Question about Kenmore 94812 Top Load Stacked Washer / Dryer
Water keeps flowing - will not fill
The machine doesn't fill - water just keeps flowing
  • 5,911 Answers
It sounds like you have a siphoning problem. Double check to make sure you don't have the drain hose shoved down in the standpipe too far. 4 to 6 inches is sufficient enough when placing your drain hose into the standpipe. There needs to be an air gap in order for the washer to drain properly and to prevent the water from continually siphoning from the wash tub. DO NOT seal the top of the standpipe, either. Some people will do this thinking that it will help prevent overflows and/or get rid of any drain odors. It can actually cause problems. The standpipe should also be 2 inches in diameter, be a minimum of 34” from the floor, and should not exceed 72 inches in height. Post back if this is not the case and I will try to lead you in the right direction. I do hope this solves your problem.
Posted on Apr 03, 2008
yalmer
  • 552 Answers
SOURCE: Filling With Water
This is probably a control board failure, which should be replaced by someone familiar with them.
If you are handy, you can do it yourself.
If you need assistance, let me know.
Posted on Mar 04, 2008
  • 67 Answers
SOURCE: Low Cold Water Flow into Machine
the water inlet valve has to be replaced,its the part where you seen the screen ,where the hose hooks up to,theres a cylinoid that opens and closes and lets the water come in,your cylinoid is no good,but you change it as one unit,and its called water inlet valve,easy fix you can do your self,if this helps please vote me a fix ya
Posted on Jul 15, 2008
  • 686 Answers
SOURCE: kenmore 110-20932-994 overfills with water (keeps fillilng)
for your model you have a water level control switch which does have a tube and it operates on air pressure from the weight of the water in the tub. when the air pressure in that tube reaches it's limit whether it be small med large load the switch tells your water valves to shut off. yours is not doing this. By removing the back you can see this tube. follow it up into the control panel and replace it or maybe it even needs adjusted. Either way the problem you have is with this switch.
Posted on Apr 03, 2009
Maytag317
  • 1136 Answers
SOURCE: water won't stop filling washing machine.
Hi, Will the water shut off if you turn the timer off or unplug the washer?
If it shuts off when power is turned off to the washer, you need to look into the water level switch. If turning off power to the washer will not stop the water, you need to change the inlet valve.
Please let me know so I can assist you further.
Thanks
Vic
Posted on May 30, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool heavy duty super capacity plus machine slow to fill.
This problem is commonly attributed to a water inlet valve that has become clogged with sediment or calcium deposits over time. If you live in an area that has hard water, or if you use well water, this is a common problem. You can remove the valve and attempt to clean it by soaking it in a 50/50 solution of distilled vinegar and water, or you can simply replace it all together. If you're going to go the route of removing the valve, it makes better sense to replace it, rather possibly having to repeat the steps again if cleaning the valve doesn't work. The following link explains how to access and replace one:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
I have found these sites to be reputable and provide great service. Prices differ between them, so shop and compare. If you do not wish to order parts on line, look up the part numbers on the Sears site and check with your nearest appliance parts retailer. These is a common part that may be commonly found in their in-store inventory. The average cost is about $30 - $35.
If you DO wish to attempt to clean the valve to save some money, submerge the valve in a 50/50 solution of distilled vinegar and hot water for about 30 minutes and flush with clean water. DO NOT submerge the electrical connections.
You may also try any number of calcium, lime and scale removers on the market. CLR comes to mind as a good product, but use in a well ventilated area. It has some very strong fumes.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Posted on Mar 18, 2010
Testimonial: "Great advice. I will follow your clear and easy steps. Sounds like one or the other solution will be fine."
Maytag Epic FH Error
follow this steps .God bless you
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
Jul 22, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Hot water keeps filling tub and does not quit
the washing machine is designed with a timer limit switch have the switch checked.
Oct 19, 2012 | Samsung WF448AAW 4.5 cu. ft. Front Load...
Doesn't fill
Possible that the water level sensor is faulty as it tends to indicate before the level has reached thereby starting the rinse cycle.
Usually this can be due to faulty level settings or fault in the pressure switch as it can be acting too fast. It will be best to clean the inlet valve and check the flow , test the water level sensor and see if this works by blowing into the diaphragm.
Sep 04, 2012 | Kenmore 2942 400 3.2 cu. ft. Top Load...
Water won't stop filling
If the water still flows in when the machine is off the inlet solenoid is faulty, if when you push start it fills and keeps filling then the problem will be with either the electronics or the pressure switch.
You really need to get someone who has experience with whirlpool machines to look at it for you.
Mar 08, 2012 | Whirlpool Washing Machines
My tank on my nouva simonilli Program machine keeps filling even with no power to the machine. I thought it might be the valve just after the pump (looks like it needs a certin pressure to open the valve...
There are 2 1/4 turn valves under the black safety cover under the drain tray, make sure the one closest to the inlet solenoid is turned off. If that is off and water still flows into the boiler then one of the exchangers might be damaged.
Sep 20, 2011 | Nuova Simonelli Program VIP Coffee Maker,...
Water keeps running, toilet not shutting off totally, tank will fill then we have to pull up float and hold it a while to stop water, doesn't overflow, just keeps running, doesn't shut off...
Hi snowjobs847...
Try resetting your float level to a lower water level in the tank, the extra pressure put on the seal may make it reseal.
If the above did not work:
You need to replace your "ballcock"...the ballcock (inlet valve) is non-repairable, has to be replaced with a new one if you cannot get it to stop leaking.
Please take time to rate me
Sep 04, 2011 | Home
My machine is not aggetating it just keeps filling with water
if the water is not over flowing on the floor.make sure your washer is off,then pull the drain hose up to the level of the back control panel you should here water flowing out once this stops.keep the hose up for aminute and restart your waher and it should fill up to the proper level and shut off and start washing
Sep 26, 2009 | Maytag Legacy Series Top Load Washer
Help
This should be a problem with the fill valve.
They are usually not very expensive.
Find your model and serial number for your machine and call an appliance parts store.
They should be able to give you a price or you can find one online.
Apr 17, 2009 | Washing Machines
Kenmore 94812 Top Load Stacked Washer / Dryer Logo
82 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
