Question about LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher
LE light on...not filling with water.
Exactly one year old today! Not filling with water...some water in bottom of dishwasher. Gets hot and LE light comes on. Help.
    Novelist:
  • 184 Answers
ACCORDING TO SERVICE MANUAL, THE "L.E." ERROR CODE SUGGESTS A LOCKED ROTOR ON THE WASH MOTOR. CHECK THE WASH IMPELLER FOR A FOREIGN OBJECT. IF IT SPINS FREELY, CHECK THE WIRING TO THE WASH MOTOR FOR LOOSE CONNECTION.
THE L.G.HAS HAD A HISTORY OF MOTOR PROBLEMS.
YOU SHOULD BE ABLE TO CANCEL THE PROGRAM AND DRAIN OUT THE WATER.
Posted on Apr 03, 2008
Water won't flow into the dishwasher
It depends how old your dishwasher i. If it is more than 18 months old and gets heavy use then grease and food debris can block the internal pipework. You can manually fill the dishwasher and use a dishwasher cleaning bottle that can be bought from most supermarkets. Run it on the hottest setting possible with nothing else in the dishwasher. Also remove all the filters and strainers from the bottom of the dishwasher and wash these by hand using hot soapy water. Do not put back into dishwasher until the cleaning cycle has finished.
This may work but if the pipes are too badly blocked then the dishwasher will need to be stripped and the pipes cleaned by hand
Aug 04, 2013 | Samsung Computers & Internet
My Asko dishwasher is not producing water
Hi, Welcome to FixYa. Based on your description that the dishwasher is indeed filling with water but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump. First though, do you hear a quiet sound ( it will be super quiet if the wash impeller is broke so you have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver ) of a motor once the unit has completed filling with water ? If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump...but not likely. Let me know what you find and I'll try and help you move forward from there. Good luck, Macmarkus :)
Aug 02, 2010 | Asko D1796FI Built-in Dishwasher
Clean light is blinking. Services manual says:
No all you do is press
Normal-Wash, Heat Dry, Normal-Wash, Heat Dry,Normal Wash, Heat Dry, Normal Wash, Heat Dry
Then all the bottons light up
Don't press anything wait a few minutes and it will work again
I know because today we just had this problem and did this from looking it up online,
Nov 22, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kemore Elite Dishwasher Spews Water When Wash Cycle Begins
After further inspection of my dishwasher I found a bad gasket under the lower wash arm. Over the years it finally gave up and was shooting a torrent of water through the water in the bottom of the wash tub. When all that water hit the door liner it went up into the lower door vents, into to wire harness, and onto the floor.
Sep 06, 2009 | Kenmore 24 in. 16352 / 16354 / 16359...
Maytag diswasher won't spray water
water level/float switch is stuck. (dishwasher is getting a indication the unit has enough water in it to operate)...repair/replace float switch, located in front right corner under bottom rack.
clarkco
Feb 28, 2009 | Maytag 24 in. MDB9750AW Dishwasher
GE Natulus will not fill with water
Had the same problem with ours today. That's why I got on here. My dad used a gallon jug to prime it with a gallon of hot tap water. We primed it to get it pumping, and now it is working fine. Just pour the hot water into the dishwasher and start it.
Nov 19, 2008 | GE Nautilus 24" Built-in Dishwasher
Sounds like dishwasher is running but no water coming out (there are no broken pipes or leaks)
I had the same problem. The motor is working (humming) and my dishwasher goes through the whole cycle without water. I googled it and found it on a website. Sorry I don't remember which website. Basically, it said to put some hot water in the bottom of your dishwasher and add some citric acid. I added 2 small packets (2 oz each) and filled the bottom of the dishwasher with hot water until it covered the motor or the drain of the dishwasher and left it overnight. The next day my dishwasher started and ran perfectly fine. That was over 4 months ago and I have not had any problems.
Mar 24, 2008 | Dishwashers
MayTag Dishwasher Quiet Series 300
If it is not filling enough, you may need a new water valve. It may be plugged.
Nov 19, 2007 | Dishwashers
LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher Logo
190 people viewed this question
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
