I would like to use my Panasonic PV-S4690 to change the channels on my TWC Pioneer HD cable box. TWC just reprogrammed the unit so their is only one timer setting. Before the re-programming I had eight timming on settings. I used the Panasonic years ago to control a different cable box. Is their a code that each unit will regonize each other? My Sony RM-AV2500 uses a code number 3102. I would need the S4690 to turn on the cable box and tune to the right station. Is this posible or is the unit to old. Thanks Ji
  • wilsongxp Apr 03, 2008
    I have another Sony remote with a timer in it that will work.
    Thanks
    Jim
    Problem Solver:
  • 12 Answers
Try getting an all Around remote to control all your devices.
Posted on Apr 03, 2008
We are connected to cable, but don't get most of the channels, we are not using a box for cable. is there a way to het the channels/
Some of the older units in the cable band will not receive channels abover about channel 46---if this is the case nothing can be done.
Jul 16, 2012 | Panasonic PV-C1320 13 in. TV/VCR Combo
I have a Panasonic PV-V4525S VCR and I'm trying to program it to work with the Comcast cable. Right now it will only record the same channel that the TV is on and I have to tell the VCR to record channel...
If your using digital cable it will only record channel 3 or 4 depending on what your cable box is set to...In order for it to record different channels it needs a cable source plugged directly into it. You will only be able to record standard cable channels 1-125. If it's digital cable forget about... you can only record it with channel 3/4 a solution to this would be using a 2nd digital box.. "auto-programming" may be limited even with a 2nd cable box. If your only using standard cable 1-125... you can use the TV/VCR button it will switch between the tuner of the TV & VCR allowing you to record while you watch a different show... keep in mind this won't work for digital channels which if I'm not mistaken comcast has already converted all channels to digital even basic.
Feb 13, 2011 | Panasonic PV-V4522 VHS VCR
Panasonic pv-c1350w channel/clock auto set
You are probably talking about the main menu that appears when the TV is taken off the AC power outlet, to get rid of this page just turn the tv off and on again and it should give you access to what ever channel was tuned before, if your game console has an RF out, your TV should be set to channel 3 ir 4, if the console has composite outs the change the channel until the TV goes to Aux in or Video in. Retrevo.com has an instruction manual available which you can download free, just in case you need more informantion, if the channel keys do not work, then you may have to get a universal remote ,they are fairly inexpensive and will come in very handy at least for the basic functions or just have theTV worked on.
May 12, 2010 | Panasonic PV-C1350W Combo
ARE MY PANASONIC PV-DM2799, AND MY PANASONIC PV-M2737 BOTH DIGITAL READY, AND ONLY NEED A CONVERTER BOX TO RECEIVE PREMIUM CHANNELS....THANK YOU VERY MUCH
You can get a converter box for these for over the air programming but if you got satalite or cable you are FINE!!! it will work great
But they do not have digital tuners no.
Please do rate the answer thanks
Aug 19, 2009 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Color shift to green on non hd channels
change out your box. thats why they rent them. they anticipate your going to have issues thats why they rent them. i have gone through about 12 boxes over 5 years. change res to 1080i
Jun 02, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
May 19, 2009 | LG 37LG30 37 in. LCD HDTV
TV not finding Digital Channels from Cable Box
I don't know where you're located but you may want to double check with Time Warner on the availibilty of an HD box. I have TWC with an HD tier package and have an HDMI out on the box that runs directly into HDMI on this TV. Hope that helps!
Jan 17, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
No audio
try to reprogram the channel. it seems that your tv's sound circuit is fine.
Jan 09, 2007 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Televison & Video Logo
135 people viewed this question
Top Televison & Video Experts
Electro Med Services...
