Question about SanDisk Sansa e260 MP3 Player
System won't refresh
My Sansa e260 won't let me change the music list. When I try to add or take out albums, there is no difference when it refreshes. I even tried deleting all of the music, and the list still comes up the same.
Also, I can't seem to get rid of Rhapsody Channel songs I added to the on-the-go playlist, even when I take them off the list. They don't show up in the music folder when connected to the computer, but they stay on the music list on the player.
Any suggestions? Thanks!
  • 758 Answers
Try holding the power button down for at least 10 to 15 seconds. That should turn it off. Turn it back on. If this doesn't work, try taking the battery out for a few seconds.If that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Posted on Apr 03, 2008
SOURCE:
My sandisk sansa e260 mp3 player wont trun on it goes to the start up screen and thin keeps repeting that screen how can i fix this does any1 know?
Hi, the Sansa E260 is a portable MP3 player released by SanDisk in 2004. Several problems may cause the E260 to not function as intended from time to time. Common problems that occur are the device freezing, album art not appearing on the screen when a song is playing, pictures not filling the screen size and missing information on the separate tracks. You can troubleshoot the device and fix many of these common problems without the need of a service technician.
Reset
1. The Sansa E260 may freeze or function in other unexpected ways from time to time. This generally occurs when the unit's software has developed an error. Reset the device to clear the error and return the device to normal working operation. A unit reset is similar to rebooting your computer. You won't lose any data stored on your device.
To reset the E260, press and hold the "Power/Menu" button for about 15 seconds. The device will be forced to power down, during which the error will be cleared. You can restart the E260 as normal once the reset is complete.
Album Art Does Not Display
2. The E260 supports viewing album art on the display screen during the playing of a song. You may find that your album art is not showing up on the display when music is playing on the device. To fix this, make sure the associated album art file is in the same folder as the song being played. You will need to connect the E260 into your computer to move the album art files into the music folder.
Photos Aren't Full-Screen
3. Photos displayed on the E260 will not show up as full-screen shots if they are not cropped to the correct dimensions. The E260 software does not support stretching pictures to fit the full screen. To ensure your photographs will display on the full screen, crop the images to 128x64 in photo-editing software prior to transferring the image on the E260.
Unknown Artist or Album
4. The E260 displays information about each song using the ID3 tags associated with each track. ID3 tags hold information such as the artist name, album name, track number, year it was released and other information. If the E260 shows an artist or album as unknown, the information in the ID3 tag was not filled in. You can insert information into the ID3 tags from your computer.
To change the ID3 information, right-click on the music file and choose "Properties." Click on the "Summary" tab and choose "Advanced." The ID3 fields will display in the window. Insert any of the missing information and click "OK." When you upload the song onto your E260, the newly inserted information will show up in the display.
Hope it helped...
Feb 23, 2011 | SanDisk Sansa e260 MP3 Player
Sansa e260 has no space left to write the database info. Vista and also Windows Media Player don't ''see'' any files. I can listen to all the music on the MP3 but I want to delete some and add others.
Same problem delete a couple of songs up to 6 mg or 10 whatever then allow to refresh then download your songs back in the music file. the sansa needs some memory to know it has the sdcard in it...
Go to my computer scroll to sansa and open the media folder and open each sub folder and delete manually then delete the folders themselfs then format a couple of times hope this works
Start over put new songs on it
Apr 19, 2009 | SanDisk Sansa e260 MP3 Player
I can't add new music folders to my sansa e260 because some go to
open windows media player and goto libary click on album artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar put a check next to artist and album artist. Right click song under artist or album artist or both and type in the name of the artist etc.... then syc with your sansa then load songs to it........
Mar 24, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260
Apparently there is a known problem with older firmware with some MP3 files having info in the ID part of the file that makes the player go crazy. So update your firmware or listen to different music :-)
"Bugs Fixed: Stability· Hanging at Refresh Database with certain ID3 tag genres."
This info from page below. Also shows you how to update to latest firmware which may fix your problem
http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=10357
Sep 04, 2008 | SanDisk Sansa e260 MP3 Player
Deleting music from sandisk sansa E260 4FB mp3 player
you can change the usb mode in the sansa player settings to MCS then connect it to the computer, in windos xp the device will be recognized automacally. go to the explorer or to my pc and you should see it there.. go to the folder music and delete what you want,, you can copy music as well.
then desconect it safely and restart the device,, It will refresh the database and that's it.
you can change the USB mode bac to MTP if you wish.
Feb 04, 2008 | SanDisk Sansa e260 MP3 Player
Sandisk sansa e260 reset?
Plug it into the usb port. The Sansa 260 will show up as the next drive letter. Using the right mouse button click on the drive latter and select format. This will will format your Sansa 260. The operating system files will still be there but all of your music, movies, voice recordings, etc... will be deleted.
Nov 11, 2007 | SanDisk Sansa e260 MP3 Player
Help sansa e260 album covers
Hi! I followed these directions, but I still can't view the album art on my player. I downloaded album art for ten albums, and named them
Album Art
album art
folder
I still can't view any of them. Any idea what's going on here?
Thanks!
Aug 05, 2007 | SanDisk Sansa e260 MP3 Player
Freeezing
Hi. The symptoms you described may be due to corruptions in the player's music database (this player maintains an information pool on the music files you download to it). To resolve that, you would need to delete that database and let the player re-create a new one. To delete the corrupted database, let's do this: Step 1: Switch your player to MSC mode Step 2: Browse the player in "Windows Explorer", and look for the folder named "System" and/or "Data". Note: if you can't locate these folders, your Explorer may be configured to "Hide" system files and folders. To change that, please go to "Tools" on the menu list on the Explorer window, then choose "Folder Options". This will display a Window arranged in tabs. Select the "View" tab, find the "Hidden Files and Folders", then choose the "Show Hidden Files and Folders" radio button Step 3: Under the "system" or "data" folder on the Sansa E260, look for this file and delete it: "PP5000.dat" Step 4: Safely remove your Sansa E260. Then power it on. Your player will now either display "Rebuilding Library. Please Wait" or "Finalizing Update". Either way, it would re-build the database and hopefully resolve the error your player is encountering. I hope this helps. I love the Sansa E260!!
Mar 15, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
20 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
