Question about Conair DPP4000 Iron
Iron Shuts off Automatically when using iron.
Can someone tell me how to control or disable the auto shut off feature. My iron just shuts off everytime I am ironing my clothes.
  • Anonymous May 21, 2008
    when I am ironing it shuts off automaticlly and when I try to turn it on it's turn shuts off again.
  • Conair Master
  • 43,501 Answers
The cord is broken...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
Iron keeps shutting down while ironing
My rowenta iron keeps shutting down while I'm ironing. What ...
www.faqqq.com/.../my-rowenta-iron-keeps-shutting-down-while-im-iro...
Question Product: Rowenta Effective DX1900 Iron with Auto Shut-off Question Details: My rowenta iron keeps shutting down while I'm ironing. What can I do.
Top 229 Complaints and Reviews about Rowenta Steam Irons
www.consumeraffairs.com > Shopping > Appliances
Rating: 1.6 - ‎36 votes From the first day, iron shuts itself off while ironing. ... The last 3 have either leaked everywhere or the cord where it joins the iron keeps switching the iron off. ..... from the stainless steal down the right side of the iron and was leaking water all ...
Oct 31, 2015 | Irons
Premature shutting off
Have you try with lower heat setting?
It seems like it might be thermostat or thermal fuse that is not working properly.
Apr 21, 2008 | Rowenta Effective DX1700 Iron with Auto...
Iron shuts off automatically when using
There is a fuse link and an over temp disc in these ,if the disc is not working correctly it tells the iron to open the disc until it cools to a lower safer temp then resets.
Apr 19, 2014 | Irons
Shark g1468 auto shut off (iron won't come/stay on)
First let me say I HATE AUTO SHUT OFF!!! It sounds like it has wore out. the computer part that tells it when to shut off it not working. It would be cheaper to buy a new one vs fixing yours. If I were you, find an older iron that has LOTS of steam vents and NO AUTO SHUTOFF at your local goodwill, thrift store or garage sale.
Jan 06, 2014 | Shark Euro Pro GI468-FS Rapido...
Breville TECHnique VIN158
if the iron use electronic control, will be a little difficult to adapt or reset .However i recommend follow this steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Jun 11, 2013 | Irons
I have a Rowenta DX1700. The iron will only stay
The problem is with the iron's thermostat which controls the temperature of the iron
Feb 07, 2010 | Rowenta Effective DX1700 Iron with Auto...
My iron shuts off when I am continuously ironing.
The flashing is a indication that somthing is failing.. More than likely it is a internal component..
It might be most efficent to get a new one..
Or bring it back if it is under warranty..
Good luck..
Sep 23, 2009 | Hamilton Beach 14977 Iron with Auto...
I have a Rowenta Pro. Iron, model DE-86.1A with auto shut-off. It sticks on auto shut-off. I have to move it around for it to heat up, as indicated by the sensor light on the top.
I believe that is how the safety feature works.
Once the iron detects no movement for a certain period of time (the iron assumes you have finished ironing) the iron will shut of the heating element.
One you have moved it around, the timer should prevent it from auto shutting down for a period of time.
Jul 22, 2009 | Rowenta Irons
I'm having a problem with the auto shut off of my sunbeam 421A series iron. The iron works great until the auto shut off comes on and the red light starts blinking. I understand that the iron should...
Unless you have a 5 or 6 hundred dollar iron, or unless it is brand new, and still under warranty, there is an excellent rule of thumb when an iron quits working: Buy a new one! These days, irons can be purchased cheaply enough that it is WELL worth the money. Not just for the convenience, but for the safety issues. This is an appliance that could burn your house down even if it's in PROPER working order. Hope this helps!!
Chad
Sep 21, 2008 | Sunbeam 4214 Iron
the only thing you can do is change out the motion sensor which is 1n the machine or disable it
Apr 21, 2008 | Irons
Conair DPP4000 Iron Logo
324 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
