Question about Kitchen Ranges
Viking oven locked and won't open
Viking self cleaning oven - the self cleaning never started but it is making a clicking noise even hours after turning the self cleaning mode off. the door remained locked, impossible to open. the oven was working perfectly before. it is an older unit, was in the house i bought.
Kgt1962
  • 59 Answers
SOURCE: viking igniters door removal?
Remove the access panel below the door, there is a screw at either side below the door, the panel will pull forwards at the top giving you access to the wires
Posted on Mar 20, 2009
SOURCE: Ran Self Cleaning - Display went blank & Oven Door stayed locked
You need thermostat limiter #8300802. It is on the back of the stove behind some sheet metal towards the top. With shipping this part is about $39.00. But don't waste your money. If you replace it, it will burn out again! I am currently trying to find a way for either a class action lawsuit or a total recall. Kitchenaid/Whirpool is well aware of this problem. A $1500.00 stove and it won't self clean.
Posted on Apr 07, 2009
Boogan
SOURCE: Viking range self cleaning not working - door locked
This is a more common problem than revealed by Viking.
Heres how I an "amature" fixed it.
Top center of many viking ovens have slots. With a small flashlight look into the center slots. "Its HARD to see" Look for something
shiney thats the latch/hook everything else will be dark.
I used a shish ka bab skwer. You need something like that or maybe an ice pick. Knives screwdrivers and things like that will
damage the face of the oven and then after opeining it you will forever feel bad about marring that very expensive unit.
Take the pick and with the flashlight guide it to the shiney part.
Once touching push to the LEFT. Keep trying as the pick will slip
many times. The latch should have no resistance if you can get on it.
Once open you can try and reset the hook to its open position.
Mine would not reset and prevented the door from closing.
This is now another fix. To keep the hook held to the open position. E mail me for how I jury rigged this part.
Mexvillas@aol.com
I have the hook held open now and will never be able to use the self clean function again. But thats better for me than a open wallet fix for the repair man and then wonder when it will happen again. To repeat. This is a known problem with Viking ovens.
Cheers
Posted on Apr 08, 2009
SOURCE: Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Posted on May 25, 2009
heatman101
  • 43501 Answers
SOURCE: Viking Oven Not Working After Self-Cleaning
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Apr 15, 2010
Viking oven locks up while baking. Cannot open oven door to remove food. What could be causing this problem?
Ovens usually lock when it thinks you are running the self-clean process. Unplug for 15 minutes and plug back in, if that fails call in service
Dec 12, 2017 | Viking Ovens
Why won't big oven door unlatch?
sounds like the lock motor has failed. Lots of clicking noises and not being able to lock/unlock is normally a good indicator. In some rare circumstances, main control board could be faulty. Look for me on 6ya if you need any more detailed help.
Nov 23, 2015 | Viking Kitchen Ranges
Door won't open after Self Cleaning Oven
if you are facing this problem still yet, I suggest that call a service guy to fix it and turn off the power.
Apr 19, 2013 | Electrolux Kitchen Ranges
Oven door won't lock, self clean won't start
this is a door lock error , you will need to replace
Feb 20, 2013 | Kitchen Ranges
H E L P !!! My oven made some noises this morning when my husband was wiping down the front of the oven door. Noise sounded like the "oven was going into clean mode"....but then only lasted...
Hello.
Please apply the solution this way!
To close an oven door when it's in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven cools down. When it is sufficiently cool, the door will automatically unlock.
Thanks for using fixya.
Sep 07, 2011 | Dacor Ovens
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Wait 20 seconds.
  • Wait 20 seconds.
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 | Ovens
Oven door won't open after self cleaning cycle
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Aug 13, 2011 | Viking 27" Professional Select Built-in...
Door locked after self clean cycle.
Ensure you let the oven cool down completely after a clean cycle before trying to open the door.
If the door still won't open after a couple hours of cooling down, then go to the main power panel in your house and shut off the breaker to the oven. Leave it off for 5 minutes, then switch it back on again.
Then try the oven door again.
Good luck.
Feb 28, 2011 | Viking Ovens
How long to run self clean on viking professional
The "Self Clean" will run for quite a while up to 4 hours I believe, during this time, the stove heats up to about 900 degrees!! and during this time the Door is automatically closed via special locks. It will allow you to open once it is finished, it should "Signal" this event.
Feb 11, 2010 | Viking 27" Professional Select Built-in...
Kitchen Ranges Logo
223 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
