THIS PROBLEM CAN YOU TELL ME
Posted on Nov 23, 2008
SOURCE:
Hp 2540 deskjet. Just replaced BOTH cartridges with genuine HP ink 60. Printer still flashes on the cartridges being empty. Error message. I cannot print anything. I can scan but that is all.
Per HP: After installing a new print cartridge, a message appears on the front panel that the print cartridge is low on ink. This may be caused by installing the cartridges with the power turned off. Cartridges should always be installed with the power turned on.
Found the following directions online:
How to Replace an Empty Ink Cartridge in the HP Deskjet 2540 All in One...
May 20, 2016 | HP Office Equipment & Supplies
My printer hp deskjet d1400 series is not compatible with my os window 7, what should i do, so i can use my printer?tnxs
It's compatible, If i am right, you haven't downloaded or installed the drivers for windows 7. If you need, you can download it from here..
1. Hp deskjet d1400 win 7 32bit
2. Hp deskjet d1400 win 7 64bit
Still need more info? please click the link
Download the appropriate drivers for your system and install it, it'll work fine..
If you have problem please let me know..
[please uninstall the installed driver before you install the new drivers]
Good luck
Thanks for using FixYa.
Jun 28, 2010 | Office Equipment & Supplies
Replaced the cartridges and the yellow flashes
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 18, 2009 | HP Deskjet 870cse Printer
Resume button will not stop flashing.
The HP series of printers you have can be finiky when cartridges are swapped. Use an old toothbrush to very gently clean the contacts behind both ink cartridges. Carefully wipe off the contact strip on the back of each cartridge. repeat this till the cartridges are properly detected. close the lid after each attempt!
Nov 10, 2009 | HP DeskJet 895cxi InkJet Printer
Hi my name is Alex Irecently purchase a HP Pavillion along with a 22" widescreen the package came with HP Desktop D1400 series, I cannot get it Print what should I do.
Make sure that the driver of the HP Deskjet D1400 series printer is already installed on your computer. Once it's properly installed, try to print a test page and see if you will be able to print.
For technical support, try to go to www.supportrix.com. You may use "suppportcall" as a promocode.
Aug 01, 2008 | HP Office Equipment & Supplies
How do i get the drivers of Hp deskjet d1460 printer
you can download the drivers from some of the following sites:
www.ciao.co.uk/APOLLO_P_2100U__5381936
www.exactmall.co.za/component/virtuemart?product_id=2431&page=shop.product_details&category_id=75
www.atomico.es/search/hp-deskjet-d1400-printer-driver/1-5.html
www.sigmanet.ro/cautare/cautare.php?kw=download%20driver%20HP%20Deskjet%20D1460%20win98&prod=4&mc
www.kaboo.ro/info/d1460-driver.html
Feb 09, 2008 | Office Equipment & Supplies
780 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
