Question about Canon imageRUNNER C3220 Color Copier
Canon Colorpass Z3000 / C-3220
I want to use a polyesther label that has a maximum temperature of 200 degrees. Will it be ok with the fusing temperature of the Canon Colorpass Z3000? The label is made for laser printers.
  • AILERON Apr 08, 2008
    Thanks Guru Spinal! Great information and I will post the results once I receive the stock.
  • Canon Expert
  • 287 Answers
Hello AILERON,
The minimum temp of the Canon IR 3220 copier is 190 degress celcius which is 374 farenheit. You did not indicate if the temp you are referring to for your label is F or C. I tend to believe it is the latter (C) if as you say the label is designed for laser printers. Laser printers typically use a high temp (like the 3220) to "fuse" or bond the toner to the paper. So, if it is indeed a celcius reference you should be ok. Use the bypass tray to feed the paper. The copier will most likely ask you the size and type of paper you are using. As far as "type" of stock you are using, start out with "PLAIN".If you indicate "HEAVY" or even "LABELS" as to the type of stock you are running, the temp will go up slightly as heavier or thicker paper requires a higher temp to properly bond the toner to the paper. I would run one sheet at a time. This allows the fuser temp to "recover" and bounce back to the original temp as anything run thru it will draw heat away.The heavier the stock the larger the depletion of heat as the paper runs thru. That is why there is a "heavy " setting. If your average customer ran card stock paper thru the bypass tray and indicated heavy (as they should) the copier would raise its temp and slow down in an effort to properly melt/fuse/bond the toner to the paper and maintain the temp despite the thicker paper's tendency to absorb large amounts of heat. I hope I made sense here. Or at least gave you enuff info for you to better understand the process and therefore make your own conclusions. If I helped you please take the time to let "FIXYA" know. :-) Good Luck. .............SPINAL
Posted on Apr 06, 2008
I have a 1996 chevy lumina and the temperature gauge keeps moving around unpredictably. The fans wont come on. We checked the fuses and relay switch. Could it be the fan motor, or temperature gauge
The gauge is supposed to move. Between 190 and 210 degrees. About a 1/16 to 1/4 inch movement with the needle. If it goes from middle(200 degrees) to hot(260 degrees) and back. Check the coolant level. Air pocket in the engine. Low fans come on at about 210 degrees. High fans come on at 225 degrees. High fans come on when the A/C is turned on. And it works.
Feb 16, 2015 | Chevrolet Lumina Cars & Trucks
How do i get my portable haier air conditioner cool off my house below 73
Air conditioners can only drop the temperature of the room temperature a maximum of 15 to 20 degrees F. A 95 degree F room temperature can drop to a maximum temperature of 75 to 80 degrees F. If the room temperature drops from 95 to 85 degrees F, Then the problem is having too small of a btu rating on the air conditioner or refrigerant has leaked out the sealed system which can affect the amount of cooling performance. You will have to buy a higher rated btu rated air conditioner if the temperature of the room drops by only 10 degrees F. Air conditioners are rated by how much heat that can be removed each hour. The more humid it is, the more work an air conditioner has to do. They cannot do more work than the btu rating that is listed on each air conditioner.
May 26, 2014 | Haier Heating & Cooling
Thermador temperature display start temperature
Send back for a replacement,obviously something definately wrong with that gauge reading 200 degrees at room temperature!!!
Jan 08, 2014 | Thermador PDR366ZS Dual Fuel (Electric and...
Radiator fans not working on a 99 dodge Grand Caravan
Hi there:
The engine coolant temperature sensor is a variable resistor with a range of -40 degrees F-265 degrees F (-5 degrees C-129 degrees C).
The engine coolant temperature sensor provides an input voltage to the PCM. As the coolant temperature varies, the sensor resistance changes resulting in a different input voltage to the PCM.
When the engine is cold, the PCM will demand slightly richer air/fuel mixtures and higher idle speeds until normal operating temperatures are reached.
The engine coolant temperature sensor is also utilized for control of the cooling fan.
Fig. 1: Engine coolant temperature sensor location - 3.3L and 3.8L engines
Check this test procedure:
  1. Turn the ignition switch to the OFF position.
  2. Detach the coolant temperature sensor electrical connector.
  3. Using a DVOM set to the ohms scale, connect one lead to terminal A and the other lead to terminal B of the coolant temperature sensor connector.
  1. With the engine at normal operating temperature, approximaterly 200 degrees F (93 degrees C), the ohmmeter should read approximately 700-1000 ohms.
  2. With the engine at room temperature, approximately 70 degrees F (21 degrees C), the ohmmeter should read approximately 7000-13,000 ohms.
  3. If not within specifications, replace the engine coolant temperature sensor.
  4. Test the resistance of the wiring harness between PCM terminal 26 and the sensor wiring harness connector. Also check for continuity between PCM connector terminal 43 and the sensor wiring harness connector. If the resistance measures greater than 1 ohm, repair the wiring harness as necessary.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jul 18, 2012 | 1999 Dodge Grand Caravan
Error code E000003-0001on Canon ir C3220
this is problem with the thermistor .
because the fixing temperature doesn't rise. maximum rise up to 70 degrees C.
solution is change the thermistor with a new.
Jul 21, 2011 | Canon imageRUNNER C3220 Color Copier
What temperater should fan turn on and i know the problem isnt the fan what should i check next
the temperature of speed motorcycle is over 100 degrees Celsius. Between 100 and maximum 110. In cooling system you must have antifreeze all the time, because this boil higher than 110 degrees.
If the fan start higher than 100 degrees, is ok. But i guess until 110 degrees. Search by internet the manual for full specifications.
Cheers.
Apr 13, 2010 | 2002 Suzuki GSX-R 600 M
Blank page from ColorPass
I cannot login to ColorPass z40e from Vista. How can I remove/change the login info from ColorPass ?
Sep 12, 2008 | Canon CLC 1150 Color Copier
Colorpass V35 with Mac
You need to download adobe postscript driver and install printer on the mac using the adobe driver!
Jul 28, 2007 | Canon CLC 1150 Color Copier
Canon colorpass Z40e
get the hard disk reloaded ur poblem should be done with
Mar 28, 2007 | Canon CLC 1150 Color Copier
Canon imageRUNNER C3220 Color Copier Logo
162 people viewed this question
old marine
old marine
