Question about X2Gen MG19MY 19" LCD Monitor
X2gen 19" monitor
The power goes off without warning and used to come on again if you wiggle the cable, but now nothing happens. It has a power cable with a transformer on it, so I don't know if its the cable, the transformer, or what. Also, is it worth repairing, or could I somewhere get a new transformer?
Power went off at monitor. The power supply has power to it as evidenced by a lighted LED but LED on the monitor is not lighted.
  • 1 more comment
  • lesweil Apr 04, 2008
    There are two separate cases listed above. The first four lines of the above post were already on your web site having been posted by someone else having a different but similar problem. My problem is that the monitor just shut down unexpectedly and will not power on again. I checked the power available at the end of the power cord that plugs into the monitor and it showed 11.17 volts. The power supply is listed at 12 volts output. I don't have any idea how critical the voltage is. I hope this additional information will help solve my problem. Thank you.
    Thanks for your suggestions Eske. I will order a new transformer and see if that solves the problem. I will let you know.
    Les
  • lesweil Apr 13, 2008
    Hi, I have received the new transformer and will give it a try at first oportunity. I will keep you posted. Les
  • 19,396 Answers
It is not a power supply problem 11.17 volts on 12 volts is ok, the monitor supprts a range of over 2V difference.
If it is faulty female power slot on monitor, it would go on and off randomly or when moved, or not turn on at all.
If the monitor goes off immediately then is a short, or a lose contact inside, or a fault on the monitor board.
If the monitor goes off approssimatively always after same time (eg.15/20 mins) than may be overheating, some job may be done on the board in this case.
Posted on Apr 13, 2008
    Sergeant:
    Champion:
  • 427 Answers
If it was me, i would buy a new transformer, if the problem still occured, then i would return it. The monitor may be haveing hardware issues with its power supply.
  • 563 Answers
Hi there
If there is power on the transformer , then it must be the part going into the screen.
It will be cheaper to have it repaired !
Check if your warranty is still valid
Posted on Apr 04, 2008
  • 813 Answers
Hi friend
i think ur bord or some capsitor are gone bad or your monitor smps gone bed so go with a good technision to repair it
  • X2Gen Master
  • 13,433 Answers
I would recommend geting a new transformer, althought its possible that there is a connection loss somewhere in the middle or then it would require replacement parts, does the transformer have a power light on it?
Shouldnt cost alot, checking.
My monitor won't come from sleep mode?
Have you tried another monitor, the issue pretty much sounds like is from video signal. pc video card adapter!
Apr 18, 2013 | X2Gen MG19MY 19" LCD Monitor
Shaded areas on my X2gen 19 inch monitor do not Show up.
It sounds like the PC video color setting is at 16 instead of 24 or 32 bit color setup. You need to check the display properties setting on the PC (Right click on the desk top). Also try it on other PC and also check the VGA cable.
Apr 07, 2010 | X2Gen MG19MY 19" LCD Monitor
Screen comes on for 2 seconds and goes black again - have tried unplugging all cables. All are secure.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 13, 2009 | X2Gen MG19MY 19" LCD Monitor
Screen goes blank. power off/on screen comes back. good for a few minutes. repeat !!
There might be problem with your power cable. It may be lose or it may make contact to the wall. Fix it you ll be alrite. If you find it useful rate this!!
Aug 17, 2009 | X2Gen MG19MY 19" LCD Monitor
Screen goes black but power light stays on
Hello. I had the same problem with my X2gen 19" (model MW19R)monitor. In my case, the monitor would turn off after 20 seconds or so but the blue power light would stay on as well. I had to replace a high voltage capacitor located in the backlight power supply board. There are 4 blue capacitors on the board which are identical and they are marked as 27J 3KV. Fortunately, I only had to replace one of these capacitors ( it was turning a yellowish brownish color ). Hope this helps.
May 30, 2009 | X2Gen MG19VT 19" LCD Monitor
No video on monitor
There is need to restart the system in safe mode.
1- When you turn on the system then press F8 for boot system in SAFE mode.
2- select 1152 by 864 pixels in the settings tab of display properties.
3- Restart the system again but not use F8 key while reboot the system.
May 01, 2009 | X2Gen MG19MY 19" LCD Monitor
X2gen mw19u 19'' widescreen monitor going black
Try your monitor cable connections on both your pc and into your monitor.
Make sure they are TIGHT and level.
Also, it could be your video display card is faulty or your video display drivers are corrupt.
Try setting your desktop to a lower resolution, like 800x600 and see it that helps.
Nov 19, 2008 | X2Gen MG19MY 19" LCD Monitor
I have 2 identical monitors that i use for my studio
They are sitting right next to each other?
sometimes you have to space electronic out, due to there out put... if they are really close to each other try moving one and see what happens.
hope this helps
Jun 05, 2008 | X2Gen MG19MY 19" LCD Monitor
X2Gen 19 inch LCD Monitor problem
Its the problem of the main display board. Not the SMPS. There will be another board inside. You have to replace the board or If some body may fix if you have spare parts of the board.
Apr 11, 2008 | X2Gen MG19MY 19" LCD Monitor
Need new power cord for x2gen monitor
You should be able to go to any local store like BestBuy and pick up a power cable. The monitor uses the same power cable as a Desktop PC.
Here is a picture: http://www.cablestogo.com/product.asp?cat%5Fid=914&sku=03129
Mar 14, 2008 | X2Gen MG19MY 19" LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
51 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
