Question about Neovo F-417 17" LCD Monitor
Screen goes black
My monitor loads the windows flash image screen and then goes totally blank, any suggestions
  • wizbang_fl Apr 26, 2009
    I have a F419 with the same issue. It is hit an miss when the image will remain on the screen. It's not software that I can tell. My PC works with another 15" monitor we have wihtout any problems. The resolution is fine as well.
  • 106 Answers
Lookour onboard VGA has gone unserviceable, this can be rectified by putting PCI VGA card in PCI slot ...also try out the resulation setting by trying ur PC on other monitor.
Posted on Apr 03, 2008
    Sergeant:
  • 202 Answers
Hello antwaun42
What needs to be done 1st, is to determine if the issue is hardware or software-related.
It doesn't matter what order you do the following in.
(01) Determine if the issue is w/ your monitor hardware. You can do this in one (or both) of two ways.
(A) Plug your current monitor into another computer whose video (display) is working fine.
(B) Plug a different (known working) monitor into the computer where you are experiencing the issue.
(02) Determine if the issue is "drivers"-related. To do this, boot your computer into "Safe Mode" and see if the problem persists. If it does, then the problem is likely hardware-related. If it doesn't, then there is a drivers-related issue. We can help you w/ that as well.
HERE is a link that will detail how to get into Safe Mode if yours is a Microsoft Windows-based operating system.
Please, let us know if this response was helpful for
you or, of course, if you have any further questions.
Thank you
BJ
  • Anonymous Apr 03, 2008
    In the case of step (01), if the problem follows the monitor (to the other computer that you connect it into) then you know the problem is with the monitor itself.
    If, however, the problem persists even w/ a different monitor connected to the computer you are experiencing the issue on, then you know the issue is not w/ the monitor.
    In this case, it's still undetermined if the issue is hardware or software-related. (The issue could be w/ your video adapter expansion card or w/ drivers.)
    If you haven't done so already at this stage, try step (02) (booting into Safe Mode) to see if the issue persists.
SOURCE:
Thinkpad blank screen
Once you run safe mode. You can turn off the laptop. Then start booting normally.
Mar 02, 2012 | IBM ThinkPad T20 2647 Notebook
I am using a Dell lap top with Windows Vista to connect to a NEC VT590 projector. I want to show a PowerPoint presentation. As the computer is booting, the computer monitor is blank and the loading...
You need to configure the projector as a second monitor as explained here
http://www.online-tech-tips.com/windows-vista/multiple-monitors-vista/
Feb 02, 2011 | Computers & Internet
Hello there , i d like to express my problem here , with the hope to find a solution . I have an LG L1730s monitor for about four years . Recently i had a video card burn and i changed it with a new one ....
Hi
I've repaired a lot of these monitors and every one seemed to do something strange. In this case my first thought is that somehow he monitor firmware got zapped when the card was damaged. Although this could certainly fall into the category of an open ground in the cable. My suggestion at this point would be to take it to a reputable repair person and get their estimate or take a look at www.micromendllc.com.
Aug 18, 2010 | LG L1730S 17" LCD Monitor
My monitor goes blank after a while,power light still on,why is this & what can I do?
Check connection cable with videocard on your PC, unplug it and carefully plug it in again. (Turn off your monitor during this operation). If monitor goes black after loading OS (like Windows), then your screen resolution higher then monitor can support. Load computer in Safe Mode and lower screen resolution.
Aug 10, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
My screen goes blank immediately after initial DELL startup image
You can either try to reset the BIOS, or have the restore cd fix it for you. By the way, what does the message say?
Nov 27, 2008 | Dell Dimension B110 PC Desktop
Monitor goes black but shows icons...
I'll assume this is an LCD panel screen.
If what you are saying is the screen shows up and then goes dim or starts dim, and you can see a dark image of the system starting up and then displaying Windows...
Your problem is a bad CCFL (Cold Cathode Fluorescent Lamp) at the top of the LCD panel.
If the screen is totally blank, then it may be the power inverter.
You can find many websites that sell these parts, but make sure you have the right model.
If you feel comfortable with working on computers, you can replace this part yourself. Otherwise, you may want to pay a technician to do it. Make sure to get a fixed price quote before authorizing the work
Here is a website on LCD repair for laptops, but it the same principal for display monitors.
http://www.ccfldirect.com/lcdtutorial.html
RDO
Nov 16, 2008 | HP vs15 15"LCD Flat Panel Monitor
Technically Black Screen
when u power up the system press F8 key untill u get safe mode menu.
then goo to enable vga mode set your resolution to 800*600 or 1024 * 768.
also u can try safe mode or last known good config.
Oct 22, 2008 | IBM ThinkPad T20 2647 Notebook
Black Screen
hi, try boot to safe mode, check the display properties, settings and the refrsh rate. if not solved, reinstall the graphics controller driver..
thanks
Aug 15, 2008 | Toshiba Satellite A135-S2276 Notebook
Good picture for 30 seconds then screen goes black with a faint ghost of the image
i hope the problem will be in LOT of the monitor...you need to replace the LOT
Jun 14, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Neovo F-417 17" LCD Monitor Logo
694 people viewed this question
Top Neovo Computers & Internet Experts
Dimitar Todorov
Leo Stuurman
Level 1 Expert
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
