Question about Toshiba 32DF46 32" TV
Vertical Collapse Problem
Hi...I have the same problem on my Toshiba 32DF46 with the vertical collapse. I was able to find the service manual online with all the part diagrams and such. But it does not tell me exactly where the vertical section is. Would you know by looking at these schematics? Here is the link to the free schematics I found http://www.audiolabga.com/pdf/32DF46.pdf
Any help would be appreciated....Thanks
Change diode D402
Posted on Apr 22, 2008
Cause of vertical collapse on glendale tv chassis
collapse means just a white line left to right in middle of screen--usually a bad solder connection at the vertical output chip or a bad part in that area.
Nov 07, 2012 | Televison & Video
Vertical collapse on glendale chassis
I tried to fix my tv and accidentally hit v- something (last page of service menu). Now There is a horizontal green line in the middle of the screen. How Can i fix it?
V stands for vertical output. You have a vertical collapse. Go back to service menu, and set range for vertical. Or you can try factory reset.
Nov 24, 2011 | Apex Digital AT2708 27" TV
One line horizontal onscreen
This is well known problem with the Toshiba line, the problem is in the vertical deflection circuits, it causes the picture to collapse to a flat white line, the vertical output ic and two to three capacitors need to be replaced to correct the issue.
Jan 19, 2011 | Toshiba MD20F51 20 in. TV/DVD Combo
I have a 35in Toshiba tv and it come on but have a stright line in the middle of tv.
HELLO
If the line is VERTICAL and at the centre of the screen it is called LINE COLLAPSE, but when the line is HORIZONTAL this is called FIELD COLLAPSE.
It may be dry joints on the field/frame output IC or it may have gone open circuit. I know that the field/frame output IC's can be obtained, but if you are no good with a soldering iron then you'll have to put it in for service.
GOOD LUCK WITH IT (:-)
Oct 06, 2009 | Toshiba CX35F60 35" TV
No picture. Just a vertical line accross the screen.
When this kind of set comes in for this problem, it is typically caused by a leaky/intermittent diode D402, located next to the heat sink for the vertical deflection IC. I will typically also replace the vertical deflection IC at the same time, just to avoid repeat failures.
Jul 06, 2009 | Toshiba 32DF46 32" TV
Panasonic 25'' 4:3 CRT Vertical collapse.
Change the vertical IC they are damaged
Jul 02, 2009 | Televison & Video
Vertical line across picture tube on my Symphoic model WF2703.
Is it just folded over with a thin line of light thru the middle of screen. It is a vertical collapse. Vertical Ic is loosing connection with the board or failing Already. resolder first then see if it can actually solve it. If not check capacitor or neighboring components within vertical circuit or replace the vertical IC and check if this solves the problem.
If your not inclened in electronics, have it service by a qualified one.
May 14, 2009 | Televison & Video
Vertical Collapse
genrally vertical collapse indicates failure of virtical ic. or related components
Jan 03, 2008 | Toshiba TP50H50 50" Rear Projection...
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Toshiba 32DF46 32" TV Logo
341 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
