Question about BenQ PE8700 Multimedia Projector
Update BenQ PE8700
Hope this is not getting too old for you? I appreciate your help!
Spoke with BenQ again, still not helpful. They insist that it is the cable or something else and that there is no firmware upgrade for this or the PE 8720. Said the only reported problem was DVI to HDMI and that there was no fix at all for that.
Don't know what to do here???, I'm going to try and test it with another cable to see if it might be the cable but I bought a real high quality cable so I'm pretty sure that's not it and I know the cable isn't too long either.
This has been a real pain, I have this great projector but can't get it to work like it should.
  • 3 more comments
  • dash18 May 29, 2008
    Can not connect to Sony Play Station 3 uising HDMI/DVI to my PE8700+
  • qed60 May 29, 2008
    Exact same problem, and terribly disappointed of course...
  • Anonymous Jun 05, 2008
    Hello, i have also the PE8700 and just added a Panasonic Blu-ray (BD30), connected via RGB cable (RCA connectors). The output of the bluray is initial 1080i and the native resolution of the projector is also 1080i - but it don't work like that - i have to reduce the output resolution of the player to 578i because the projector tells the player that's this is his max resolution via RGB? I think this is a firmware problem. But where can i find an upgrade for this?
  • kenhartshorn Jun 23, 2008
    Concerning:
    "Said the only reported problem was DVI to HDMI and that there was no fix at all for that."
    What is the problem? I have a Playstaion 3 connected via HDMI to DVI.
  • rgordonpike Nov 07, 2008
    I am trying to source a service manual for the PE8700. I have to replace a faulty upper fan motor. Any help as to directions to remove the fan at the top of the unit ???????
6ya staff
SOURCE:
Marrie
Marnus Jacobs
  • 563 Answers
SOURCE: BenQ PE8700 DVI problem
Hi guys
All that needs to be done is a firmware upgrade.
This can however only be done by a BenQ Approved Service Provider because if the person doing this makes a balls-up the Projector will be dead as a doornail.
Posted on Apr 01, 2008
Marrie
Marnus Jacobs
  • 563 Answers
SOURCE: BenQ PE8700
Nothing yet , still awaiting feedback from BenQ Factory
Posted on Apr 17, 2008
projdoc
jasbo
  • 2239 Answers
SOURCE: BenQ pe8700 projector ir sensor replace or repair
unless you dropped it, there is no damage to the sensor. it might just be dirty. blow the dust out of the projector with canned air. if there is physical damage, just replace it. if you're sure the remote works but none of the sensors do, it's a main board problem.
Posted on Nov 12, 2009
Anonymous
SOURCE: Projector shuts down ca 20 sec from start.
I have the same problem, however, my lamp wasn't replaced. Projector working great, just started today. Filter cleaned, reset lamp time, neither helped. Any luck yet?
Posted on Dec 25, 2009
racvon
SOURCE: How do I replace the cooling fan in benq pe8700
There's more then one fan inside the projector. I think I counted 3 when I opened mine up. Two are easy to get to, the other is underneath. on theleft side looking from the front. You have to take off the back surround cover in onder to remove the top cover. The top cover slides back and lifts up. Be careful because there's a wire harness running to the top cover control panel. Disconnect it then you have access to the fans. Wish mine was that easy to repair.
Posted on Apr 30, 2010
Dear Sirs, I have a BENQ PE8700 projector. I know it's outdated, but it still suits me fine. I've already changed the lamp, and this new one is 1000 hours old. I am recently having a problem:...
If the bulb on this projector is filament less then it may be a bad ballast. If it is that kind of a bulb the ballast is like the starter on a florescent bulb that excites the internal gases for light to be emitted. If it conks out, the bulb stops emitting light even though the cooling fan stays on.
Apr 30, 2017 | BenQ PE8700 Multimedia Projector
Won't broadcast in hi-def with component cables
I have a BENQ PE8700 also. Charter Cable just replaced my Hi Def Cable Box and now I only get the non hi-def channels. I get the sound on the Hi-Def channels only. My projector is hooked up with the DVI Cable. Did you ever find out why you were not getting HI DEF?
Aug 07, 2010 | BenQ PE8700 Multimedia Projector
How much is a power supply for the Ben Q PE8700 projector
Power Supply
100 ~ 240 V / 50 ~ 60 Hz
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 17, 2009 | BenQ PE8700 Multimedia Projector
Rest benq pe8700 projector
if the lamp comes on, hold the exit button down until the osd comes on. press enter, then the right or left arrow button to reset it, then the exit.
Oct 02, 2009 | BenQ PE8700 Multimedia Projector
BENQ VA321 REMOTE CONTROL
Hi there
A universal remote would do the job , as long as you make sure that the Universal Remote can learn IR codes which it uses to control the Projector.
Sep 25, 2008 | BenQ 98J2032B01 PE8700-REMOTE Projector...
BenQ PE8700
Apr 15, 2008 | BenQ PE8700 Multimedia Projector
BenQ PE8700
Rick
Give me a couple of days - I'm sending the BenQ factory in Malaysia a e-mail.
Apr 04, 2008 | BenQ PE8700 Multimedia Projector
BenQ PE8700
Hi there
I'm a approved BenQ Technician in JHB South Africa - and I've done this before.
Apr 03, 2008 | BenQ PE8700 Multimedia Projector
Benq PE8700 - Won't Power Up
Hi there
Trust me that the Mainboard needs replacement.
I am very familiar with the PE8700's as I am a ASP Technician for BenQ.
Visit www.BenQ.com and look for the link to your country - you should be able to allocate a Approved Service Provider.
Must warn you that the Mainboards on these models are quite expensive.
Mar 29, 2008 | BenQ PE8700 Multimedia Projector
BenQ PE8700 Multimedia Projector Logo
334 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
