Victor 1520A Calculator
Looking for the piece which holds calculator paper roll in place. Left one is broken.
  • kpope Apr 04, 2008
    yes, still need a solution (free)
  • Linda Sloss Nov 15, 2008
    The piece that holds the paper roll in the calculator is missing.
    New Friend:
Buy my victor 1560 for 7 dollars
Posted on Jun 18, 2010
    Sergeant:
  • 331 Answers
Coleman and other companies have repalcment add rolls parts, Some are generic and some are original..
Posted on Jun 28, 2008
SOURCE:
Clear paper jam
1. Turn ON calculator and set the slide switch P/NP/IP switch to P position.
2. Remove the paper roll from printer.
3. Use a business card and insert into the printer slot
4. press the feed key to feed the business card to clear the paper jam
Jan 19, 2015 | Victor 1260-3 Calculator
How do I load the tape in the Victor 1297?
f319ovy15l9xaaaaaelftksuqmccPPress the ARROW button on the top left side of the printer. Watch the direction of the feed roll and then push the paper into it,
Apr 11, 2012 | Victor 1297 Calculator
Please help me to load paper into the victor 1208-2 calculator
Feed the paper through the slot located just under where the roll is sitting. Once you have fed it through as far as you can, press the arrow button (the up arrow) on your calculator until it catches the paper & feeds it through the machine.
Feb 08, 2011 | Victor 1208-2 Calculator
We can't get the paper to go into the machine?
Installing the Paper Roll
1. Lift the paper holder so that it extends behind the calculator.
2. Make sure the calculator is plugged into an easily accessible
electrical outlet near the calculator.
3. Move the POWER switch to ON.
4. Insert the end of the paper into the paper slot on the back of the
calculator as shown. To avoid paper jams, use quality bond paper.
5.While feeding the paper into the slot, press and hold up arrow.
6. Place the paper roll on the paper holder.
Note: To prevent damaging the printer (which may void the warranty),
move the POWER switch to ON when operating the calculator without
paper.
Nov 27, 2010 | Texas Instruments TI-5045 SVC Calculator
Broken Paper Roll Holder
You must google to find the manufacture to find if anything is still available; but I have 2 ideas : 1. form a hard wire loop (from coat hanger or #12 guage steel wire) and attach this wire loopto the back of calculator case with screws (you'll need to make an eye loop at one end for the screw to go through). 2. make a small wood block that sits on the desk or table and make a wire loop that is held by the wood block and of course the paper roll is held by the wire loop. Goodluck, Macgivor.
Dec 07, 2009 | Victor 1430-3 Calculator
How do I install adding machine paper roll
Slide off the upper cover of the calculator, and cut across the paper roll to form a clean end.
If you are mounting the roll externally (outside of the back of the calculator), then look for a slot in the rear of the calculator, which will accept the paper. Feed the end of the paper through the rear slot, and then into the internal feed slot, and hold the [FEED] key. After that, you can flip the arm back to mount the roll and replace the upper cover.
If you want to place the roll inside of the calculator, then you need to feed from the bottom of the roll into the internal feed slot, and hold the [FEED] key. After you are finished, replace the upper cover.
Nov 23, 2009 | Canon P1-DHV Calculator
Don't have a manual; have pulled the top off but can't figure out exactly how the paper should go in.
Sep 08, 2009 | Texas Instruments TI-5019 Calculator
How do you load the paper?
Aug 31, 2009 | Canon P23-DH Calculator
Need help replacing the paper roll on a Casio BIG 12-Digit adding machine.
Aug 21, 2009 | Office Equipment & Supplies
Paper Roll Replacement
i work i mservice ,but for that model i don`t have a holder,but if you want i vill send you a universal holder.
beljin sasa
[email protected]
Feb 01, 2008 | Victor 1240 Calculator
Open Questions:
294 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
