Question about Minolta CF2001 Copier
ERROR CODE C0660
WHAT DOES ERROR CODE C0660 MEAN AND HOW CAN WE FIX IT
  • Anonymous Nov 26, 2008
    have same problem with 0660 how do i fix it?
    Scholar:
  • 141 Answers
This is a scanner problem, try the following...
C0650, C0660
Step Check Item Result Action
1 Scanner can be moved manually.
NO Correct drive coupling (Scanner
Belt tension, pulley operation,
drive cable tension)
2 Scan motion: initial scan motion after the
Power Switch has been turned ON or Front
Door has been opened and closed.
NO Carry out misfeed/malfunction
troubleshooting procedures.
3 Connectors are connected properly on
Scanner Motor Drive Board: PWB-IC
PJ1IC, PJ2IC, and PJ3IC.
NO Check connectors for connection.
4 Scanner Motor turns when the Start key is
pressed.
Change motor. Change
Scanner Motor Drive Board.
5 I/O check for Scanner Home Sensor: the
voltage across PJ6C-2 on Image Processing
Board and GND is DC 0 V (home position)
when the sensor is blocked and DC 5
V when the sensor is unblocked.
YES Change Image Processing
Board.
NO Check sensor for installation.
Correct detecting plate.
Check sensor connector for
connection. Change sensor.
6 “IR Area” check:
Malfunction when Power Switch is turned
ON after “Top Image” has been set to 0 and
“FD-Mag.” to 1.000.
Posted on Apr 05, 2008
Minolta CF900 error C0660 / scanner motor
It possibly you've got bad motor, it does'nt respond when you turned on the unit.
Feb 21, 2008 | Office Equipment & Supplies
RIM c0660
The best answer I have found (not my own) is from the AllExperts website which says:
Yes, the code means chassis C0660 Level Control Exhaust Valve Circuit Malfunction. There is a valve on the compressor, I believe on these cars the compressor is somewhere on the undercarriage, the valve may be cracked or leaking, the best way to test for this is to spray it with water, BUT as you said the compressor isnt working, the first place to look is of course the fuses, follow the electrical line to the compressor, test the voltage at the compressor. Check that the ground connection is clean, it may be neccessary to replace the compressor.
Ben Trigoboff - 12/21/2006
Apr 07, 2014 | 2001 Cadillac DeVille
Service ride control light on dic
First you need to have Suspention Control Module scanned to retvieve troube codes.
The common code is C0660 exhaust solenoid fault.
The exhaust soleniod in the rear suspention air compressor and is a common problem for having an open circuit internally.
The solenoid is not serviced seperate, will need an air compressor assembly if this is found to be the problem.
Mar 24, 2014 | 2005 GMC Yukon Denali
EP2030 Minolta error code C0660
Under the big glass to your right under that black cover is a lens assy., and mirror assy., something is jammed in there or bad motor. open front door upper left access cover remove cover touch trouble reset to reset machine.
May 08, 2012 | Konica Minolta EP2030 Fuser Thermofuse
I have code C0660
that would be the " exhaust valve circuit fault "
Feb 23, 2012 | 2004 Chevrolet Tahoe
My 05 tahoe is throwing an C0660 code what could cause this what should i look at to try an fix
co660 is with the level ride, the problem is in the exhaust seloniod valve, check the connection if it looks ok then the valve may be bad,the best thing is to have it scaned to find which of the four are bad.
Jan 25, 2010 | 2005 Chevrolet Tahoe
It is on the screen, c0660 what does it mean
hello
scanning problem, please touch the rest button under the cover of front!
Nov 04, 2009 | Minolta CF2001 Copier
What does error code c0660 relate to on the Minolta CF1501
Hello sir; Turn power off, remove the glass, push scaner unit for and back see have anything stock over there, otherwise you have to change home position senser.
Mar 08, 2009 | Konica Minolta DiALTA CF910 Copier
There should be a lamp regulator PCB check the fuse on it. Also, if you move the scanner out of HP will it find HP again? Also, how offten does it show up scines the last time?
Feb 20, 2008 | Office Equipment & Supplies
658 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
