Question about Galaxy Radios DX-2517 CB Radio
I was listening to my 25 17 on 11 meter which is band b and all of a sudden,it went to the standard 40 channels on band b and c and the other bands are off as well.
    Champion:
  • 219 Answers
Without looking at it and from what you're saying a crystal went bad in the radio.A crystal is what controls your channels or freq.
Posted on Jun 02, 2010
SOURCE:
Purchased a midland 75 785 from u s will it work on u k channels
  • For 11 meter (CB) the standard 40 channels will be the exactly same as the "EU" set of frequencies (channels). However the "UK" 11 meter (40 channels) and the U.S.A. 40 11 meter (40channels CB) will not work together at all. This includes any actual Citizen Band radio, excluding Export 10 an 12 meter radios often labeled as "CB'S" which they are not.
  • Hope this helps.
Oct 29, 2011 | Midland 75-822 40-Channels Handheld CB...
Midland 75 785 purchase from us will it work on uk channels
  • Hope this helps.
Oct 29, 2011 | Midland 75-785 Handheld CB Radio
I have purchase a midland 75785 cb isit compatable with uk chanels
  • Hope this helps.
Oct 29, 2011 | Midland 1001Z 40-Channels Base CB Radio
LOST MY MANUAL TO MY UNIDEN BEARCAT BC142XL CAN I GET A FREE REPLACEMENT
The manual isn't online to my knowledge however I did find a guide on how to program it.
"Turn it on. Push the "MANUAL" button to stop it from scanning.
Push number 1, then push "MANUAL" again. This should leave you on
channel one.
Using the keypad enter the frequency you want to monitor, then push
"E." Press "REVIEW" at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the LED readout
display, you might be entering an invalid frequency. Refer to the list
of acceptable frequencies in the Frequency Range Bands below.
Push "MANUAL" to step to channel number two. Enter the frequency. Push
"E." Push "MANUAL" to step to channel three. Repeat this process until
all the (10) channels are full, or you've run out of frequencies to
enter.
Push "SCAN" to start automatically scanning the frequencies. The
radio will stop when it hears someone talking, and resume scanning two
seconds after the conversation has stopped.
Frequency Range Bands:
20 to 29.7 MHz (10 Meter "Ham" Band)
29.7 to 50 MHz (VHF Low Band)
50 to 54 MHz (6 Meter Amateur Band)
136 to 144 MHz (Military Land Mobile)
144 to 148 MHz (2 Meter "Ham" Band)
406 to 420 MHz (Federal Government Land Mobile)
420 to 450 MHz (70cm "Ham" Band)
450 to 470 MHz (UHF Standard Band)
470 to 512 MHz (UHF "T" Band)"
http://newsgroups.derkeiler.com/Archive/Rec/rec.radio.scanner/2006-01/msg00174.html
Hope this helps.
Apr 22, 2011 | Office Equipment & Supplies
Why can't i listen to aircraft pilots & tower on my Uniden bearcat BC60XLT-1? Our airband frequency here is 108-137 mhz.
Your scanner does not receive frequencies between 54 and 137 MHz, and there's nothing you can do to enable reception in that block. Your only option is to purchase a scanner with air band coverage. Here are the reception ranges of the BC-60XLT-1:
29.0-29.7 MHz 10 Meter Amateur Band
29.7-50 MHz VHF Low Band
50-54 MHz 6 Meter Amateur Band
137-144 MHz Military Land Mobile
144-148 MHz 2 Meter Amateur Band
148-174 MHz VHF High Band
Above bands in 5 kHz steps
406-420 MHz Federal Government
420-450 MHz 70 cm Amateur Band
450-470 MHz UHF Standard Band
470-512 MHz UHF "T" Band
Above bands in 12.5 kHz steps
Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
Bill B.
Listening in since the 60's
Feb 26, 2011 | Uniden Radio Communications
What frequency do these run?? am or fm??
CB or citizen's band is in the 27 MHZ band. Its 40 channels long, AM typically, and on some models side band, or SSB.
It is only legal in the US to have a radio that operates in the 27 MHZ band on the designated 40 channels using AM or single side band only.
The MCB-30 is an AM only radio.
Mar 25, 2010 | Maxon MCB-30 40-Channels Base CB Radio
Please explain a 10 meter am/fm radio
Okay.
You do set this up like a regular CB. The meters refers to how long the waves are. CB is 11 meters. So its very close. The antenna woud be tuneds slightly shorter. Use the SWR meter in the radio to calibrate just like you would a normal cb.
Now for the ABCDEF knob. each letter is 40 channels in the band. So A would be 1 - 40 channels, then B would be the next 1 - 40 channel frequencies. You use the frequency counter in the radio(providing that model has one) to tell what channel you are on.
Here is some info one the frequencies in the band.
Now for AM and FM. this is the type of modulation you are using for transmit and receive.
CB transmits on AM or SSB. Amplitude modulation or Single side band. Most CB radios only have AM. But some also have SSB. None will have FM.
FM is frequency modulation.
10 meter radios can have AM FM SSB and DSB depending on the model and options it comes with.
So your radio has 6 ranges for freqency. each is 40 or 50 channesl. Not sure what model you have. If it has 40 then you have 240 channel freqencies.
with AM and FM, you double that, because you can talk on AM or FM on all the channels. If you are on AM and some one transmits on FM unless they are really close, you will not hear them at all, but if you do with will just be garbbled noise.
Also Am and FM both work a little different with range etc.
Now, you may be able to talk on the CB channels as well. Cb starts at 26.965 MHz and ends at 27.405 MHz. The channels are all .010 MHz appart.
Hope this helps
Dec 09, 2009 | Radio Communications
PROGRAM FREQ IN BC142XL
Its so easy to use you really don't need a manual for the Uniden BC
142XL scanner.
Turn it on. Push the MANUAL button to stop it from scanning.
Push number 1, then push MANUAL again. This should leave you on
channel one.
E. Press REVIEW at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the display, you might be entering an invalid frequency. Refer to the frequency coverage list below.
Push MANUAL to step to channel number two. Enter the frequency. Push E. Push MANUAL to step to channel three. Repeat this process until all ten channels are programmed, or you've run out of frequencies to enter.
Frequency Coverage:
For a comprehensive database of active frequencies in your area, visit
www.RadioReference.com
Nov 07, 2009 | Uniden BC248CLT Base Scanner
Information on how to use DX 45MP radio
The DX 45mp is a 10 meter radio meaning you need a license to use any other band other than the normal 1- 40 cb channels, its capable of going beyond the normal cb range.Ask if it has been converted to 11 meter. Channel E should be the normal if it has been converted from 10 meter to 11 meter. Im sure its been converted if its been used for a mobile cb application. Normal cb band is called 11 meter 26.965 mhz to 27.405 thats 1- 40 . Your not supposed to talk on the other bands unless you have an amature radio license but everyone does anyway . I have several galaxys and by far in my opinion are the best on the market. Go to www.cbtricks.com on the home page go to Radio Informaion click it go to G and follow it to Galaxy DX radios youll find all the info for this radio you can even print out the channel chart to see where everything is. Good luck and if you have any more questions just ask. Thank you Chia
Nov 05, 2008 | Radio Communications
How do I make it work
It depends on the channels on the walkie talkies.
Can you supply the frz range of the TRC, and walkie talkies make and model and I will try and get the frez on the channels for you.
I can then tell if it will work or not.
Apr 27, 2008 | Computers & Internet
Radio Communications Logo
110 people viewed this question
Top Galaxy Radios Radio Communications Experts
Marvin
Marvin
Mike Charette
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
