Question about Gucci 3905 YA039517 (23934)
Running slow chang battery but the time is still running slow.
Casio wave ceptor hands running 8 minutes slow. Digital clock showing correct time. Hands 8 minutes slow even if I change time manually.
You may need to recalibrate the hands. Sometimes the hands are out of sync with timekeeping. Go to the Casio website, download the manual for your model, and follow instructions for resetting the position of the hands (might be referred to as zeroing or recalibaration).
May 30, 2016 | Casio Watches
I have a fossil ES-1355 watch and it running slow. I installed a new battery and still running slow. Is there an adjustment I can make.
most batteries that run of a battery are controlled by a frequency crystal or electronic setting and is not adjustable
however take it to a watchmaker or jeweller as it may be adjustable using their instruments
May 15, 2016 | Fossil Watches
Time is slow and stops
you either need a new battery or the watch is junk, if you get the battery changed out have them test the movement to make sure you dont walk out and have the same problem.
Aug 03, 2010 | Watches
Watch erratic. Slows suddenly between days of working well.
Sounds like a failing battery to me. Its very common for a watch to loose time when battery needs to be changed.
Jan 09, 2010 | Timex Watches
Eddie bauer watch runs slow
This usually means the battery is dying. Usually the backs on these are very tight, and the back has to be taken off to replace the battery. You might be able to get the back off without damaging the watch, but you probably will not get it back on without breaking the crystal. Best thing to do is take it to a reputable watch repair place or jewelry shop and have them replace the battery for you. Before they begin, make sure they are willing to replace the crystal for free for you if they break it!
Aug 06, 2009 | Watches
New watch is losing 5 to 15 minutes a day
This could be that the battery is slow. Newer swiss watches have a indicator in the movement of the watch that makes the sweep second hand skip every few seconds to indicate that the battery is slow. On regular japan made watches the watch just simply starts slowing down. Your watch could be new but the battery in it could have a long shelf life.
May 11, 2009 | Kenneth Cole KC1104 Wrist Watch
Tropby radio controlled watch, runs slow, even with new battery
Your watch is need to clean an replaced the old oil in gear shafting that is the common problem of a watch when the old oil is sticky already thats makes the gear moves slowly and your watch is always late . If ever your watch was already clean and replaced new oil and still working slowly then the problem is in the circuit board is near to run out its needs to replaced whole circuit board so its better again. I know this because im a technician in Rolex service center before. Feel free to ask whatever the result.
Hope it may help you;
Jan 30, 2009 | Bulova Watch
Setting the time
Dear Sir,
It appears that the watch was malfunctioning which I thought was due to a change of battery being required.
(It was running slow and giving the wrong time - so my mother told me)
I subsequently found instructions for the watch on an internet site, changed the battery and the watch is still failing to set to the U.K. time zone therefore, I deduce that it is a failure in the watch rather than the need for a new battery or ranything I have or have not done.
Please delete my question from your system
Thank you.
Jan 17, 2009 | Bulova Watch
Gucci 3905 YA039517 (23934) Logo
Top Gucci Watches Experts
Lawrence Oravetz
John mullen
Are you a Gucci Watch Expert? Answer questions, earn points and help others
