Error message F61 - Audio Players & Recorders
  • Anonymous Mar 14, 2009
    F61
    Genius:
  • 1,550 Answers
Si es un panasonic tu IC amplificador de audio esta dañado hay que remplazarlo.
Posted on Apr 04, 2008
On my 5 disc changer panasonic SA-PT950 there is a error displaying F61 then automatically shuts down. How can I reslove this issue?
F61 indicates a fault with the laser and the only solution is to replace it.
I've had a look at my usual supplier and can't find any reference to a replacement being available and on most occasions when they are available it isn't cost effective.
Jun 21, 2011 | Audio Players & Recorders
Panasonis SC HT70 Plays for about 1hour then comes up with F61 Fault code
This fault code means the speaker cables may have shorted, or the speakers are not the correct resistance (ohms) Are you using the speakers that came with the unit? If not, make sure the ohms rating of the speakers you are using are the same as the factory speakers. If they are the same, the unit may just be overheating, make sure it is in a well ventilated area, and dust-free.
Jul 16, 2008 | Panasonic Audio Players & Recorders
Hi. I have a panasonic SA-PT860 dvd theatre system. Everytime you turn the on/off button it states that I have an F61 fault. I have looked in the manual and it says to check speaker connections. I have...
- Is your system playing in spite of this error?
Assuming that this is the model complete with "receiver" and speakers+sub and you use these and the original connections. You could try and measure your ohm level on each speaker to control if there is a bad/blown speaker. The Ohm level should be the same on each speaker - roughly.
- Hope this will get you somewhere!
Jan 28, 2011 | Audio Players & Recorders
Hi ther i have a panasonic sa-nc9 hometheatre system and it is showing the f61 error message
THE F61 ERROR USUALLY MEANS A FAULTY FAN,BUT IT SOMETIMES CAN BE FIX JUST BY GIVING THE FANS A GOOD CLEANING.
Oct 05, 2010 | Panasonic Audio Players & Recorders
Hi All, I have Panasonic SC - VK 540 music system. It has gone to the authorized service station several times for the above mentioned error. But unfortunately they have not bee able to fix the problem....
The fault seems to be a main board issue in which the relay is clicking but not activating.
SInce you are not aware of the work done earlier it must be seen if this was a reset issue. so power off and try to reset- refer you manual in thelast column for reset in case of errors...may be holding the menu/selecctor while switching on.
You can also see if there is any dry points in the main board,a loose connector or a connection . press and reset all connections
Sep 24, 2010 | Audio Players & Recorders
When i turn it on, it says F61
Given the error message, I'm going to guess that you have a Panasonic shelf unit with CD and cassette built in. If so, then the F61 means "protect" mode. This indicates that the unit has detected a problem in the final amplification stage and has shutdown. The fix for this is to replace the output amplifier pac and/or the regulator IC. If it is the amp-pac, expect a parts cost between $75 -$95.
Dan
Aug 29, 2009 | Panasonic Audio Players & Recorders
Keeps showing F61
Panasonic error code F61 is for an output /power problem. Most likely it will need the output ic replaced. But check that the fan(s) are running a bad or stopped fan will also cause F61. Replacing the IC is best left to a technician and Panasonic is the only supplier that I know has the part.
Feb 16, 2009 | Audio Players & Recorders
Error message F61
you have a problem in the power supply or the audio output circuits.more likely is the output circuit
Nov 11, 2008 | Technics Audio Players & Recorders
F61 error
If memory serves me correctly, the F61 message is teh shorthand for protect mode. There is a problem with the output section that is being detected. The unit shuts down to prevent additional damage to either the amp section or the speakers. I'll look up your specific model for more details. In the meantime, check the speaker wires to be sure that they are not frayed and crossed.
Dan
Apr 08, 2008 | Audio Players & Recorders
447 people viewed this question
 Grubhead
Grubhead
