Question about Epson Stylus Photo RX600 All-In-One InkJet Printer
Epson Printer problems
I had to reinstall my printer due to some hardware issues. Now I am not sure I have the correct port. I am unable to print at all.
  • Anonymous May 20, 2008
    Computer says cannot find plug&play.
  • Rajkumar Bordoloi
    Rajkumar Bordoloi May 11, 2010
    how do you connect to cpu.cable specification please
    Problem Solver:
  • 12 Answers
Well i'm not sure waht is your issue,
but you can try to check this out
If you are using win 2000/xp/
and usb cable connection/interface
after you installed the drivers from the cd software or from epson website http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp
click on start>> control panel>> printers and faxes>> right click on the printer icon(epson stylus?)>> properties>> ports>> select usb001 virtual printer port for usb...
well... sory if i misunderstand you
good luck!!!
2.
Posted on May 09, 2008
SOURCE:
Problem printing with IBM 4610 TF6
It can be a connection problem, since the printer and the computer are not communicating, probably the cable is bad, so if you have a different cable that we can try that will be better so we can check if its only a cable problem ...
Hope that helps......
Aug 28, 2008 | IBM 4610 TG4 Thermal Label Printer
Epson printer is not printing correctly
Reinstall driver first if problem is still then change data cable to solve the problem
Sep 28, 2014 | Epson P50 Inkjet Printer
Cannot print from command prompt - Epson U220D Windows 7 32-bit New parallel port with driver New centronix to parallel cable Epson driver APD_455dE (I was using Windows 7 64 bit with a...
The Epson works fairly well with XP. It is to be connected to
a parallel port, usually LPT1
using an IEEE certified parallel printer cable. The computer BIOS
setting is best set for standard parallel port, SPP, bi-directional port
or similar. If possible, do not set it to ECP or EPP or ECP & EPP.
The only native driver for the printer is on the Windows CP CD. Install
using the Add Printer wizard.
The Epson LQ-860 drivers, and a few others, can be used. Using these
drivers, you will discover that the printer actually has some resident
fonts (in printer ROM) that are not accessible from the Stylus
driver. However, with this driver, graphics printing quality is
compromised.
Windows 9x drivers _cannot be used_.
Let us know.
Tom
MSMVP
Windows Shell/User
"the_best_of_fools" <[email protected]> wrote in
message news:[email protected]
:I have an Epson stylus color 600 I can't get to work with Windows XP.
This
: printer worked fine with my old Mac.
: I've tried everything I could and nothing is working. The printer is
: connected to
: the computer via parallel LPT1 port. I've installed the WindowsXP
resident
: drivers
: for this printer model (the Epson drivers are too old and not
verified). The
: computer doesn't detect the new hardware with Plug and Play when
turned ON
: (don't know why) so I had to manually Add Hardware (Printer Port) with
the
: Hardware Wizard. I'm not sure how to recognize if the LPT1 port is
active or
: not and set up properly in the BIOS? I read something about having to
set the
: parallel port to ESP or ECP depending on the printer's requirement
(which I
: don't know) in the BIOS?
: Everytime I send a test page or print from a command prompt or WordPad
: nothing happens for 1-2 minutes and then I get a "Printer Out of
Paper"
: message in the pop-up. Of course, the printer has enough paper (and I
can
: print a sefl-test page from the printer). I also tried with another
parallel
: cable and it still doesn't work. I've tried uninstalling/reinstalling
the
: printer's driver many time and it's still not printing.
May 13, 2014 | Epson TM-U220D Matrix Printer
Epson printer cannot print
Sir/Madam
To resolve this problem, you can disable the Printer Preview option:
  1. In Control Panel, double-click Printers and Faxes.
  2. Right-click the Epson printer, and then click Properties.
  3. On the General tab, click Printing Preferences.
  4. On the Main tab, click to clear Print Preview.
Or Go To Welcome to Epson Support
I Hope You able To fix your Epson Printer problem,In Case your Epson Printer not Solved Then I Suggest You follow Us On:
Epson Printer Support
Jun 09, 2011 | Epson Office Equipment & Supplies
My C64 prints Black but not Colors. Even after I put in new color cartridges. Is there a way to test the color nozzle?
Issues in color printer are many. The most common one is the non-printing of color prints. This issue might be due to corrupted or incompatible drivers in your printer. When the driver installed in a color printer is corrupted or not installed correctly it might lead to issues. So in order to solve this issue you need to install or replace the corrupted driver with a new powerful driver; or reinstall the driver since the issue might be due to wrong installation of drivers.
Jan 31, 2011 | Epson C64 InkJet Printer
I NEED THE PRINTER DRIVER FOR ePSON TM-P2.01
Driver related problems can be solved by using this program Driver Update (including your epson driver files). Wish you best of luck
Chris
May 12, 2009 | Epson TM-U220 Matrix Printer
Won't print
Try to follow these steps to fix this problem:
1. Cancel the print job from the computer and from the printer.
2. Click the Start button, then select Control Panel.
3. Select Printer or Printers in the Hardware and Sound category.
4. Right-click on your printer and select Printing Preferences.
5. Click the Utility tab.
6. Select Speed & Progress.
7. Click the Always spool RAW datatype checkbox.
8. Click OK to close the Speed & Progress window.
9. Click OK to close the Printing Preferences window.
10. Right-click on your printer and select Properties.
11. Click the Ports tab.
12. Make sure the correct printer port is selected, then click Configure Port.
13. Click the LPR Byte Counting Enabled checkbox.
14. Click OK to close the Configure Port window.
15. Click Apply and then Close to close the Properties window.
16. Restart the computer.
take out the inks and check to be sure they are not dried up, they usually dry up easily. Shake the ink cartridges and replace them. be careful when shaking them so you don't spill inks around.
If this fails to work, try to uninstall the printer and reinstall it again.
May 06, 2009 | Epson Stylus Pro 3800 InkJet Printer
Communication error between Epson Printer and iMac
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 27, 2009 | Epson Stylus Photo 1400 Printer
Spooled documents get deleted
Jan 07, 2009 | Epson LX-300+ II Matrix Printer
Epson Stylus Photo RX600 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
