Question about EliteGroup GeForce 6100SM-M Motherboard
Bios update How do i install a bios update to a Geforse 6100sm m board
  • 13,433 Answers
General instructions
http://www.wikihow.com/Update-Your-Computer's-BIOS
1. find the update
2. find the update software
3. find a dos boot diskette or cd from www.bootdisk.com
4. continue with the wikihow
Posted on Apr 06, 2008
Will an ADX6000(125w) Run on a geforce6100SM-M motherboard with new bios update?
updating your bios can be farmful to a computer you should not update your bios unless its absolutely necessary
http://majorgeeks.com/BIOS_Patcher_d3965.html
Find and fix errors in your system BIOS
BIOS Patcher can find and fix errors in your system BIOS (only AWARD BIOS for now) and also it can add or open new features, i.e. some features that your BIOS has but they are closed by manufacturer of your motherboard. It scans rom file. If it finds any known errors it fixes the errors. If it finds any closed features it opens it. hope this helps you
Nov 04, 2011 | EliteGroup GeForce 6100SM-M Motherboard
After downloading drivers from ECS site for geforce 6100 sm-m i still do not have ethernet adapter. Also other pci bridge device is missing. In XP
since your not able to install the drivers..
Broadcom AC131 10/100 driver is the same as nforce 430/410
http://www.nvidia.com/object/nforce_nf4_430_410_winxp32_8.26.html
or
http://www.broadcom.com/support/ethernet_nic/downloaddrivers.php
then try installing Uniblue DriverScanner or Driver Genius Professional Edition so you can get all the other drivers for you motherboard
you can also try to update your bios only for ecs 6100sm-m mobo
http://drivers.softpedia.com/get/BIOS/ECS/ECS-GeForce6100SM-M-V10-10A-BIOS-070906.shtml
hope this helps..
Dec 31, 2009 | EliteGroup GeForce 6100SM-M Motherboard
Just installed new mobo (ecs 6100sm-m) and boot up issue
from my experience, you will need to format when changing the hardware you have changed. are there files on the drive that you need? if so id recommend putting your old motherboard back in to backup the drive then rebuild and format. thats if it wasnt faulty to start off with.
hope it helps
Mar 16, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
No Audio on ECS 6100SM-M2 mobo d
Go to the Startup Bios Configuration Utility By Presing Specific hotkey. Probanly you having Audio Device as Following
Realtek ALC660/ALC662 6-channel audio Enable or Reinstall Driver As link given here >>> http://www.esoft.web.id/go/WDM_R210.exe
Hope you will have good result
Regards
Feb 01, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
ECS 6100sm-m
Download WD's software to test & setup drive. Try windows install again.
WD's link; http://support.wdc.com/download/index.asp?cxml=n
Mike
Apr 25, 2008 | EliteGroup GeForce 6100SM-M Motherboard
EliteGroup GeForce 6100Sm-M Problem
4 things can cause this MB to do as you mention.
Bad CPU or the MB is not sensing the CPU fan and is protecting CPU from overheating.
Bad or inconpatible memory, If multiple sticks use only 1 at a time, This MB is known for having problems with both slots filled most of the time bios resaves can fix this but just set up with 1 first.
Reset the bios, Make sure the reset jumper is set back correctly.
Make sure it post without any extra harware hooked up first then add them.
The beeps are a old style of signaling the problem, You can find charts online that will tell you what the beeps mean long and short.
Nov 27, 2007 | EliteGroup GeForce 6100SM-M Motherboard
GeForce 6100SM-M Motherboard (no Audio )
I down loaded Realtek HD audio drivers from
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=685&DetailName=Driver&DetailDesc=GeForce6100SM-M(V1.0/1.0A)&CategoryID=1&MenuID=75&LanID=0
Oct 24, 2007 | EliteGroup GeForce 6100SM-M Motherboard
ECS GeForce6100SM-M Onboard Network Adapter does not show up in windows???
I had the same problem. Tyr this.. Install windows x64 1st install the ide driver (it's a setup program) reboot 2nd go to device manager, you will see a PCI bridge device, update that driver to the lan driver on the cd. reboot Then install the rest of the drivers. If you don't do it in that order you will NEVER be able to install the Lan driver without reinstalling windows.
Aug 11, 2007 | EliteGroup GeForce 6100SM-M Motherboard
EliteGroup GeForce 6100SM-M Motherboard Logo
267 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
