Question about Sanyo PLC XU35 Multimedia Projector
Image too big for screen
How do i make the image fit the screen?
  • 563 Answers
Hi there
Adjust the zoom.
Posted on Apr 04, 2008
SOURCE:
Why are the movies half screen?
Movies that are created for "Wide Screen" viewing show up in letterbox on your TV. If you go to a theatre you notice it is a big rectangle. To be able to fit all of the widescreen movie on a TV it has to make the height smaller.
Because many people want to see the "complete" Movie, the "Letterbox Format" came about. I do NOT know what the word "Letterbox" actually means, or how that term was chosen. To get the complete Rectangle into that Square, they discovered that they could shrink the entire rectangle to fit that square. Meaning, what used to take 2 inches on your screen, now may only take 1.75 inches. Now a problem arrose. When you shrink the WIDTH to fit your dinky Square of a TV, the HEIGHT also has to be shrunk along with it, or else you're stretching the image as if it was on silly-putty ("Compression"). When the image was shrunk to fit the TV Screen, they were left with a gap at the top and bottom of the screen. So they simply fill it in with "Black". I guess the only alternative was to leave it snowy.
Nov 13, 2014 | Televison & Video
Where is the zoom button on TV or remote?
Press the Format button. It's directly below the power button. It has a symbol of a rectangle with a double-headed arrow inside.
Press it to cycle through the different picture shapes.
Sep 10, 2014 | Emerson LC320EM2 32" LCD HD Television
I bought new monitor Compaq S1922a and picture stretched horizontal. I have HP intel with Vista. How to adjust VGA to make picture normal?
if the whole image is too long you can adjust it from tthe image driver ..it will be in the right side on the task bar near the programs that are opened all the time ..and named like the video card you are using and usually will display when hoovering the resolution in use..open the resolutions and choose one that fits best...and confirm ..
To adjust just the the picture from the desktop ..right click on the desktop..properties..and desktop...in there choose the desktop image ..or change image ..and you will have 3 possibilities for adjusting the picture to fit..center ...stretch..and tile.. see them one by one ...if non of the stile will make it visible in a normal way ..then you should change the picture,,and choose a wallpaper that it is in the same form and big enough to fit....
T change a picture on the wallpaper it is enough to right click on it when its opened ..and choose it to be set as wallpaper from the list of tasks...
May 31, 2010 | Computers & Internet
Screen image is too big to fit screen?
change the resolution of your system by right click on desktop >propertis>setting>here you can chage the reslolution by slider
Nov 11, 2009 | Dell Dimension 2400 PC Desktop
Image too big
You have two possibilities; either buy the original remote or look up the code for 'universal' remote for that set here:
Remotes
If you can't find the code set for the remote & TV you have, look for a code set for one of the following brand names:
Funai, Symphonic, Sylvania, Emerson, Aventura, Durabrand, ESA, Magnavox, INSIGNIA, Philips and Misakai
These are all made and marketed by Funai.
Nov 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
The document size is too big when scanning
I'm assuming that you mean the scanned image is to big to fit the screen, and not that the document you are scanning is too big to fit in the scanner...
Try reducing the resoloution of the scan, this will redce the size of the scanned image.
EG: at the moment your probably scanning at 1200 dpi, when 300 dpi might suit the application better.
Oct 06, 2009 | HP J4680 Office Jet All-In-One Printer
The images are too big.
go to the printer perference or setting on your pc, there is option says scale to fit the page, click it , and some of printer allow you to select the paper size you are using. its simple problem its just driver setting issue.
Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 19, 2009 | Dell Office Equipment & Supplies
I have the same tv.
On your remote push menu, then go to settings, and then screen. Put the auto wide to on. And keep the picture mode on normal, not the zoom or wide zoom. If its in HD it will fit the screen. If its not in HD it will crop the sides. This worked for me, hope it works out.
Dec 03, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sanyo PLC XU35 Multimedia Projector Logo
108 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
