I have a nortel T7316E. i would like to turn my ringer off for outside calls but have the phone play a sound when someone in my office calls my extension.
If you're looking for specific instructions without reading the manual, good luck. I'll be happy to come over and do it for you. I get paid for programming.
You can't post conmments that contain an email address.
Have you tried to call the phone and adjust the volume on the set while the call is coming in? I think the only way you can adjust the ringer volume is if the phone is ringing.
I am assuming the page is over your set and not an overhead speaker. The setting is in the configuration programming of your system. Recieve page must be set to 'n' in the programming for your set. If you don't have someone within your company that has access to this programming you may have to call an outside party.
If the phone doesn't ring when called by the extension number of the phone then try to use the volume up button while someone is calling the phone. The volume is a multi-purpose button that doubles for phone volume and ringer volume. However, the only way to turn up the ringer is when a call is coming into the phone.
Maybe you set the Do Not Disturb by mistake. press "feature #85"
or maybe you call forwarded it. press 'feature #4" or turn up the ringer 'feature *80'
You can adjust the ringer of your Nortel phone by dialing Feature *6, then using the volume bar to adjust the ringer while the tone is playing, or dial Feature *80 to adjust it there.
MANY TIME A PERSON DIALS WITHOUT REALIZING THAT THE ACCEPTANCE CODE NEEDS TO BE INSERTED FIRST THE Nortel T7316E?...If you want to
temporarily turn them off use do not disturb (feature 85, feature #85 to
turn Do Not Distrub off) Turning off the ringing permanently will require you to program the set. Programming is done on M7310,...regards John
more than likely someone in your office left the message rather than the voice mail. to clear it press the call soft key below the screen. the screen should display who left the message with two of the soft keys labeled call and erase. press the erase soft key. it's possible the the person/s that left the message left multiple messages. in that case repeat the procedure til all messages are canceled
You have to go into programing to terminals and sets type in the local whos ring was turned off and turn back on . If you can,t get in to programing let us know.
You may need to change your Ring Volume. Here are some instructions on how to do so. To Change your Ring Type: 1. Press the Feature button, then * 6 2. Press the number keys 1 – 4 to hear the different ring types 3. Press the OK softkey when you hear your desired ring To Change the Ring Volume: 1. Press the Feature button, then * 80 2. Press the volume key up or down 3. Press the release key1 to exit and save the volume level
