How do you set a scanned document folder on a ricoh aficio 1045?
Ricoh aficio 1045
  • 1 more comment
  • Anonymous Mar 13, 2014
    RICOH AFICIO 2032
  • Anonymous Mar 19, 2014
    SC475
  • Anonymous Mar 21, 2014
    Aficio 4500 ricoh sc520
  • 82 Answers
Do you mean how do you creat a folder to scan your documents into ? if you have document server or scanner buttons on the key pad, then just select scan and mofidy the folder to your choosing.
Thank You,
Mikey
Posted on Apr 06, 2008
Hi, I have multifunction printer (Ricoh Aficio 1515MF) I want to use it to scan many pages to a folder in my pc, unfortunately I didn't found any way to make that, the only way I found by email, then I set...
If the printer came with operating software you should use it to scan the document. Even without the manufacturer software (but not the drivers) you can use Acrobat or Word Perfect or LibreOffice to scan to the application then save the scanned file either as pdf, image format, or as text (OCR).
There are some free scanning software available on the Internet: freeOcr, pdfViewer, Paperscan Free edition They are usually able to send the file to an application or save in a specific format. If they are not able to scan a multipage document you will have to scan one page at a time then assemble the pages
Oct 11, 2013 | Ricoh Aficio 1515MF All-In-One Laser...
I can't set up scenner options in aficio mp2000
look here in Ricoh white papers you should be able to find what you need. http://www.ricoh-usa.com/support/knowledgebase.asp?tsn=Ricoh-USA
Mar 16, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Trying to get my Ricoh Aficio 1035 networkable
This is all you need to upgrade your copier to a network printer/scanner and fax.
Good Luck.
32MB Memory Unit Type B 400516
Postscript 3 kit type 1045 410713
64MB Memory Unit Type B 400517
Fax Function Upgrade Type 185 410284
Print Unit Type 1045 410706
Printer/Scanner Unit Type 1045 410699
Network Interface Board Type 1045 410714
Fax Option Type 1045 410680
Fax Stamp Marker Type 30 334049
Jul 08, 2009 | Ricoh Aficio 1035 Copier
Scan
Yes you should be able to set up a destination in your address book. The folder must be shared. Click here for the scanner reference for this machine for more information.
Here is a link to all of the other manuals. Hope this helps. Let me know if you need more help.
If this helps you out, please rate this as fix ya.
Nov 25, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1045 User Key
Someone locked the machine out. You can a hold of who your purchased it from to see if they can give you the key operator code to unlock it.
I can give you the service code to restore it but there are several steps involved in doing that.
If the first option doesn't work, let me know and I'll look up the service program to disable the key codes.
Sep 01, 2008 | Ricoh Aficio 1035 Copier
Problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Jul 02, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio 1075 - SMTP error message
To use the scan to email function on your copier you need some settings from your internet provider (email setting specifically). Go into Outlook options and get your SMTP server, user name and password.
On your copier you need to change under User tools, system setting and file transfer and put these settings in. As long as your machine is set up for scan to folder thats all you should need.
Apr 18, 2008 | Ricoh Aficio 1013F Copier
Re: SCANNING ON RICOH
You need the scan router lite utility. You can download it from:
http://support.ricoh.com/html_gen/util/SR/SR_R.html
Feb 22, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
Scanning software issue
if you go to scan settings under user tools you will see that you can set it to a multipage pdf or multi page jpeg tiff , or what ever , so if you scan 20 pages it will create 1 file and it would contain your 20 pages
Aug 14, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
647 people viewed this question
k24674
jasbo
jasbo
