Question about NetGear DG834G Router
Cannot get password authorisation for netgear router
[email protected] have problems with netgear router cannot get password autherisation to register product ect
  • 1 more comment
  • Anonymous Apr 05, 2008
    need password for router to install wireless printer get so far installing then asks for router password don,t no where to find it
  • Hollyecho Montgomery
    Hollyecho Montgomery May 11, 2010
    What model is your netgear router?
    Once you log into it, what are you wanting to do?
  • Anonymous Mar 18, 2014
    show password for router
    Master:
  • 555 Answers
The default username and password for the Netgear DG834G router is:
username: admin
password: password
If that does not work (i.e., the default password has been changed), then the only way for you to log into the router is to restore the router back to its default factory settings. Then you will be able to use the default username and password above.
To restore the router's factory default settings, you must use the Default Reset button on the rear panel of the router.
1. Press and hold the Default Reset button until the Test LED turns on (about 10 seconds).
2. Release the Default Reset button and wait for the router to reboot.
Posted on Apr 03, 2008
  • Matt Jurach
    Matt Jurach Apr 08, 2008
    *Please rate this solution if you find it helpful!*
SOURCE:
Lost router password
Default user names:
  • All Netgear routers: admin
Default passwords:
Sep 21, 2012 | NetGear Computers & Internet
Lost aol start up cd for my router
  1. Connect your router to a computer by plugging one end of an Ethernet Cable into any of the four LAN ports on the back of your router.
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. To install your router, simply click on the "Setup Wizard" link at the top of the left-hand navigation menu once you are logged into your router.
A video walk-through of installing and configuring your router using the Smart Wizard is available at http://kb.netgear.com/app/answers/detail/a_id/12873.
Sep 26, 2010 | NetGear DG834G Wireless Router
I use AOL as my ISP, with British Telecom supplying my telephone line rental. On Friday 2nd my internet connection kept dropping out, and then eventually stopped connecting altogether. My original router...
If BT tested the phone line is OK but did AOL test the connection to the Netgear router and get the IP address of your Netgear router.
The phone connection is OK but the ADSL connection from the telephone exchange may not be working, that is why you are not getting an ADSL light.
Jul 12, 2010 | NetGear DG834 Router
It is a small Netgear from aol and I wish to change it over to a belkin . when i asked oal for help they gave me e serious of leters and numbers and told me to contac belkin and you would put these...
Belkin is compatible with aol, its just that the company dont support that router.. ie there support isnt trained in using it. They should provide you with the correct aol settings to use with the belkin. To put these in, connect your belkin
  • open internet explorer or alternative browser
  • type 192.168.2.1 in the webaddress bar and enter
  • this is the offline website for your belkin
  • click connection type on the left
  • leave the password box empty and click submit
  • On the connection type page you should be using pppoe
  • go next, your usernamer should be in the form
  • [email protected] and password
  • Aol will provide correct username and password if unsure of login details
  • VPI and VCI are 0 and 38 respectively
  • Mtu should be 1400
  • The rest of the default belkin settings are fine, click next and apply or finish at the bottom.
  • Your belkin router should now be connected to Aol
Any problems get back to me. Hope this helps.
Owen
Dec 29, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
I use aol & recently the netgear connection keeps getting lost. i have now reset the netgear box by the reset button at the back but it will not connect to the internet. what do i need to do. when i...
connect router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then you can see configuration of your router.
Set WAN settings as your internet service provider settings.
Enable DHCP in advanced.
click on wireless or wi fi menu and enable wi fi .
Enable WEP or WAP security if you want to secure then add key it is your password to connect internet.
Then save and restart router then check.
Let me know if you need more assistance.
Nov 09, 2009 | NetGear DG834G Router
Cant connect using AOL software through Netgear DG834NP
tell to an supplier.
I dont know, but the AOL software maybe cant support.
Peace!
Aug 26, 2009 | NetGear DG834G Wireless Router
Connecting laptop to a friend's netgear
You can have your friend log into the router with their laptop and check the setting in the router. Of course, your friend will need to remember what his password is for the router as well. If he doesnt remember that, then the only solution is to reset the router to the default.
Feb 16, 2009 | NetGear DG834G Router
Router and Aol server not conected.
With AOL make sure you have set these values in the Netgear
ADSL settings as PPPOa
VC 0,38
MTU setting to 1400
If you still have problems
Start -> Control Panel -> Add/Remove Programs -> select AOL Connectivity
click Add/Remove -> use the repair option
Follow instructions to repair.
Once complete make sure modem is configured and switched on and
try restarting AOL.
It will search for your connection, find it and allow you to log on.
Configuratin instructions can be found here
http://www.howtofixanything.co.uk/howto-278.html
Feb 10, 2009 | NetGear DG834 Router
New pass word
Have you tried resetting the router back to factory settings using the small hole in the rear? This will default it back as it was when you first got it.After doing this you would have to put all your original settings back into it though.
Apr 29, 2008 | NetGear DG834G Router
NetGear DG834G Router Logo
1,494 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
