I had no problem getting the tape to eject, but when I try to load the tape again, it starts to load and then stops. There is a message on the screen that says c.emg and then the tape stops loading. The manula says to turn off the camera, turn it back on again and the tape will load as this is just a safety mechanism activation. Any help would be appreciated!
Thanks,
Kathy
SOURCE: camcorder not working says 'c-emg' on screen
That error code is telling you hey i've got a mechanical problem because when the microprocessor tells me to move the mode switch is suppose to send signals back to the processor to let the mechanism know where its at and in this case the processors not getting the right codes or signals so it wont let you use it, and thats why it will eject if a tape is inserted. Now unless you have all the special tools ,jigs and adaptors to repair this including a service and a mechanism manual you really should take this unit in as there are really no serviceable parts inside for the consumer to replace. Sorry i couldnet be more helpfull. Good Luck
SOURCE: sony hi8 ccd-trv208e pal camcorder
Same problem, same frustration. Just flashing, won't open to insert tape, Battery relatively new. Is there any way to get it to open to put in tape? I hate this technology, not along far enough.
SOURCE: error code EO3
· http://www.camcorderinfo.com/bbs/index.php
· JVC camcorders
· Tap o the side to fix your problems
-only, only, only use the more expensive JVC tapes. They keep their tension far better than cheaper brands. Also, they won't rub off their oxide coatings on the heads as easily, avoiding the 'clogging' of the heads (which thereby requires constant cleaning-further damaging the heads).
-when and if you do get E- errors do a complete rewind or fast forward to the end of the tape in order to pull out tape slack. Then remove battery and tape for a while. If still screwed, then yes, sharply tap (not hard!) on the closed tape door. That may reposition those tiny switches that I mentioned earlier and get you going again.
-NEVER, EVER, EVER, leave tapes in the machine when not in use....it creates problems for the heads and the mechanisms.
-Don't leave the battery on the camera when not in use for extended periods of time. It can create problems with respect to resetting the computer controlled logic.
-there are little switches and interlocks that provide electrical feedback about the mechanical status of things to the main processor of the camera (ie. tape/no tape in camera, door open/closed etc). Over time, the mechanics get out of adjustment because of usage, humidity and certainly rough handling. So: treat the mechanisms very, very, very delicately. Don't use/store the camera in humid conditions, hot conditions or very cold conditions. Certainly don't leave it in your car---ever!
-get the camera "cleaned and ajusted" regularly to avoid these problems. (I know...more $$$$)
· -I keep bags of dessicant in an insulated camera bag with the camera to maintain dryness and optimal temperatures during storage.
SOURCE: Canon zr300 ejects tapes
If warranty has not expired take it to an authorized service shop. It needs special tools and experience to dismantle and inspect belts or gears condition by yourself.
The solution for this required sending it to Canon factory service. I was very reluctant to do this because I've heard horror stories about Canon service, but I was actually pleasantly surprised. The total cost was only about $65 and the shipping and service turn around time was amazingly fast. I was expecting weeks to go by. If memory serves me right I shipped it and received it back in less than 2 weeks.
This is a known problem with Canon and would be covered under warranty if your time hasn't run out.
