Question about Sharp AR-M237 Copier
Sharp ar-m237 default username and password
When logging into the printer via IP address and clicking on the "network scanning" link under scan management I get prompted for a username and password. What are the default admin username and password?
thanks.
  • Anonymous Mar 26, 2014
    default password
Admin
Sharp
Posted on Apr 04, 2008
    Guru:
  • Sharp Expert
  • 62 Answers
Actually I know this is very old but the username has to be all lower-case
admin
The password is Sharp with a capital S.
Copier Collin Houston TX Copier and Imaging Expert
Posted on Feb 09, 2015
SOURCE:
Sharp AR-M257 clearing user names in scan feature
Please log in machine with you browser with machine ip address
and user name and password is admin and Sharp and go to address book and remove anything you do not want.
Dec 04, 2013 | Sharp AR-M257 Black and White Copier
How do I change the IP address for the scanner on a Sharp AR-M237 multi function
Custom Settings/Admin mode/ passworrd 000000 print settings/ network settings
Aug 27, 2010 | Sharp AR-M237 Copier
We cannot scan to email from our Sharp AR-M237 Multi-function "Error[973]: Incorrect format for Primary SMTP Server." I am using all the settings for SMTP that I use everywhere else. HELP?-pjm
Model AR-M257 - I have several Sharp MFP devices at different locations and all are set up to scan through our email server using a special account I have just for this purpose. I have all of them setup using the external IP address of our Exchange server (not its name or FQDN) and I have firewall rules setup to allow SMTP from the WAN IP addresses of our different offices to the LAN IP address of the Exchange server. It worked at all the others but this one. I was getting the following error when trying to send a status message (under Log) from the device to my email account as a test: [error 973] incorrect format for primary smtp server. And when I tried to scan through our email server I would get "network error". However, a connection test succeeded. I had everything set correctly for SMTP and DNS but as I was trying anything I could to get it working I went to mDNS under Services and it was enabled. I disabled it and then I could get a status message to be sent to me and we could send a scan through our email server.
Apr 12, 2010 | Sharp AR-BC260 Color Copier
AR-M237 PRINTS BUT DOES NOT SCAN
You may have a problem with the physical board connected to the machine, try re seating the card with the machine off and unplugged. Its a data issue over the network, it may be the board itself. Try re seating it first.
Mar 23, 2010 | Sharp AR-M237 Copier
When trying to scan to the network, getting "network error"
If everyone but this computer works, sounds like there may be a problem with the software on that computer. I would first uninstall and then reinstall the drivers for your copier on that computer...
Hope that helps...
Lbcoaster
Feb 16, 2009 | Sharp AR-M550N Copier
Xerox 7328, error 018-543 Shared name error in server
Prerequisites:
  • The printer must be connected to the network.
  • The IP address of the printer is required.
  • The HTTP option must be enabled on the printer. To obtain the IP address or to confirm if the HTTP option is enabled, print a Configuration Report. See the Related Items below for additional information.
  • A user account for the scanner must be created (account needs full control access rights).
  • A directory to be used as a repository for the scanned files must be created. The directory must then be shared.
  • The Hostname of the workstation must be known.
Scan to File is set up in several steps:
  1. The first step is to make sure the scanning service is enabled on the printer.
  2. The second step is to set up the scan file repository.
  3. The third step is to create any necessary templates.
  4. The final step is to configure the template with the required settings.
NOTE: This solution assumes Microsoft Internet Explorer is being used as the web browser. Other web browsers may vary.
  1. Make sure the SMB port is enabled. Print a Configuration Report to verify this setting. See the Related Items below.
  2. Open an Internet browser window.
  3. Enter the IP address of the printer in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services window will be displayed.
  4. If prompted, enter the username and password in the fields provided, and then click [OK].
    NOTE: The default username is "11111". The default password is "x-admin" and must be entered in lower case letters. If the username or password has been modified or forgotten, contact your System Administrator.
  5. Click on the [Properties] tab. The Properties options will be displayed.
  6. Click on the [+] next to Services on the left side of the window to expand the options.
  7. Click on the [+] next to Network Scanning.
  8. Click on [File Repository Setup]. The File Repository Setup window will be displayed.
  9. Click on [Edit] in the Default File Repository section. The File Destination screen will be displayed.
    NOTE: A maximum of five file repositories may be configured. Generally, just the default repository is configured for scan to file.
  10. Select [SMB] from the Protocol menu.
  11. Enter a descriptive name in the Friendly Name field.
  12. Enter the IP address or Hostname of the computer where scanning will be setup in the Hostname / IP Address & Port field.
    NOTE: The default SMB port is 139. Generally this port number does not change.
  13. Enter the Share name in the Share field.
  14. If necessary, enter the scan path in the Document Path field.
  15. Click on the [Prompt at User Interface] or [System] radio button from the Login Credentials to Access the Destination section.
  16. Enter the scan user name in the Login Name field.
  17. Enter the scan user password in the Password and Retype Password fields.
  18. Click on [Apply]. A “Settings have been changed” message will be displayed.
  19. Click on [Reboot Machine]. A "Do you want to reboot?" message will be displayed.
  20. Click [OK].
  21. Close the browser window.
  22. Test scan to file using the default template. See the Related Items below.
  23. If necessary, create scan templates.
Dec 16, 2008 | Xerox WorkCentre M128 Copier
IP Address on a Sharp AR-M237
The easy way to do it is to set the copier up for AUTO DHCP.  That way the copier will connect to the router and assign a free IP address to the copier.
Then go into internet explorer and type in the ip address of the copier.  If you can get a control panel screen of the copier to appear.  It worked.
Once you get the IP address, take it off of AUTO DHCP and type in the IP address that the router assigned to the copier.
Oct 16, 2008 | Sharp AR-C270 Color Copier
Sharp AR-BC320 Scanner Setup
login to the copiers web interface (the ip address of the printer ex: 192.168.XX.XX) you will see Network Scanning. Here you can change all the scanning e-mail options.
Aug 11, 2008 | Sharp AR-BC320 All-In-One Led Printer
Sharp AR-M237 Copier Logo
18,633 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
