Question about Whirlpool LGV4634JQ Gas Dryer
Gas dryer/ whirlpool
Hi my dryer is heating up , it is exhaling hot air via the exhaust hose but the clothes are not drying. I replaced the hose last week , also a technician diagnosed the lint build-up in the vent between blower and lint filter, that lint was removed. So it is spinning, heating but not drying could you help me thanks Debra
  • 3 more comments
  • mialily May 09, 2008
    where are the valve coils on dryer model # LGR4634EQO Whirlpool dryer located, and btw ty aborcass i havent yet fixed it the only prob would be to get at it which you said to be easy ty deb
  • mialily May 13, 2008
    Good Morn Aborcass,
    I have one more question, my dryer that may need a new vaLVE COIL IS A 1990's model ancient so i am trying to get by the snaps and rivets what would be the best access to this area siiince i am not seeing any visible way to go through the front i have semi kind of got the top off. I am trying to avoid having to disconnect gas pipe or is that impossible? ty friend
    Hello again Aborcass , just to update you I figured out how to take panel off yay i' ll keep you posted ty deb
  • mialily May 17, 2008
    ty aborcas my dryer is working the valve coil was the issue yay tyty, deb
  • Anonymous May 20, 2008
    My dryer had a plugged vent pipe between the dryer and the outside discharge. The line was cleared but the dryer still takes a long time to dry. The exhaust blows hard out the back of the dryer. Would that indicate the dryer is not clogged internally? The burner kicks on loud at first but cycles very quietly after the first 5 minutes. When the lights are out it is evident the burner cycles on and off but when it kicks on it only stays on for about 5 to 10 seconds and you can not hear it. Is that normal? My dryer is a whirlpool with the burner on the left side but I don't know if it the model I selected here.
    President:
  • Whirlpool Master
  • 2,651 Answers
Well your generating heat which is a good sign, either there is a blockage in your venting() most likely source of issue!) but you say ou replaced, i would then look to replacing the valve coils, 279834, about 20 bucks, easy to replace... its possible that they open the valve upon start up allowing heat, but after being on 20-30 min they overheat and no longer open not allowing heat to generate..
Posted on Apr 09, 2008
  • Ron Coons
    Ron Coons May 13, 2008
    they are located on the valve body itself, go ahead and order the part, whe nyou get them youll be able to see exactly what yourlookin for, right behind the fron panel
Hi my Whirlpool dryer is not generating any heat and makes a
grind like noise then goes away after a min. model# LGR4634EQ3
Type # 121-00 anyhelp please thanks
Brian
Posted on Apr 16, 2008
SOURCE:
Dryer will not get hot
how old is it? One thing i run into a lot, is that the exhaust vent may be clogged.
if that is the case, clothes tend not to dry due to lack of air circulation. And the heating element in the dryer will not kick on. That vent is typically located in the back lower panel of the dryer. And is hooked up to a vent hose. check the hose for debris (lent) remove anything you might find. also disconnect where the hose meets the dryer, and check dryer portion as well. If nothing is clogged, then you may have a bad heating element.
Apr 05, 2014 | Whirlpool Dryers
Problem drying clothes
This is the classic symptom of "poor air flow". Another symptom you didn't mention (but I bet is happening) is that the top of the dryer gets VERY hot. OK, don't move your dryer yet... get a flashlight and look behind there. See the flexible vent connecting the dryer to the wall? It must have SMOOTH, FLOWING turns. No crushing allowed. If it's crushed/pinched, you found the problem. It's "choking" off the air flow... not allowing the hot air to escape and containing all of it in the dryer cabinet. If this is the problem, pull the dryer away from the wall about 8" and make sure the vent isn't pinched off anymore. Leave your dryer this far out, it'll ensure that this doesn't happen again. If the flexible vent is OK, there is a blockage in your house's internal dryer duct work somewhere. Turn the dryer on and go outside to where the exhaust is. Check air flow. Check the exhaust vent for debris (I've seen birds build nests in the outside exhaust, incubates the eggs...but your clothes won't get dry!). If your dryer location and the exhaust location are quite a distance (20' or more) from each other, you should hire a professional to come out and thoroughly clean it out for you. In this case, you should have this done once a year as part of routine Home maintenance. To test and verify my solution to this, you can remove the dryer vent from the wall and cover the end of it with a pair of old pantie hose. Then run the dryer as usual (the pantie hose will act as a secondary lint trap). You'll see that the dryer will be happy again and the clothes will dry in no time at all.
Aug 21, 2007 | Whirlpool GGW9200L Gas Dryer
I have an older model gas dryer with the lent catcher located on top of the dryer. It spins and it gets hot but it is not drying properly. I have to run the dryer three times to completely dry my...
you might have a restriction in the exhaust system. check the entire exhaust vent tube/hose from the back of the dryer to the outside of the building for any restrictions. check the outside exhaust vent for any restrictions or obstructions. make shure the exhaust tube/hose are as short and straight as possible any sharp curves or bends can restrict air flow.
Oct 07, 2011 | Whirlpool GGW9868K Gas Dryer
I have a gas dryer. Dryer heats up but doesn't dry clothes completely all the time. Sometimes I have to run it 2 -3 times. What do i need to replace? Maytag Performa Model # PYG2000AWW REV. 10 Serial #...
I got cut short.. and disconnected...so if this is a repeat, please forgive me:
Dryers 101
1. Heat alone does not dry clothes
2. Air alone does not dry clothes.
3. Only dry, heated air passing over and through clothes will dry them...
I recommend the following:
Set the dryer for "Air Dry".
Go outside and check the dryer exhaust.
Confirm that the exhaust is spewing out lots of air.
If it is, then you have a need for a technician to inspect everything - in person.
If it is NOT, the you need to determine the clog - or reason that air is not moving through your dryer, clothes and exhaust system.
ONLY 2 possibilities exist:
1. Fan motor is frozen and needs replacement....or
2. Duct/exhaust is clogged with lint and will not allow air to pass through.
Please check for both, clean/clear/fix as needed.
Nov 04, 2009 | Dryers
My whirpool dryer is overheating what is causing the problem
Is that a Gas or Electric dryer? Kindly mention the Make and Model so that i could assist you in a better way.
Thanks!!
Oct 13, 2009 | Whirlpool Dryers
My dryer dosen't dry my clothes
Check the exhaust tube for obstructions. If this is a gas dryer it needs airflow coming and going through that tube. This is always the cheapest, easiest first step.
Sep 05, 2009 | GE Profile Harmony DPGT750EC Electric...
My dryer isn't drying , it runs and runs and it's getting warm but not hot enough to dry a load of clothes. what's my broblem. my dryer vent is open and it still seems to me the it's not running like it...
It is possible the heating element is out of your dryer Check with Whirlpool or another service dealer to see if they have your model. sometimes it is cheaper to buy a new dryer if you have a off brand or lower cost dryer
Check the vents and filters first of all. If they are blocked at any point the air flow will be restricted and prevent drying.
The next thing would be to see if the heating element is working, whether it is gas or electric.
The heating elements could be bad and need replacing. In addition, if the dryer is not properly vented, clothes will take much longer to dry.
You should first REPLACE your exhaust hose if it has been on your dryer for more than a year. Not clean it out but REPLACE it. This not only prevents fires but also keeps your dryer at optimal performance.
Also, every 3-4 years, unplug the dryer and remove the back of it (it's just a metal panel, don't be afraid) and clean all the lint out of there. If that doesn't work, your moisture sensor may be slowly dying. If that is the case, you just have to run some loads twice. Using a pair of dryer balls helps dry the clothes faster so I recommend those too. Eventually, you may wish to consider replacing the dryer.
Aug 31, 2009 | Whirlpool Dryers
Shuts off, clothes not dry, but if start button is held then drys
this video will help you to check all the possibles couses
http://www.youtube.com/watch?v=rQV-z4f7fvA
you may
Need a good meter to check all of this.
Was this helpful?
May 13, 2009 | Kenmore 73932 Gas Dryer
Dryer not drying clothes
An easy way to check dryer function is to check the airflow on the outside of your home at the exhaust the vent. While the dryer is running, and hot, put your hand near the outlet. The air coming out should be hot and forceful. If not, there is most likely an obstruction, and the whole airway should be cleaned. Keeping the airway clean and clear can dry clothes faster and save you money.
Another possibility is the blower,(fan) which can become encrusted with lint, preventing it from moving air. This is much less likely, but still a possibility.
Dec 09, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
FRIDGIDAIRE GAS DRYER MODEL # GLGR642AS2 IS NOT DRYING CLOTHES BUT GAS IS IGNITING. THANK YOU. DON
Hi Don,
So let me get this straight, you are getting heat from the gas burner and the drum rotates but your clothes remain wet? You can check a few basic things to identify where the problem lies.. First off, have you checked the lint trap and cleaned it? Secondly, have you checked your vent system ( meaning : are you sure it is not clogged anywhere in the duct or at the end where it exits outside? If that's OK.. when your system is drying clothes.. do you get hot air flow at the end of that duct? If not, your blower may not be working ..You need to move that hot air out of the tub for the system to dry. Heat, Motion to move clothes, air flow from the blower and an unimpeded path via the vent duct to outside.. Hope one of these things to check gets you going. Regards...
Sep 03, 2008 | Dryers
Whirlpool LGV4634JQ Gas Dryer Logo
217 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
