Question about Nikon D40x Digital Camera
Doesn't power up
Got the d40x for just more than a month now. then suddenly the camera doesn't power up, checked battery, recharged the bat. pressed the reset button, still there's no effect. help..gettin frustrated!
  • 2 more comments
  • lynxlady May 17, 2008
    I've had this camera for almost a year. I have the same problem - it was working 2 weeks ago, but now it won't turn on. I've tried with a different battery, different memory card and tried the reset button several times. help!
  • cape5151 Jun 01, 2008
    same thing. no power from a charged battery. reset doesn't help.
  • tran63841 Jun 16, 2008
    I had the same problem over the weekend. I found that if you turn the camera upside down it would power up but if you invert it back upright, it powers off. I tried checking the lens mount and its secure, tried putting on different lens and the problem still exist. Camera would power on in certain positions but not others. Finally I got fustrated and gave it a good "wack" between two hand and its working properly. However, I still get that power problem once in awhile but its fixed by "slaping it around abit." So trange, I will continue to narrow the problem unless someone else has anything to contribute.
  • gadams54 Jul 04, 2008
    Had the camera almost 1 yr and exactly the same problem. Any solutions?
Sme issue here. Camera is less than a month old.
Posted on Jun 09, 2008
How to reset sony dsc-w90 to factory setting
Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESET button or Initialize option in the menu. These cameras require a manual power reset.
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product.
Follow the appropriate procedure below for your camera. Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button:
Locate the RESET button on the camera.
Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset:
Turn off the camera.
Remove the battery pack.
Remove the button-sized lithium battery.
Allow the camera to remain without power for 30 seconds.
Reinsert the button-sized lithium battery.
Reinsert the battery pack.
Turn on the camera.
If your camera is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required.
Hope this helps.
Oct 07, 2011 | Sony Cyber-shot DSC-W90 Digital Camera
What do I do when my camera says,
If resetting the camera with the reset-button won't help, you have to take it to the authorized dealership for repairs.
Jun 03, 2010 | Nikon D40x Digital Camera
My Nikon D40X shows an Error for the shutter release. It says "Error. Press shutter release button again." When I push it again, it keeps giving me the same error. Is there a way to fix it without sending...
Hello. I have the D40X myself and I have had success by going into the menu and locating the reset button. What this does is return the camera to the settings that it had the day it came out of the box. Joe
Feb 14, 2010 | Nikon D40x Digital Camera
Hi there, my Nikon D40x flash suddenly stopped working (popping up but not flashing) after I was fooling around with the manual settings, now no matter what I do the "no flash" icon appears beside the...
Try turning camera on,
Then press both Green buttons for a count of 10. This should restore factory reset.
Some models also have a reset button under a connector flap, or go into your menu. Under Custom Setting Menu, choose Menu Reset.
One of these methods should work.
Sep 22, 2009 | Nikon D40x Digital Camera
Camera wont turn on My Nikon D40x wont turn on at all, i have been using it, then plugged it in the my laptop with the USB cable, unplugged it to take more pix, and it now wont turn on at all!!
Just a suggestion ... remove the lens, card and battery. Recharge the battery completely. Install the lens, card and battery then do a hard reset...
Hard Reset:
With D40 you need to install the lens, the card and the battery then open the cover under which USB and video sockets are. There is a small button in the hole. Press it with pencil tip or something and the camera will be reset losing all settings and clock time.
May 28, 2009 | Nikon D40x Digital Camera
Camera powers down when pressing shutter button
I see this frequently on the E900. Every time it has been a battery issue. If you're using rechargables (the E900 came with batteries and charger in the Canadian market......not sure about the rest of the planet), they may have just worn out over time. Replace with new NI-MH (nickel metal hydride) rechargeables. If you're using throw-away AA's, try Energizer Ultimate Lithiums. I've solved many, many E900 shutting off problems simply by changing the batteries to Energizer Lithiums.
May 27, 2009 | Fuji FinePix E900 Zoom Digital Camera
My D40X won't turn on!
It is required to solder a main pcb.
Dec 05, 2008 | Nikon D40x Digital Camera
NIkon D40X LCD not displaying
Push ring circling OK button to up or down positions and LCR display will change showing info or image.
Dec 03, 2008 | Nikon D40x Digital Camera
Camera not functioning
There is a reset hole under the cap the covers the USB connector.  Use a straightened paper clip to gently press in and it should reset the camera.   I hope this works.
Apr 12, 2008 | Nikon D40x Digital Camera
Nikon D40x Digital Camera Logo
150 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
