Question about LG DLE2514 Electric Dryer
Dryer shuts off on own lights blink
Dryer shuts off on own with lights flashing on select button and check filter light on. cleaned filter checked vent..nothing. You can start dryer again but after a minuter it shuts off.
  • 5 more comments
  • Anonymous Apr 16, 2008
    dryer lights flashing wont trun on...
  • james
    james Nov 30, 2013
    dryer won't shut off even when it's turned off, open the door and it shuts off, close the door and it starts back up again. can anybody help?
  • Anonymous Mar 12, 2014
    I have checked the vent lines & trap & both are clear
  • Anonymous Mar 19, 2014
    15 seconds it will restart just to shut off in 5 seconds again. It is hot in the dryer so it is heating but maybe too fast.
  • Anonymous Mar 22, 2014
    the dryer starts to turn but sounds like it laboring to turn or turns slow runs for about 2 minutes then shuts off
    cleaned out under lint basket and it seemed to run a little longer but then it shut off again??
  • lso349
    lso349 Dec 15, 2014
    I had a similar issue with my LG Tromm. The problem with mine, was the latch was worn and opening just enough to shut the dryer off, leaving the light inside on. I placed a thick self adhesive felt chair leg pad on the dryer door where the dryer plunger touches the door. It has been working great for 4 months now.
Turn off breaker wait an hour turn back on.
Posted on Apr 04, 2008
GLEQ2152ES0 dryer stops after ten minutes and then blinking lights on the right of the side panel. The lights that blink simultaneously.
The dryer is telling you what is wrong with it. Count the number of flashes the drying, cooldown, pressaver and clean filter light are flashing then count the number of times the control/start light is flashing. That will give you the error code number.
Dec 04, 2016 | Dryers
The clean filter light was flashing but it stopped after I cleaned the vent but still won't heat, Is there another vent/filter in this dryer?
the blinking filter light is just a reminder, not connected to anything. goes out when you start cycle. however, if the dryer overheated then it may have blown the thermistor fuse. check out appliancepartspros.com or repairclinic.com for how to videos and parts.
May 23, 2016 | LG DLG5988 Gas Dryer
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
Check filter light remains power light blinking
Hi friend,,,
welcome to fixya
try to unplug it for 30 minutes this should reset the control board. and clear any errors it has. and may start working again. let me know how it goes OR
try this to get it in diagnostic test mode have the dryer in standby mode then press and hold more time and less time and then press the power button to get out of this mode you will have to unplug the unit for at least 1 minute
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Dryers
Electric front load dryer flashes check filter.
what is the indicator lights in the board means. The green light is flashing one flash in then going into lock mode.
Model# RGPJ 05 EAUER
Jan 29, 2010 | LG Heating & Cooling
Check filter light wont shut off and setting.lg tromm dryer
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
Dec 23, 2009 | LG Dryers
Dryer won't power up, says check filter
Check the door switch first.Than look for possible thermal fuse has cut off.
May 22, 2008 | LG DLE2514 Electric Dryer
LG Gas Stacking Dryer
The check filter light comes on every load to remind you to clean the lint filter. Cooling only happens when that light is flashing not when it's on solid. If this is a gas dryer check the exhaust hose and vent on the outside of the house. If it is blocked it will not let the unit get to the correct temp due to cycling.
Dec 16, 2007 | LG DLE2514 Electric Dryer
LG DLE2514 Electric Dryer Logo
793 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
