I am using the workcentre 4150 and the printer keeps giving me an error saying. "toner supply failed, remove seal tape from toner cartridge and reinstall" I can't find any tape on toner cartridge. Also the error screen is saying 07-500, and 09-700
  • mdlaw99 Mar 30, 2009
    I am having the same problem. I have two Xerox 4150s and the other one has no problem with the BRAND NEW toner cartridge.
    Master:
  • 555 Answers
The seal tape might be inside the cartridge, attached to a pull-tab.
I am only specifically familiar with the HP toner cartridges, which have a colored plastic pull-tab attached to the tape which seals the toner drum during transit. You have to pull on the tab which in turns yanks the sealing tape out after it.
Each HP cartridge has a small instruction sheet included which shows the location of the pull-tab. Perhaps your Xerox cartridge came with a similar diagram sheet?
Posted on Apr 03, 2008
Canon lbp7660cdn
Carol, Did you remove the sealing tape? There should be a small orange tab on the left side of the toner. Its integrated with the toner cartridge and easy to miss. Flip that tab over and pull. It will pull out the protective tape.
Aug 05, 2014 | Canon Imageclass Lbp7660cdn Laser Printer...
Seal tape from toner cartridge tore
prining invoices to letterhead, your laser printer is an integral part of your company's computer system. The device's ink is stored in one or more toner cartridges that are replaceable - a single black cartridge, if you have a laser printer that only prints black, or three color cartridges along with a black cartridge if the laser printer prints both color and black. The cartridges are available at office supply, retail and warehouse stores. Like inkjet cartridges, toner cartridges contain a strip of sealing tape that keeps the powder ink from spilling out until you are ready to install the cartridge.
Sponsored Link
Computer AMC ServicesOnlinepcshop.in
Laptop-PC Repairs in Delhi NCR. Total PC Solutions. Get Free Quotes
1Remove the toner cartridge from its packaging, if the cartridge is still in its box, and shake the cartridge from side to side to evenly distribute its toner.
2Hold the cartridge away from your body so ink won't spill onto your clothes or shoes. Grab the cartridge's sealing tape on the side of the cartridge and pull the tape firmly away from the cartridge. The sealing tape contains a plastic end piece for grasping it, usually in a different color than the toner cartridge.
3Continue pulling the sealing tape until it is completely out of the cartridge. Place the cartridge close to your printer or on a surface nearby until you are ready to install it. Dispose of the sealing tape in a trashcan or bag; try not to get any toner present on the tape on your hands or clothing.
Sep 14, 2013 | Xerox WorkCentre 4150 Black and White...
Code 09-700 xerox 4150
09-700 Toner Supplying Error RAP
The toner module has stopped supplying toner to the xerographic module.
Procedure
WARNING
Switch off the electricity to the machine. Disconnect the power cord from the customer
supply while performing tasks that do not need electricity. Electricity can cause death or
injury. Moving parts can cause injury.
1. Check that the tape seal has been removed from the xerographic module, PL 9.10 Item 1.
2. Remove the toner module, PL 9.10 Item 2. Check that the locking lever opens and closes
the toner shutter.
3. Install new components as necessary:
• Toner module, PL 9.10 Item 2.
• Xerographic module, PL 9.10 Item 1.
Jul 27, 2011 | Xerox WorkCentre 4150 Black and White...
Toner supply failed, remove seal tape from toner cartridge and reinstall
The cartridge inside the printer that holds the dry toner could be empty.
Or, if you have just replaced the toner cartridge, you forgot to remove a piece of "sealer" tape from the cartridge. Remove the cartridge from the printer. Remove that tape from the cartridge. Re-insert the cartridge. Try again.
May 05, 2011 | Office Equipment & Supplies
How do I change the toner cartridge on a 4150 workcentre. Where is it?
Open the front access cover and find the toner cartridge unit on the left, next to the drum. Unlatch it and slide out the toner.
See the attached diagram
Nov 17, 2010 | Xerox WorkCentre 4150 Black and White...
I need to change my Xerox workcentre 4150 toner cartridge. The old cartridge is stuck and I cannot get it out. Any ideas? Thank you. Russ thornock
You have to twist them clockwise and then counter clockwise. There is a locating pin they stick on in back, All I can say is twist and pull.
You can try opening the right side door and sliding a thin bladed screwdriver in there to assist in lostening it .
That is not uncommon and is frustraiting.
Jul 03, 2010 | Xerox WorkCentre 4150 Black and White...
I have a Xerox 4150 printer, I install a new cartridge and get a message,"The toner cartridge is not for this machice, install the correct cartridge", I also want to add that want I took out the toner...
There are a couple of different cartridges for those machines. One is a "sold" the other "metered" if the cartridge part number is different it will give you that message.
Also remove the cartridge and shine a falshlight into the machine . Look all the way to the back and locate the springs, they make contact with the cartridge. Try gently stretching them to see if they area making good contact.
Feb 07, 2010 | Xerox WorkCentre 4150 All-In-One Laser...
Xerox workcentre 4150 printer cartridge not installed correctly
i'm going to try to explain this in english even tought is not my native language, i had the same problem with my xerox 4150, when i bought a new cartridge it worked perfectly but at some point it stoped working, and it says in the screen something like "remove toner cartridge and reinstall", the problem was that the chip (is like a sticker under the toner) was in bad position from factory, a men who worked in xerox told me that there was a lot of toner cartridge that came with this problem, and this chip is ultrasonic or something like that because it never make contact with the printer circuit, so the fact is that you only have to remove and re-paste the chip in the correct position, but you have to do it several times until it works, that's how i repaired it...
Aug 26, 2009 | Xerox Office Equipment & Supplies
Toner installation error
take it out and try again, there are often adhesive tabs protecting certain areas of cartridges, that need to be removed, and that are not obvious
Not a guarantee, just something to try
Sep 09, 2008 | Xerox WorkCentre 4150 All-In-One Laser...
969 people viewed this question
k24674
jasbo
jasbo
