Question about Lexmark Optra T614 Laser Printer
Optra T614 printer
I have a Lexmark Optra T614 printer. It has parallel and network on it. I have it set up as a network printer. When I have to print several pages (25 to 30). It starts out printing good and then slows down extremely slow. What could be my problem. Please email me back with your thoughts at:
gstewart@crstx.com
Thanks,
Greg
    Problem Solver:
  • 12 Answers
I had the same problem and it went away after i removed the main circuit board and reinstalled it. (left side of the machine)
Posted on Sep 16, 2008
How do i change the ip address of my printer ..i printed out the menu page and it list an old ip address that i can no longer access
From the operator panel saying "ready". Scroll through the menus to "Network Menu", then scroll to "Standard Network", then to "STD Net Setup", then "TCP/IP", then "Set IP Address". Once you make the desired changes (move through octets using "select" changing numbers using "menu"), make sure to save by pressing the select button until it says "saved".
Nov 14, 2013 | Lexmark Optra T614 Laser Printer
How do I print the meter page count on a lexmark t614,t612 and t520?
Use the following steps.
1. Press the menu button multiple times until you get to Utilities Menu.
2. Press Select.
3. Press menu until you get to Print Menus.
4. Press Select.
A Menu Settings page will print. Following all the menu settings a page count will be listed. This applies to all three models.
Jun 23, 2010 | Lexmark Optra T612 Laser Printer
PRINT HEAD ERROR
there are several different printhead errors 931 933 scanner motor died scanners bad. 932 934 935 are loose lock errors these can be caused by either the scanner or the engine board
Nov 09, 2009 | Lexmark Optra T614 Laser Printer
What is the default password for the Lexmark T614?
There is now default password. The default is without password. Did you try a cold reset?? Push and hold down butons 2,3 and 5 while powering on the machine. Release the buttons when innitialisation is on the display.
Gerrit jan
Nov 04, 2009 | Lexmark Optra T614 Laser Printer
What would cause a 900 RIP code on a Lexmark T612?
Go to http://support.lexmark.com/printerfirmware
Locate the appropriate authorization code for your printer model from the following list and enter it:
Optra S (4059) series printers: 4059engn.
Optra T610, Optra T612, Optra T614, Optra T616 printers: optrateng.
Lexmark T520, Lexmark T522, Lexmark T620, and Lexmark T622 printers: lextengn.
Lexmark T630, Lexmark T632, Lexmark T634 printers: e551416.
Lexmark W812: eng204
We recommend you choose to save the file within a directory on your computer's hard drive.
Once it has been saved, go ahead and run the file. The downloaded files are self-extracting ZIP files. Running this file will create a set of .PJL files and a file entitled Readme.1st. The Readme.1st file also contains directions for sending the file over through a parallel connection.
Oct 30, 2009 | Lexmark Optra T612 Laser Printer
Invalid engine code
The easiest way to solve this is to work through Lexmark Technical Support.
Their web site may have the correct engine code on their site, but installation of the code can be tricky.
Are you getting a 900 Invalid Engine code message?
Don
Apr 23, 2009 | Lexmark Optra T614 Laser Printer
Lexmark Optra T614 Won't accept toner cartridge
there is a smart chip on the right side top of the toner cartridge clean these 2 connections with thee green plastic brillow on the back of a sponge. just do this lightly. cleaning this should fix your problem
Apr 11, 2009 | Lexmark Optra T614 Laser Printer
T614 is printing very small 2inch by 2inch on 8x10 page
hold right arrow go and return buttons down and hold power the unit up ubtill you see activity in the dispply then release this will reset factory defaults and solve your problem
Jan 08, 2009 | Lexmark Optra T614 Laser Printer
Lines across page
My metric to standard conversions skills are poor. But if 10 cm is equivalent to about 2 inches it sounds like the drum on the cartridge has gone bad from inactivity. Change the cartridge.
Jul 02, 2008 | Lexmark Optra T614 Laser Printer
Lexmark Optra T614 Laser Printer Logo
167 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
